    MTA MODULE MM NEWBIE HERE!
    14 Posts 3 Posters 3.5k Views 3 Watching
      jeaniouso
      2020-05-14-194423_1024x768_scrot.png ))
      I hope that everyone is well and healthy at this time. So, I successfully installed magic mirror as well as a module after several attemps and several segues to make it happen.
      I’ve been struggling trying to install the MTA Subway Module however, after several attempts with use of the newbie guide to modules, It finally worked and didn’t cause my MM to corrupt however, none of the modules that I have personally installed doesn’t seem to work for some strange odd reasoning . I have posted on what I think is a decent config script however, I notice that my line of module is a bit off from the program file…
      I’ve included a screenshot .
        Mykle1 Project Sponsor Module Developer @jeaniouso
        @jeaniouso
        At first glance, I see you’re missing a closing comma at the end of the transit module entry. You can start there. :-)
                updateInterval: 300000
        J 5 Replies Last reply Reply Quote 0
          jeaniouso @Mykle1
          @Mykle1 Hi Mykle, I appreciate your reply… I see that you’re in the big apple like me , I hope that you’re well and staying healthy.
          So, I tried adding ; to the last curly and I restarted MM however, a splash screen popped up upon restart.2020-05-15-080937_1024x768_scrot.png
            jeaniouso @Mykle1
            @Mykle1 I followed your posting I believe as much as possible.
              sdetweil @jeaniouso
              @jeaniouso he said “a closing comma”, not semicolon,
              the config is a list (array ) of module entries
              each starts with { and ends with }
              if there is another one coming, add a ‘,’ to the end of the 1st, to say ‘more coming’
              it won’t hurt to have a ‘,’ after the module block }
              modules: [                                  // start of list (array)
              {                                           // start of a module
              }                                           // end of a module entry
              ,                                           // another entry to follow
              etc
              etc
              ]                                           // end of the modules list (array)
                jeaniouso @Mykle1
                @jeaniouso [0_1589594860883_config.js](Uploading 100%)
                  jeaniouso @Mykle1
                  @Mykle1 /* Magic Mirror Config Sample
                  • By Michael Teeuw http://michaelteeuw.nl
                  • MIT Licensed.
                  • For more information on how you can configure this file
                  • See https://github.com/MichMich/MagicMirror#configuration
                  var config = {
                  address: “localhost”, // Address to listen on, can be:
                  // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
                  // - “0.0.0.0”, “::” to listen on any interface
                  // Default, when address config is left out or empty, is “localhost”
                  port: 8080,
                  ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                  // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                  // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                  language: "en",
                  timeFormat: 24,
                  units: "metric",
                  		     // false, default for all  NON-armv6l devices
                  		module: "alert",
                  		module: "updatenotification",
                  		position: "top_bar"
                  		module: "clock",
                  		position: "top_left"
                  		header: "US Holidays",
                  					symbol: "calendar-check",
                  					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                  		module: "compliments",
                  		position: "lower_third"
                  		module: "currentweather",
                  			locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                  			appid: "YOUR_OPENWEATHER_API_KEY"
                  		module: "weatherforecast",
                  		header: "Weather Forecast",
                  			locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                  		module: "newsfeed",
                  		position: "bottom_bar",
                  			feeds: [
                  					title: "New York Times",
                  			showSourceTitle: true,
                  			showPublishDate: true,
                  			broadcastNewsFeeds: true,
                  			broadcastNewsUpdates: true
                  if (typeof module !== “undefined”) {module.exports = config;}
                    jeaniouso @Mykle1
                    @Mykle1 ```
                    code_text
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert",
                    			position: "top_bar"
                    			module: "clock",
                    			module: "newsfeed",
                    				feeds: [
                      sdetweil @jeaniouso
                      @jeaniouso but that is the default config.js, not the one w the module u are having trouble with…
                      Also, u can edit your forum posts to correct posting errors.
                      .I worked w u tonight, and u had the modules installed correctly, but the API key was not correct for some reason
                        jeaniouso @sdetweil
                        Thank you so much for your tireless efforts! I finally have it working… I played around with the script after getting rid of errors pointed out by @Mykle1 plus his tutorial was excellent as I read it again and I opted for another API key that I found on here as suggested by @sdetweil … I finally got it working thanks to you two!! Now I can rest lol… Man what a workout!!!
                          sdetweil @jeaniouso
                          @jeaniouso said in MTA MODULE MM NEWBIE HERE!:
                          u are supposed to create a new apikey on the train providers web site
                          J 2 Replies Last reply Reply Quote 0
                            jeaniouso @sdetweil
                            @sdetweil I did but, for some reason it’s not working hence why I used the other one
                              jeaniouso @sdetweil
                              @sdetweil I stand corrected. The APIKEY in the code is mine… I just confirmed
                                @jeaniouso
                                Good to see you got it sorted and perhaps a better understanding of how things work. Well done.
