    PIR sensor to turn monitor off. Nothing works :(
    magic mirro pirpir sensor
    31 Posts 8 Posters 19.2k Views 9 Watching
    • E
      elleclouds @wishmaster270
      @wishmaster270 I’ll follow yours today and report back.
      • E
        @wishmaster270 got it working with your tutorial but once the monitor goes into sleep mode, after not receiving a signal, it doesn’t turn back on unless I unplug and plug it back in.
        wishmaster270W 1 Reply Last reply
        • wishmaster270W
          wishmaster270 Module Developer @elleclouds
          @elleclouds Hi, do you see any output of the Gpio module in the log file?
          E 1 Reply Last reply
            satsatt @wishmaster270
            @wishmaster270
            the cmdline.txt was already ok , i really had to install xscreensaver and disable screensaver to solve my problem.
            • cowboysdudeC
              It won’t get any easier then this…
              https://github.com/cowboysdude/Pir-Sensor
              • E
                @wishmaster270 said in PIR sensor to turn monitor off. Nothing works :(:
                So I got it working with your tutorial. My only issue now is when the monitor doesn’t have a signal it turns completely off and won’t turn back on unless its unplugged and plugged back in. Is there a way to keep the monitor on, just asleep so that the HDMI signal when signaled, activates the screen?
                • wishmaster270W
                  it depends on your monitor. Maybe there is an option in the monitor configuration menu.
                  If not you can configure the MMM-Screen-Powersave-Notification module to only hide all modules and show the black background instead of turning the hdmi off (hideInsteadShutoff option)
                  E 2 Replies Last reply
                  • E
                    @wishmaster270 Since the monitor would stay on… would that have any benefits? I can’t access the menu of the monitor due to taking it apart and not knowing where the button to access the menu is located. Thanks for all the assistance and advice, I appreciate it.
                    • wishmaster270W
                      @elleclouds Black causes the display to turn off the backlight which saves energy. But it is surely less effective than switching the display to standby mode.
                      • E
                        @wishmaster270 I’m using this in the config file but its coming back with an error. What am I doing wrong?
                                module: 'MMM-Screen-Powersave-Notification',
                                    delay: 60,
                                    hideInsteadShutoff:true,
                          sdetweil @elleclouds
                          @elleclouds said in PIR sensor to turn monitor off. Nothing works :(:
                          please use the markup for code or config info
                          mark the text, and hit the button above the editor </>
                          • E
                            elleclouds @sdetweil
                            @sdetweil Did you change it for me, because it looks in the correct format? Any help with the code?
                              @elleclouds yes I changed it… know nothing about the module sorry
                                @sdetweil well, u have 1 more close brace } then u have opens {
                                            delay: 60,
                                        }                  //  ---- what is that guy?
                                before u fix it run the config checker
                                cd ~/magicMirror
                                npm run config:check
                                so u can learn how to fix them
                                • uros76U
                                  uros76
                                  For those unsuccessfully trying to put the monitor to sleep and wake up with PIR, are you running MM on pi4 with Rapsberian?
                                  I never managed to get this combination to work. Instead I did succeed with Lubuntu on pi4.
                                  Currently I have working PIR on pi3 with Rapsberian. No issue with this one.
                                  Just the pi4 is so different and worse to configure sleep/wakeup.
                                  • BKeyportB
                                    BKeyport Module Developer
                                    Honestly, I would resort to an out-of-MagicMirror experience. I whipped up some python code using GPIOZero to replace MMM-Buttons, for instance…
                                    • E
                                      @wishmaster270 Can you help me out with this?
                                        rafhtl
                                        I dont know if this is helpful but I use
                                        /usr/bin/vcgencmd display_power 0
                                        monitor off
                                        /usr/bin/vcgencmd display_power 1
                                        monitor on
                                        works flawlessly
                                        (ssh in pi and type the commands to try them)
                                        r
                                        • E
                                          elleclouds @rafhtl
                                          @rafhtl Can you give me more context on where to input this and where it should go?
                                            rafhtl
                                            ok
                                            if u are using MMM-PIR-Sensor
                                            it should already be in the module
                                            please try from ssh (you have to log in to the pi) and then type
                                            you should first try this to see if monitor responds to command
                                            so first log in from a pc to your pi using putty
                                            r
