    MMM-Strava Auth Fail
    10 Posts 6 Posters 2.2k Views 6 Watching
    • H Offline
      huso15
      I followed all the steps, but I fail to authorize the app.
      Every time I go to http://localhost:8080/MMM-Strava/auth/ or http://192.168.1.23:8080/MMM-Strava/auth I get “Safari failed to open page”. Any idea on what I"m doing wrong? I’d love to get this module to work on my mirror.
      alt text
      Thank you in advance for all your help.
      • lavolp3L Offline
        lavolp3 Module Developer @huso15
        @huso15 Where do you have the mirror running? On the mac or on a pi?
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • lavolp3L Offline
          lavolp3 Module Developer @lavolp3
          @lavolp3 If I remember correctly:
          If you’re trying to auth from your mac’s browser using the pi as the mirror you should use the Pi’s IP address as callback URL. NOT “localhost”.
          You need to use a valid address you can enter from your mac or laptop.
          This one works if you also use http://192.168.1.23:8080 as callback URL for the authentication.
          • H Offline
            huso15 @lavolp3
            @lavolp3 Thank you for the reply.
            I’m running MagicMirror on PI. I’m using SSH on Mac’s terminal to access PI. The Strava Auth I’m trying to run through Safari on my Mac by using PI’s IP: 192.168.1.23 - but, it doesn’t work. I’m still getting Failed to Open Page.
            I’ve tried 192.168.1.23, localhost, and even 192.168.1.23:8080 as Authorization Local Callback Domain, but still nothing.
            No idea how to proceed or what I’m doing wrong here.
            • H Offline
              huso15
              Anyone that can help with this issue?
              • mumblebajM Offline
                mumblebaj Module Developer @huso15
                @huso15 Hi. You need to add the config to the config.js and start MM. Then run http://192.168.1.23:8080/MMM-Strava/auth in a browser. This should then open the auth page to Strava. Hope this helps.
                  MaXi-XCeL Project Sponsor
                  Your config.js should also allow listen on for 192.168.1.23. By default it is set to “localhost” only.
                  There is also a “ipWhitelist” which should reflect the ip address of your Mac and your PI.
                  Here’s my config.js relevant to listen on and ipWhitelist
                  var config = {
                  	address: "0.0.0.0", 	// Address to listen on, can be:
                  	port: 8080,
                  	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                  	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.178.73", "192.168.178.76"], 	// Set [] to allow all IP addresses
                  					// or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"],
                  And here’s my Strava module in “config.js”
                  				module: "MMM-Strava",
                  				position: "bottom_right",
                  				header: "Strava",
                  					client_id: "12345",
                  					client_secret: "123456789012345678901234567890",
                  					mode: "chart",
                  					chartType: "bar",
                  					activities: ["run"],
                  					stats: ["count", "distance", "elapsed_time", "achievements"],
                  					period: "recent",
                  					units: "metric",
                  If you’ve downloaded the Strava module and add it to your config together with the listen on and ipWhitelist you should be able to successfully register and use the module.
                  Good luck!
                  David
                  A BerkSmash1984B 2 Replies Last reply Reply Quote 0
                    acdacd2 @MaXi-XCeL
                    @maxi-xcel hello,
                    I get this message “Cannot GET /MMM-Strava/auth” whith the page request.
                    Any idea ?
                    Thanks,
                    marc,
                      acdacd2
                      @acdacd2 solved
                      • BerkSmash1984B Offline
                        BerkSmash1984 @MaXi-XCeL
                        @MaXi-XCeL Hello, I am getting client id not authorized, despite having my client ID and client secret correct (from Strava API page). I also have the whitelist setup correctly and can access my MM from my local browser (the MM itself is on a RPI4). I receive the link within the magic mirror and am redirected to the authorization page on Strava, but after clicking authorize and restarting MM, I am still getting the same client ID not authorized. Any help would be greatly appreciated. Thanks!
