    MTA MODULE MM NEWBIE HERE!
    14 Posts 3 Posters 3.0k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @jeaniouso
      @jeaniouso
      At first glance, I see you’re missing a closing comma at the end of the transit module entry. You can start there. :-)
              updateInterval: 300000
      J 5 Replies Last reply Reply Quote 0
        jeaniouso @Mykle1
        @Mykle1 Hi Mykle, I appreciate your reply… I see that you’re in the big apple like me , I hope that you’re well and staying healthy.
        So, I tried adding ; to the last curly and I restarted MM however, a splash screen popped up upon restart.2020-05-15-080937_1024x768_scrot.png
          jeaniouso @Mykle1
          @Mykle1 I followed your posting I believe as much as possible.
            sdetweil @jeaniouso
            @jeaniouso he said “a closing comma”, not semicolon,
            the config is a list (array ) of module entries
            each starts with { and ends with }
            if there is another one coming, add a ‘,’ to the end of the 1st, to say ‘more coming’
            it won’t hurt to have a ‘,’ after the module block }
            modules: [                                  // start of list (array)
            {                                           // start of a module
            }                                           // end of a module entry
            ,                                           // another entry to follow
            etc
            etc
            ]                                           // end of the modules list (array)
              jeaniouso @Mykle1
              @jeaniouso [0_1589594860883_config.js](Uploading 100%)
                jeaniouso @Mykle1
                @Mykle1 /* Magic Mirror Config Sample
                • MIT Licensed.
                • For more information on how you can configure this file
                • See https://github.com/MichMich/MagicMirror#configuration
                var config = {
                // - “0.0.0.0”, “::” to listen on any interface
                // Default, when address config is left out or empty, is “localhost”
                port: 8080,
                ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                language: "en",
                timeFormat: 24,
                units: "metric",
                		     // false, default for all  NON-armv6l devices
                		module: "alert",
                		module: "updatenotification",
                		position: "top_bar"
                		module: "clock",
                		position: "top_left"
                		header: "US Holidays",
                					symbol: "calendar-check",
                					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                		module: "compliments",
                		position: "lower_third"
                		module: "currentweather",
                			locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                		module: "weatherforecast",
                		header: "Weather Forecast",
                			locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                		module: "newsfeed",
                		position: "bottom_bar",
                			feeds: [
                					title: "New York Times",
                			showSourceTitle: true,
                			showPublishDate: true,
                			broadcastNewsFeeds: true,
                			broadcastNewsUpdates: true
                if (typeof module !== “undefined”) {module.exports = config;}
                  jeaniouso @Mykle1
                  @Mykle1 ```
                  code_text
                   * MIT Licensed.
                  var config = {
                  	port: 8080,
                  	language: "en",
                  	timeFormat: 24,
                  	units: "metric",
                  			module: "alert",
                  			position: "top_bar"
                  			module: "clock",
                  			module: "newsfeed",
                  				feeds: [
                    sdetweil @jeaniouso
                    @jeaniouso but that is the default config.js, not the one w the module u are having trouble with…
                    Also, u can edit your forum posts to correct posting errors.
                    .I worked w u tonight, and u had the modules installed correctly, but the API key was not correct for some reason
                      jeaniouso @sdetweil
                      Thank you so much for your tireless efforts! I finally have it working… I played around with the script after getting rid of errors pointed out by @Mykle1 plus his tutorial was excellent as I read it again and I opted for another API key that I found on here as suggested by @sdetweil … I finally got it working thanks to you two!! Now I can rest lol… Man what a workout!!!
                        sdetweil @jeaniouso
                        @jeaniouso said in MTA MODULE MM NEWBIE HERE!:
                        u are supposed to create a new apikey on the train providers web site
