    AmbientWeather call to get swimming pool temp displayed on Mirror
    3 Posts 2 Posters 667 Views 2 Watching
    • J
      joshuaandrews
      I just built a mirror with a portrait 1920x1080 monitor and a Pi 3b. Fun toy, but I had some space left and my kids suggested showing the temperature of our pool.
      So I bought a “WS-50-F007PF” from ambientweather.com, which has a floating thermometer, paired with an indoor display that has WiFi and will update ambientweather.net with your systems info.
      (note that you can also set up a full weather station, I just want the pool temp)
      After getting the unit on the WiFi (it needs a uniquely named 2.4Ghz network - no 5Ghz “smart sharing”) I set up a login at ambientweather.net, added the device and poof, pool data online.
      Using my account at ambientweather.net I created a free API key and a app/developer key. Using postman I verified https://api.ambientweather.net/v1/devices?applicationKey=&apiKey= returned json including my pool temp.
      “macAddress”: “DE:AD:E3:12:34:56”,
      “lastData”: {
      “dateutc”: 1588720380000,
      “tempinf”: 74.5,
      “humidityin”: 46,
      “tempf”: 81.3,
      “baromabsin”: 29.97,
      “baromrelin”: 29.86,
      “battout”: 1,
      “feelsLikein”: 73.8,
      “dewPointin”: 52.3,
      “tz”: “America/New_York”,
      “date”: “2020-05-05T23:13:00.000Z”
      “info”: {
      “name”: “Pool”
      where tempf is the field I need.
      I took a look at the available JSON modules and found the unsupported “MMM-json-feed”
      using a config of:
                          module: "MMM-json-feed",
                          position: "bottom_right",
                                  urls: [
                                          "https://api.ambientweather.net/v1/devices?applicationKey=<key>&apiKey=<key2>
                                  arrayName: "0",
                                  title: "Pool Temp",
                                  values: ["lastData.tempf"],
                                  replaceName: [["tempf",""]],
      It looks great and updates every 5 minutes.
      I also set
      wrapper.className = “bright large”;
      in MMM-json-feed.js to make the temp easy to read.
      just FYI for anyone searching ambientweather in the future.
      Mykle1M 1 Reply Last reply
      Reply Quote 2
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @joshuaandrews
        @joshuaandrews
        Cool! :-)
        • J
          joshuaandrews
          I guess I should add an image. I have “MMM-json-feed”, “currentweather” and “weatherforecast” all “bottom_right” and they stack nicely.
          Reply Quote 1
