    mmm assistant mk2
    112 Posts 12 Posters 70.0k Views 11 Watching
      JohnBachini
      @Bugsounet
      HI, Amazing work with GoogleAssist, it seems to be more responsive and accurate than AssistantMK2.
      Have an issue with the display of the googleAssistant banner. My Mirror is full screen, ie in custom.css i have :-
       body {
           margin: 0px;
           position: absolute;
           height: 100%;
           width: 100%;
      Which i hope is correct, im struggling with css side of things !! :-)
      But when the banner appears i have this issue,
      As top of banner is missing and width
      I looked at GoogleAssistant.css, but couldnt work out what needs to change.
      • ? Offline
        [[global:former-user]]
        @JohnBachini :
          module: "MMM-GoogleAssistant",
          position: "fullscreen_above",
        don’t work with this position ?
        Edit : Ah yes don’t work
          JohnBachini @Guest
          @Bugsounet
          Yes i have it set to fullscreen_above, i confirmed it works fine if i remove the css code i posted above
          • ? Offline
            @JohnBachini: I don’t find too :face_with_tears_of_joy: :face_with_tears_of_joy: :face_screaming_in_fear:
            I got lost in my css code !!!
              JohnBachini @Guest
              @Bugsounet :-) So custom.css overides main.css , so does GoogleAssistant.css overide all ?
                sdetweil @JohnBachini
                @JohnBachini main, then modules, then custom.css last
                • ? Offline
                  nop it not override all.
                  Actually I’m working arround a new rending
                  real time Transcription will be in next update in popup (like the response)
                  and it will correct this problem ;)
                  So wait a few days :)
                  results:
                  New animation (response screen)
                  new animation (transcription)
                  More reactive
                    JohnBachini @Guest
                    @Bugsounet Great, Ill wait till then. Thanks
                    ? 2 Replies Last reply Reply Quote 0
                    • ? Offline
                      [[global:former-user]] @JohnBachini
                      @JohnBachini : fixed ;)
                      wait next release :p
                        mcretu @dvbit
                        @dvbit Hi, did you managed to figure it out? I have the same issue. Youtube video audio works fine, I even hear the chime when the assistant is waked up.
                        • ? Offline
                          @JohnBachini : if you want, we can do some test
                            dvbit @mcretu
                            @mcretu Hi . Lost in the Post.
                            I think you refer to youtube not being displayed.
                            If that is the case, as @Bugsounet keeps saying (he said it to me about this…), red the wiki. It’s all there.
                            you need to change the config.js in config as follows:
                            https://github.com/bugsounet/MMM-Assistant2Display/wiki/Configuration
                            Assistant2Display need electron special configuration for web link displaying and Youtube functionality
                            start of the config.js configuration file
                            var config = {
                              address: "localhost",
                              electronOptions: {
                                webPreferences: {
                                  webviewTag: true
                              port: 8080,
                            address should be localhost for playing YouTube video
                            electronOptions is need if you want to display the link and Cast module
                            • 6
                            • 6 / 6
