    PIR sensor to turn monitor off. Nothing works :(
    magic mirro pirpir sensor
    31 Posts 8 Posters 19.2k Views 9 Watching
    • E
      elleclouds @wishmaster270
      @wishmaster270 said in PIR sensor to turn monitor off. Nothing works :(:
      @elleclouds Hi, do you see any output of the Gpio module in the log file?
      So I got it working with your tutorial. My only issue now is when the monitor doesn’t have a signal it turns completely off and won’t turn back on unless its unplugged and plugged back in. Is there a way to keep the monitor on, just asleep so that the HDMI signal when signaled, activates the screen?
      • wishmaster270W
        wishmaster270 Module Developer
        it depends on your monitor. Maybe there is an option in the monitor configuration menu.
        If not you can configure the MMM-Screen-Powersave-Notification module to only hide all modules and show the black background instead of turning the hdmi off (hideInsteadShutoff option)
        E 2 Replies Last reply
        • E
          @wishmaster270 Since the monitor would stay on… would that have any benefits? I can’t access the menu of the monitor due to taking it apart and not knowing where the button to access the menu is located. Thanks for all the assistance and advice, I appreciate it.
          wishmaster270W 1 Reply Last reply
          • wishmaster270W
            wishmaster270 Module Developer @elleclouds
            @elleclouds Black causes the display to turn off the backlight which saves energy. But it is surely less effective than switching the display to standby mode.
            E 1 Reply Last reply
            • E
              @wishmaster270 I’m using this in the config file but its coming back with an error. What am I doing wrong?
                      module: 'MMM-Screen-Powersave-Notification',
                          delay: 60,
                          hideInsteadShutoff:true,
                sdetweil @elleclouds
                @elleclouds said in PIR sensor to turn monitor off. Nothing works :(:
                please use the markup for code or config info
                mark the text, and hit the button above the editor </>
                • E
                  elleclouds @sdetweil
                  @sdetweil Did you change it for me, because it looks in the correct format? Any help with the code?
                    @elleclouds yes I changed it… know nothing about the module sorry
                      @sdetweil well, u have 1 more close brace } then u have opens {
                                  delay: 60,
                              }                  //  ---- what is that guy?
                      before u fix it run the config checker
                      cd ~/magicMirror
                      npm run config:check
                      so u can learn how to fix them
                      • uros76U
                        uros76
                        For those unsuccessfully trying to put the monitor to sleep and wake up with PIR, are you running MM on pi4 with Rapsberian?
                        I never managed to get this combination to work. Instead I did succeed with Lubuntu on pi4.
                        Currently I have working PIR on pi3 with Rapsberian. No issue with this one.
                        Just the pi4 is so different and worse to configure sleep/wakeup.
                        • BKeyportB
                          BKeyport Module Developer
                          Honestly, I would resort to an out-of-MagicMirror experience. I whipped up some python code using GPIOZero to replace MMM-Buttons, for instance…
                          • E
                            @wishmaster270 Can you help me out with this?
                              rafhtl
                              I dont know if this is helpful but I use
                              /usr/bin/vcgencmd display_power 0
                              monitor off
                              /usr/bin/vcgencmd display_power 1
                              monitor on
                              works flawlessly
                              (ssh in pi and type the commands to try them)
                              r
                              • E
                                elleclouds @rafhtl
                                @rafhtl Can you give me more context on where to input this and where it should go?
                                  rafhtl
                                  ok
                                  if u are using MMM-PIR-Sensor
                                  it should already be in the module
                                  please try from ssh (you have to log in to the pi) and then type
                                  you should first try this to see if monitor responds to command
                                  so first log in from a pc to your pi using putty
                                  r
                                  • E
                                    elleclouds @rafhtl
                                    @rafhtl I was able to achieve this but my monitor stays off after a while and doesn’t come back on. Earlier in the thread I was suggested to just put the monitor to sleep but the code I used came back with errors. I needed help with those lines.
                                    R 1 Reply Last reply
                                      rafhtl @elleclouds
                                      @elleclouds ok
                                      You need to acces the monitor’s menu
                                      I think I read you dont have a remote?
                                      You need to access the energy saving menu
                                      It musdt be something simple as that
                                      • E
                                        elleclouds @rafhtl
                                        @rafhtl can’t access it. Stripped down the monitor in my build a while ago
                                        BKeyportB 1 Reply Last reply
                                        • BKeyportB
                                          BKeyport Module Developer @elleclouds
                                          wait, the code comes back with errors?
                                          do us a favor.
                                          DISABLE the pir-sensor module for this test.
                                          SSH into the mirror when you’re gonna be away for a couple hours.
                                          type: vcgencmd display_power 0 - Monitor should shut off.
                                          Go do whatever for a while. Come back,
                                          SSH back into the mirror, and type vcgencmd display_power 1 Monitor should power on.
                                          If the monitor doesn’t power back up, there’s a good chance the monitor isn’t good for your use. If it does, then we need to look at how it’s interfacing with the PIR Sensor module.
                                            sdetweil @BKeyport
                                            @BKeyport commands that work on pi3, do not work on pi4… many struggling with things that worked, but don’t now
