    PIR sensor to turn monitor off. Nothing works :(
    magic mirro pirpir sensor
    31 Posts 8 Posters 18.1k Views 9 Watching
    • cowboysdudeC Offline
      It won’t get any easier then this…
      https://github.com/cowboysdude/Pir-Sensor
      • E Offline
        elleclouds @wishmaster270
        @wishmaster270 said in PIR sensor to turn monitor off. Nothing works :(:
        @elleclouds Hi, do you see any output of the Gpio module in the log file?
        So I got it working with your tutorial. My only issue now is when the monitor doesn’t have a signal it turns completely off and won’t turn back on unless its unplugged and plugged back in. Is there a way to keep the monitor on, just asleep so that the HDMI signal when signaled, activates the screen?
        • wishmaster270W Offline
          wishmaster270 Module Developer
          it depends on your monitor. Maybe there is an option in the monitor configuration menu.
          If not you can configure the MMM-Screen-Powersave-Notification module to only hide all modules and show the black background instead of turning the hdmi off (hideInsteadShutoff option)
          E 2 Replies Last reply Reply Quote 1
          • E Offline
            @wishmaster270 Since the monitor would stay on… would that have any benefits? I can’t access the menu of the monitor due to taking it apart and not knowing where the button to access the menu is located. Thanks for all the assistance and advice, I appreciate it.
              wishmaster270 Module Developer @elleclouds
              @elleclouds Black causes the display to turn off the backlight which saves energy. But it is surely less effective than switching the display to standby mode.
              E 1 Reply Last reply Reply Quote 1
              • E Offline
                @wishmaster270 I’m using this in the config file but its coming back with an error. What am I doing wrong?
                        module: 'MMM-Screen-Powersave-Notification',
                            delay: 60,
                            hideInsteadShutoff:true,
                  sdetweil @elleclouds
                  @elleclouds said in PIR sensor to turn monitor off. Nothing works :(:
                  please use the markup for code or config info
                  mark the text, and hit the button above the editor </>
                  • E Offline
                    elleclouds @sdetweil
                    @sdetweil Did you change it for me, because it looks in the correct format? Any help with the code?
                      @elleclouds yes I changed it… know nothing about the module sorry
                        @sdetweil well, u have 1 more close brace } then u have opens {
                                    delay: 60,
                                }                  //  ---- what is that guy?
                        before u fix it run the config checker
                        cd ~/magicMirror
                        npm run config:check
                        so u can learn how to fix them
                        • uros76U Offline
                          uros76
                          For those unsuccessfully trying to put the monitor to sleep and wake up with PIR, are you running MM on pi4 with Rapsberian?
                          I never managed to get this combination to work. Instead I did succeed with Lubuntu on pi4.
                          Currently I have working PIR on pi3 with Rapsberian. No issue with this one.
                          Just the pi4 is so different and worse to configure sleep/wakeup.
                          • BKeyportB Offline
                            BKeyport Module Developer
                            Honestly, I would resort to an out-of-MagicMirror experience. I whipped up some python code using GPIOZero to replace MMM-Buttons, for instance…
                            • E Offline
                              @wishmaster270 Can you help me out with this?
                                rafhtl
                                I dont know if this is helpful but I use
                                /usr/bin/vcgencmd display_power 0
                                monitor off
                                /usr/bin/vcgencmd display_power 1
                                monitor on
                                works flawlessly
                                (ssh in pi and type the commands to try them)
                                r
                                • E Offline
                                  elleclouds @rafhtl
                                  @rafhtl Can you give me more context on where to input this and where it should go?
                                    rafhtl
                                    ok
                                    if u are using MMM-PIR-Sensor
                                    it should already be in the module
                                    please try from ssh (you have to log in to the pi) and then type
                                    you should first try this to see if monitor responds to command
                                    so first log in from a pc to your pi using putty
                                    r
                                    • E Offline
                                      elleclouds @rafhtl
                                      @rafhtl I was able to achieve this but my monitor stays off after a while and doesn’t come back on. Earlier in the thread I was suggested to just put the monitor to sleep but the code I used came back with errors. I needed help with those lines.
                                        rafhtl @elleclouds
                                        @elleclouds ok
                                        You need to acces the monitor’s menu
                                        I think I read you dont have a remote?
                                        You need to access the energy saving menu
                                        It musdt be something simple as that
                                        • E Offline
                                          elleclouds @rafhtl
                                          @rafhtl can’t access it. Stripped down the monitor in my build a while ago
                                          • BKeyportB Offline
                                            BKeyport Module Developer @elleclouds
                                            wait, the code comes back with errors?
                                            do us a favor.
                                            DISABLE the pir-sensor module for this test.
                                            SSH into the mirror when you’re gonna be away for a couple hours.
                                            type: vcgencmd display_power 0 - Monitor should shut off.
                                            Go do whatever for a while. Come back,
                                            SSH back into the mirror, and type vcgencmd display_power 1 Monitor should power on.
                                            If the monitor doesn’t power back up, there’s a good chance the monitor isn’t good for your use. If it does, then we need to look at how it’s interfacing with the PIR Sensor module.
