    MTA MODULE MM NEWBIE HERE!
    14 Posts 3 Posters 3.0k Views 3 Watching
      sdetweil @jeaniouso
      @jeaniouso he said “a closing comma”, not semicolon,
      the config is a list (array ) of module entries
      each starts with { and ends with }
      if there is another one coming, add a ‘,’ to the end of the 1st, to say ‘more coming’
      it won’t hurt to have a ‘,’ after the module block }
      modules: [                                  // start of list (array)
      {                                           // start of a module
      }                                           // end of a module entry
      ,                                           // another entry to follow
      etc
      etc
      ]                                           // end of the modules list (array)
        jeaniouso @Mykle1
        @jeaniouso [0_1589594860883_config.js](Uploading 100%)
          jeaniouso @Mykle1
          @Mykle1 /* Magic Mirror Config Sample
          • By Michael Teeuw http://michaelteeuw.nl
          • MIT Licensed.
          • For more information on how you can configure this file
          • See https://github.com/MichMich/MagicMirror#configuration
          var config = {
          address: “localhost”, // Address to listen on, can be:
          // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
          // - “0.0.0.0”, “::” to listen on any interface
          // Default, when address config is left out or empty, is “localhost”
          port: 8080,
          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
          language: "en",
          timeFormat: 24,
          units: "metric",
          		     // false, default for all  NON-armv6l devices
          		module: "alert",
          		module: "updatenotification",
          		position: "top_bar"
          		module: "clock",
          		position: "top_left"
          		header: "US Holidays",
          					symbol: "calendar-check",
          					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
          		module: "compliments",
          		position: "lower_third"
          		module: "currentweather",
          			locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          			appid: "YOUR_OPENWEATHER_API_KEY"
          		module: "weatherforecast",
          		header: "Weather Forecast",
          			locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          		module: "newsfeed",
          		position: "bottom_bar",
          			feeds: [
          					title: "New York Times",
          			showSourceTitle: true,
          			showPublishDate: true,
          			broadcastNewsFeeds: true,
          			broadcastNewsUpdates: true
          if (typeof module !== “undefined”) {module.exports = config;}
            jeaniouso @Mykle1
            @Mykle1 ```
            code_text
             * MIT Licensed.
            var config = {
            	port: 8080,
            	language: "en",
            	timeFormat: 24,
            	units: "metric",
            			module: "alert",
            			position: "top_bar"
            			module: "clock",
            			module: "newsfeed",
            				feeds: [
              sdetweil @jeaniouso
              @jeaniouso but that is the default config.js, not the one w the module u are having trouble with…
              Also, u can edit your forum posts to correct posting errors.
              .I worked w u tonight, and u had the modules installed correctly, but the API key was not correct for some reason
                jeaniouso @sdetweil
                Thank you so much for your tireless efforts! I finally have it working… I played around with the script after getting rid of errors pointed out by @Mykle1 plus his tutorial was excellent as I read it again and I opted for another API key that I found on here as suggested by @sdetweil … I finally got it working thanks to you two!! Now I can rest lol… Man what a workout!!!
                  sdetweil @jeaniouso
                  @jeaniouso said in MTA MODULE MM NEWBIE HERE!:
                  u are supposed to create a new apikey on the train providers web site
                  J 2 Replies Last reply Reply Quote 0
                    jeaniouso @sdetweil
                    @sdetweil I did but, for some reason it’s not working hence why I used the other one
                      jeaniouso @sdetweil
                      @sdetweil I stand corrected. The APIKEY in the code is mine… I just confirmed
                        Mykle1 Project Sponsor Module Developer @jeaniouso
                        @jeaniouso
                        Good to see you got it sorted and perhaps a better understanding of how things work. Well done.
