    PIR sensor to turn monitor off. Nothing works :(
    magic mirro pirpir sensor
    31 Posts 8 Posters 15.8k Views 9 Watching
      sdetweil @wishmaster270
      @wishmaster270 if you used the automated install script,m it will turn screen saver off for you if you reply yes…
      you can also run the screensaver off script part from the installation repo here
      it will figure out what system and set it off appropriately.
      • E Offline
        elleclouds @wishmaster270
        @wishmaster270 I’ll follow yours today and report back.
        • E Offline
          @wishmaster270 got it working with your tutorial but once the monitor goes into sleep mode, after not receiving a signal, it doesn’t turn back on unless I unplug and plug it back in.
          • wishmaster270W Offline
            wishmaster270 Module Developer @elleclouds
            @elleclouds Hi, do you see any output of the Gpio module in the log file?
              satsatt @wishmaster270
              @wishmaster270
              the cmdline.txt was already ok , i really had to install xscreensaver and disable screensaver to solve my problem.
              • cowboysdudeC Offline
                It won’t get any easier then this…
                https://github.com/cowboysdude/Pir-Sensor
                • E Offline
                  @wishmaster270 said in PIR sensor to turn monitor off. Nothing works :(:
                  So I got it working with your tutorial. My only issue now is when the monitor doesn’t have a signal it turns completely off and won’t turn back on unless its unplugged and plugged back in. Is there a way to keep the monitor on, just asleep so that the HDMI signal when signaled, activates the screen?
                    it depends on your monitor. Maybe there is an option in the monitor configuration menu.
                    If not you can configure the MMM-Screen-Powersave-Notification module to only hide all modules and show the black background instead of turning the hdmi off (hideInsteadShutoff option)
                    E 2 Replies Last reply Reply Quote 1
                    • E Offline
                      @wishmaster270 Since the monitor would stay on… would that have any benefits? I can’t access the menu of the monitor due to taking it apart and not knowing where the button to access the menu is located. Thanks for all the assistance and advice, I appreciate it.
                        @elleclouds Black causes the display to turn off the backlight which saves energy. But it is surely less effective than switching the display to standby mode.
                        E 1 Reply Last reply Reply Quote 1
                        • E Offline
                          @wishmaster270 I’m using this in the config file but its coming back with an error. What am I doing wrong?
                                  module: 'MMM-Screen-Powersave-Notification',
                                      delay: 60,
                                      hideInsteadShutoff:true,
                            sdetweil @elleclouds
                            @elleclouds said in PIR sensor to turn monitor off. Nothing works :(:
                            please use the markup for code or config info
                            mark the text, and hit the button above the editor </>
                            • E Offline
                              elleclouds @sdetweil
                              @sdetweil Did you change it for me, because it looks in the correct format? Any help with the code?
                                @elleclouds yes I changed it… know nothing about the module sorry
                                  @sdetweil well, u have 1 more close brace } then u have opens {
                                              delay: 60,
                                          }                  //  ---- what is that guy?
                                  before u fix it run the config checker
                                  cd ~/magicMirror
                                  npm run config:check
                                  so u can learn how to fix them
                                  • uros76U Offline
                                    uros76
                                    For those unsuccessfully trying to put the monitor to sleep and wake up with PIR, are you running MM on pi4 with Rapsberian?
                                    I never managed to get this combination to work. Instead I did succeed with Lubuntu on pi4.
                                    Currently I have working PIR on pi3 with Rapsberian. No issue with this one.
                                    Just the pi4 is so different and worse to configure sleep/wakeup.
                                    • BKeyportB Offline
                                      BKeyport Module Developer
                                      Honestly, I would resort to an out-of-MagicMirror experience. I whipped up some python code using GPIOZero to replace MMM-Buttons, for instance…
                                      • E Offline
                                        @wishmaster270 Can you help me out with this?
                                          rafhtl
                                          I dont know if this is helpful but I use
                                          /usr/bin/vcgencmd display_power 0
                                          monitor off
                                          /usr/bin/vcgencmd display_power 1
                                          monitor on
                                          works flawlessly
                                          (ssh in pi and type the commands to try them)
                                          r
                                          • E Offline
                                            elleclouds @rafhtl
                                            @rafhtl Can you give me more context on where to input this and where it should go?
