    PIR sensor to turn monitor off. Nothing works :(
    magic mirro pirpir sensor
    31 Posts 8 Posters 18.1k Views 9 Watching
    • E Offline
      elleclouds @wishmaster270
      @wishmaster270 Since the monitor would stay on… would that have any benefits? I can’t access the menu of the monitor due to taking it apart and not knowing where the button to access the menu is located. Thanks for all the assistance and advice, I appreciate it.
      • wishmaster270W Online
        wishmaster270 Module Developer @elleclouds
        @elleclouds Black causes the display to turn off the backlight which saves energy. But it is surely less effective than switching the display to standby mode.
        E 1 Reply Last reply Reply Quote 1
        • E Offline
          @wishmaster270 I’m using this in the config file but its coming back with an error. What am I doing wrong?
                  module: 'MMM-Screen-Powersave-Notification',
                      delay: 60,
                      hideInsteadShutoff:true,
            sdetweil @elleclouds
            @elleclouds said in PIR sensor to turn monitor off. Nothing works :(:
            please use the markup for code or config info
            mark the text, and hit the button above the editor </>
            • E Offline
              elleclouds @sdetweil
              @sdetweil Did you change it for me, because it looks in the correct format? Any help with the code?
                @elleclouds yes I changed it… know nothing about the module sorry
                  @sdetweil well, u have 1 more close brace } then u have opens {
                              delay: 60,
                          }                  //  ---- what is that guy?
                  before u fix it run the config checker
                  cd ~/magicMirror
                  npm run config:check
                  so u can learn how to fix them
                  • uros76U Offline
                    uros76
                    For those unsuccessfully trying to put the monitor to sleep and wake up with PIR, are you running MM on pi4 with Rapsberian?
                    I never managed to get this combination to work. Instead I did succeed with Lubuntu on pi4.
                    Currently I have working PIR on pi3 with Rapsberian. No issue with this one.
                    Just the pi4 is so different and worse to configure sleep/wakeup.
                    • BKeyportB Offline
                      BKeyport Module Developer
                      Honestly, I would resort to an out-of-MagicMirror experience. I whipped up some python code using GPIOZero to replace MMM-Buttons, for instance…
                      • E Offline
                        @wishmaster270 Can you help me out with this?
                          rafhtl
                          I dont know if this is helpful but I use
                          /usr/bin/vcgencmd display_power 0
                          monitor off
                          /usr/bin/vcgencmd display_power 1
                          monitor on
                          works flawlessly
                          (ssh in pi and type the commands to try them)
                          r
                          • E Offline
                            elleclouds @rafhtl
                            @rafhtl Can you give me more context on where to input this and where it should go?
                              rafhtl
                              ok
                              if u are using MMM-PIR-Sensor
                              it should already be in the module
                              please try from ssh (you have to log in to the pi) and then type
                              you should first try this to see if monitor responds to command
                              so first log in from a pc to your pi using putty
                              r
                              • E Offline
                                elleclouds @rafhtl
                                @rafhtl I was able to achieve this but my monitor stays off after a while and doesn’t come back on. Earlier in the thread I was suggested to just put the monitor to sleep but the code I used came back with errors. I needed help with those lines.
                                  rafhtl @elleclouds
                                  @elleclouds ok
                                  You need to acces the monitor’s menu
                                  I think I read you dont have a remote?
                                  You need to access the energy saving menu
                                  It musdt be something simple as that
                                  • E Offline
                                    elleclouds @rafhtl
                                    @rafhtl can’t access it. Stripped down the monitor in my build a while ago
                                    • BKeyportB Offline
                                      BKeyport Module Developer @elleclouds
                                      wait, the code comes back with errors?
                                      do us a favor.
                                      DISABLE the pir-sensor module for this test.
                                      SSH into the mirror when you’re gonna be away for a couple hours.
                                      type: vcgencmd display_power 0 - Monitor should shut off.
                                      Go do whatever for a while. Come back,
                                      SSH back into the mirror, and type vcgencmd display_power 1 Monitor should power on.
                                      If the monitor doesn’t power back up, there’s a good chance the monitor isn’t good for your use. If it does, then we need to look at how it’s interfacing with the PIR Sensor module.
                                        sdetweil @BKeyport
                                        @BKeyport commands that work on pi3, do not work on pi4… many struggling with things that worked, but don’t now
                                        BKeyportB 1 Reply Last reply Reply Quote 1
                                        • BKeyportB Offline
                                          @sdetweil True - however these commands do work the same as they did before. (Assuming you’re using the HDMI 0 plug closest to the power supply anyway)
