    PIR sensor to turn monitor off. Nothing works :(
    magic mirro pirpir sensor
    31 Posts 8 Posters 19.2k Views 9 Watching
    • BKeyportB
      BKeyport Module Developer
      Honestly, I would resort to an out-of-MagicMirror experience. I whipped up some python code using GPIOZero to replace MMM-Buttons, for instance…
      • E
        elleclouds @wishmaster270
        @wishmaster270 Can you help me out with this?
        • R
          rafhtl
          I dont know if this is helpful but I use
          /usr/bin/vcgencmd display_power 0
          monitor off
          /usr/bin/vcgencmd display_power 1
          monitor on
          works flawlessly
          (ssh in pi and type the commands to try them)
          r
          • E
            elleclouds @rafhtl
            @rafhtl Can you give me more context on where to input this and where it should go?
            • R
              rafhtl
              ok
              if u are using MMM-PIR-Sensor
              it should already be in the module
              please try from ssh (you have to log in to the pi) and then type
              you should first try this to see if monitor responds to command
              so first log in from a pc to your pi using putty
              r
              • E
                elleclouds @rafhtl
                @rafhtl I was able to achieve this but my monitor stays off after a while and doesn’t come back on. Earlier in the thread I was suggested to just put the monitor to sleep but the code I used came back with errors. I needed help with those lines.
                • R
                  rafhtl @elleclouds
                  @elleclouds ok
                  You need to acces the monitor’s menu
                  I think I read you dont have a remote?
                  You need to access the energy saving menu
                  It musdt be something simple as that
                  • E
                    elleclouds @rafhtl
                    @rafhtl can’t access it. Stripped down the monitor in my build a while ago
                    • BKeyportB
                      BKeyport Module Developer @elleclouds
                      wait, the code comes back with errors?
                      do us a favor.
                      DISABLE the pir-sensor module for this test.
                      SSH into the mirror when you’re gonna be away for a couple hours.
                      type: vcgencmd display_power 0 - Monitor should shut off.
                      Go do whatever for a while. Come back,
                      SSH back into the mirror, and type vcgencmd display_power 1 Monitor should power on.
                      If the monitor doesn’t power back up, there’s a good chance the monitor isn’t good for your use. If it does, then we need to look at how it’s interfacing with the PIR Sensor module.
                        sdetweil @BKeyport
                        @BKeyport commands that work on pi3, do not work on pi4… many struggling with things that worked, but don’t now
                        BKeyportB 1 Reply Last reply Reply Quote 1
                        • BKeyportB
                          @sdetweil True - however these commands do work the same as they did before. (Assuming you’re using the HDMI 0 plug closest to the power supply anyway)
