    mmm assistant mk2
    112 Posts 12 Posters 74.5k Views 11 Watching
    • D
      dvbit @sdetweil
      done
      here the output
      pi@MagicMirror:~/MagicMirror/node_modules/electron/dist $ bash -c $(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)
      pi@MagicMirror:~/MagicMirror/node_modules/electron/dist $ ls -la
      total 107496
      drwxr-xr-x 4 pi pi     4096 May 30 12:38 .
      drwxr-xr-x 4 pi pi     4096 May 30 12:38 ..
      -rw-r--r-- 1 pi pi   145945 May 30 12:38 chrome_100_percent.pak
      -rw-r--r-- 1 pi pi   209147 May 30 12:38 chrome_200_percent.pak
      -rwxr-xr-x 1 pi pi  4202140 May 30 12:38 chrome-sandbox
      -rwxr-xr-x 1 pi pi 74664904 May 30 12:38 electron
      -rw-r--r-- 1 pi pi 10410272 May 30 12:38 icudtl.dat
      -rwxr-xr-x 1 pi pi   157372 May 30 12:38 libEGL.so
      -rwxr-xr-x 1 pi pi  1949660 May 30 12:38 libffmpeg.so
      -rwxr-xr-x 1 pi pi  4883208 May 30 12:38 libGLESv2.so
      -rw-r--r-- 1 pi pi     1060 May 30 12:38 LICENSE
      -rw-r--r-- 1 pi pi  3961766 May 30 12:38 LICENSES.chromium.html
      drwxr-xr-x 2 pi pi     4096 May 30 12:38 locales
      -rw-r--r-- 1 pi pi    83237 May 30 12:38 natives_blob.bin
      drwxr-xr-x 2 pi pi     4096 May 30 12:38 resources
      -rw-r--r-- 1 pi pi  8471329 May 30 12:38 resources.pak
      -rw-r--r-- 1 pi pi   275792 May 30 12:38 snapshot_blob.bin
      -rw-r--r-- 1 pi pi   608820 May 30 12:38 v8_context_snapshot.bin
      -rw-r--r-- 1 pi pi        5 May 30 12:38 version
      I mean I did run the bash
      No output. here is the detail listing of the folder.
      I do not see any timestamps changed…
        sdetweil @Guest
        @Bugsounet don’t count on it!!
          A Former User
          not fixed
            sdetweil @dvbit
            @dvbit have to do from the MagicMirror folder… sorry, will fix for future
              A Former User
              cd ~/MagicMirror
              sudo chown root node_modules/electron/dist/chrome-sandbox
              sudo chmod 4755 node_modules/electron/dist/chrome-sandbox
              • D
                dvbit @sdetweil
                done it from MagicMirror folder.
                Can I see any file being changed somewhere?
                I did a ls -la in
                and there seems to be no change there
                  A Former User
                  result must be:
                  -rwsr-xr-x 1 root pi  4204060 mai   20 15:23 chrome-sandbox
                  S D 2 Replies Last reply Reply Quote 0
                    sdetweil @Guest
                    @Bugsounet maybe he doesn’t have sudo rights…
                    must do change to root first
                      sdetweil @dvbit
                      @dvbit it NEEDS the quotes
                      I see I had a typo, try again
                      • D
                        dvbit @sdetweil
                        @sdetweil Thanks I removed the final quote as I was ending up with a prompt
                        will try again now with
                        • D
                          dvbit @Guest
                          @Bugsounet and it is
                          -rwsr-xr-x 1 root pi 4202140 May 30 12:38 chrome-sandbox
                            A Former User
                            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)"
                            result:
                            fixing sandbox permissions
                              A Former User
                              cool ;)
                              let retry now MAgicMirror
                              edit: Fingers crossed
                                A Former User
                                With lost @dvbit in MagicMirror and GoogleAssistant ! :crazy_face:
                                • D
                                  dvbit
                                  S*t I was sent away from the leaving room where I have the mirror by the cleaning lady :-)
                                  Cannot interact with it for a couple of hours.
                                  Still hanging after query.
                                  I am uploading a video to Google drive of an interaction.
                                  It is as if the plugin was not receiving the feedback of response given.
                                  Keeps spinning
                                  • D
                                    dvbit @Guest
                                    @Bugsounet :-D
                                    • D
                                      dvbit
                                      @Bugsounet I will ask your advice on a simple js helper plugin for the C kinect gesture proggie I wrote. It would be nice to integrate it in a2d plugin
                                      • D
                                        dvbit @dvbit
                                        @Bugsounet @sdetweil https://drive.google.com/file/d/1mFsoz7ozNJ8Lc0-774D56SGqROIo3CP_/view?usp=drivesdk
                                        eheh jumping from a pc (cleaning lady chased me away(, to another to a phone (discharged), to another PC.
                                        the short clip above is the MM started .
                                        I ask what time is it in italian
                                        answer is retrieved
                                        display but no audio
                                        then keeps spinning
                                        If I refresh through vnc, spinning goes away (I haev not tried another invocation)
                                          A Former User
                                          1. yes why not but i have Kinect for testing
                                          2. i see your video, but i see something weird …
                                            What is the windows in the top of the video ?
                                          ChrisC 1 Reply Last reply Reply Quote 0
                                          • D
                                            dvbit
                                            1. If I find a good proposal on ebay I can buy you one . After all you are doing for the community if you like it’s a minimum. Should I look for France as delivery? It will work just with a Raspberry 4 however (below are not powerful enough). I really would like to be able to program in JS . I am dreaming of a play plugin like this https://www.youtube.com/watch?v=KLOB-T1mgdY . My son is waiting for it since he saw the video :-D. Ok I confess: I would like too
                                            2. Do you refer to the chromium top? I am testing so I do launch it not in full screen (But I tried in full screen too)
                                            • 6
                                            • 4 / 6
