    MMM-Tado wrong units
    28 Posts 3 Posters 9.3k Views 4 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @sdetweil
      @sdetweil no luck…sorry, I have changed 4x this into self
      but I am not sure with the line 26
       * Created by Wouter Eekhout on 06/01/2017.
      Module.register("MMM-Tado", {
          // Default module config.
          defaults: {
              username: '',
              password: '',
              updateInterval: 300000,
          tadoMe: {},
          tadoHomes: [],
          getStyles: function () {
              return [
                  this.file('css/MMM-Tado.css'),
          start: function () {
              if (this.config.updateInterval < this.defaults.updateInterval){
                  this.config.updateInterval = this.defaults.updateInterval;
              this.config.units = self.config.units;
              this.sendSocketNotification('CONFIG', this.config);
          // Override dom generator.
          getDom: function () {
              let self = this;
              let wrapper = document.createElement("div");
              wrapper.className = "tado-info";
              this.tadoHomes.forEach(home => {
                  let homeWrapper = document.createElement("div");
                  homeWrapper.className = "tado-home";
                  let logoWrapper = document.createElement("i");
                  logoWrapper.className = "tado-icon-tado_logo tado-logo";
                  homeWrapper.appendChild(logoWrapper);
                  let tableWrapper = document.createElement("table");
                  tableWrapper.className = "tado-table small";
                  home.zones.forEach(zone => {
                      let rowWrapper = document.createElement("tr");
                      if (zone.type === "HOT_WATER") {
                          let firstTableDataWrapper = document.createElement("td");
                          firstTableDataWrapper.className = "tado-table-name";
                          let zoneNameWrapper = document.createElement("span");
                          zoneNameWrapper.innerText = zone.name;
                          firstTableDataWrapper.appendChild(zoneNameWrapper);
                          rowWrapper.appendChild(firstTableDataWrapper);
                          let secondTableDateWrapper = document.createElement("td");
                          secondTableDateWrapper.className = "tado-table-data";
                          let temperatureWrapper = document.createElement("span");
                          let temperatureIconWrapper = document.createElement("i");
                          temperatureIconWrapper.className = "fa fa-thermometer-half";
                          temperatureWrapper.appendChild(temperatureIconWrapper);
                          if (zone.state.setting.temperature == null) {
                              var temperatureTextWrapper = document.createTextNode(zone.state.setting.power);
                          } else {
                              if (self.config.units === "metric") {
                                  var temperatureTextWrapper = document.createTextNode(zone.state.setting.temperature.celsius + "°");
                              } else {
                                  var temperatureTextWrapper = document.createTextNode(zone.state.setting.temperature.fahrenheit + "°");
                          temperatureWrapper.appendChild(temperatureTextWrapper);
                          secondTableDateWrapper.appendChild(temperatureWrapper);
                          rowWrapper.appendChild(secondTableDateWrapper);
                      else if (zone.type === "HEATING") {
                          //current temperature
                          temperatureWrapper.className = "bright";
                              var temperatureTextWrapper = document.createTextNode(zone.state.sensorDataPoints.insideTemperature.celsius + "°");
                          } else {
                              var temperatureTextWrapper = document.createTextNode(zone.state.sensorDataPoints.insideTemperature.fahrenheit + "°");
                          if (zone.state.activityDataPoints.heatingPower.percentage > 0) {
                              //The zone is heating
                              let heatingWrapper = document.createElement("i");
                              heatingWrapper.className = "fa fa-fire bright";
                              temperatureWrapper.appendChild(heatingWrapper);
                          //target temperature
                          let temperatureTargetWrapper = document.createElement("span");
                          temperatureTargetWrapper.className = "xsmall";
                          let temperatureTargetIconWrapper = document.createElement("i");
                          temperatureTargetIconWrapper.className = "fa fa-thermometer-half";
                          temperatureTargetWrapper.appendChild(temperatureTargetIconWrapper);
                              var temperatureTargetTextWrapper = document.createTextNode(zone.state.setting.power);
                          } else {
                                  var temperatureTargetTextWrapper = document.createTextNode(zone.state.setting.temperature.celsius + "°");
                              } else {
                                  var temperatureTargetTextWrapper = document.createTextNode(zone.state.setting.temperature.fahrenheit + "°");
                          temperatureTargetWrapper.appendChild(temperatureTargetTextWrapper);
                          secondTableDateWrapper.appendChild(temperatureTargetWrapper);
                          let breakLine = document.createElement("br");
                          secondTableDateWrapper.appendChild(breakLine);
                          let humidityWrapper = document.createElement("span");
                          let humidityIconWrapper = document.createElement("i");
                          humidityIconWrapper.className = "fa fa-tint";
                          humidityWrapper.appendChild(humidityIconWrapper);
                          let humidityTextWrapper = document.createTextNode(zone.state.sensorDataPoints.humidity.percentage + "%");
                          humidityWrapper.appendChild(humidityTextWrapper);
                          secondTableDateWrapper.appendChild(humidityWrapper);
                      else if (zone.type === "AIR_CONDITIONING") {
                          } else {
                          if (zone.state.setting.mode === "HEAT") {
                          else if (zone.state.setting.mode === "COOL") {
                              //The zone is cooling
                              let coolingWrapper = document.createElement("i");
                              coolingWrapper.className = "fa fa-snowflake bright";
                              temperatureWrapper.appendChild(coolingWrapper);
                          } else {
                              } else {
                      } else {
                          //don't add it
                          return;
                      tableWrapper.appendChild(rowWrapper);
                  homeWrapper.appendChild(tableWrapper);
                  wrapper.appendChild(homeWrapper);
              return wrapper;
              if (notification === 'NEW_DATA') {
                  this.tadoMe = payload.tadoMe;
                  this.tadoHomes = payload.tadoHomes;
                  this.updateDom();
        sdetweil @Stoffbeuteluwe
        @Stoffbeuteluwe weird… i’ll be back on in about 6 hours, do you know how to use the debugger?
        ctrl-shift-i on teh keyboard, select the sources tab, navigate the left tree to find the module and filename, click
        shows in middle window
        scroll down to one of the if (self.config.units lines (make sure u have that type unit in the tado data)
        click the number on the start of the line, it should turn blue
        hit refresh
        the code will stop there
        mouse over the self and a box will pop up showing what self points to, then config
        same… units should say metric
          @Stoffbeuteluwe said in MMM-Tado wrong units:
          nothing… it will copy the system units to the module units info
          • W Offline
            WouterEekhout
            @Stoffbeuteluwe I’ve updated the code with the suggestions of @sdetweil . For now I put it into a separate branch. If this solutions works for you, I will push it to the master branch.
            Execute the following:
            git pull
            git checkout incorrect_pointer_in_getdom
            Will you let us know if this solved your problem?
              Stoffbeuteluwe Project Sponsor @WouterEekhout
              @WouterEekhout sorry does not work
              Last login: Sat Jun  6 20:48:53 on ttys000
              patrickhahn@Patricks-Mini ~ % cd ~/MagicMirror/modules
              patrickhahn@Patricks-Mini modules % git clone https://github.com/WouterEekhout/MMM-Tado
              Cloning into 'MMM-Tado'...
              remote: Enumerating objects: 47, done.
              remote: Counting objects: 100% (47/47), done.
              remote: Compressing objects: 100% (39/39), done.
              remote: Total 152 (delta 22), reused 23 (delta 6), pack-reused 105
              Receiving objects: 100% (152/152), 841.64 KiB | 973.00 KiB/s, done.
              Resolving deltas: 100% (50/50), done.
              patrickhahn@Patricks-Mini modules % cd MMM-Tado
              patrickhahn@Patricks-Mini MMM-Tado % npm install
              npm WARN deprecated simple-oauth2@2.5.2: simple-oauth2 v2 is no longer supported. Please upgrade to v3 for further support
              npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
              npm WARN deprecated wreck@14.2.0: This module has moved and is now available at @hapi/wreck. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
              npm WARN deprecated boom@7.3.0: This module has moved and is now available at @hapi/boom. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
              npm WARN deprecated bourne@1.1.2: This module has moved and is now available at @hapi/bourne. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
              npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
              npm notice created a lockfile as package-lock.json. You should commit this file.
              added 42 packages from 446 contributors and audited 42 packages in 5.628s
              1 package is looking for funding
                run `npm fund` for details
              found 1 low severity vulnerability
                run `npm audit fix` to fix them, or `npm audit` for details
              patrickhahn@Patricks-Mini MMM-Tado % git pull
              Already up to date.
              Branch 'incorrect_pointer_in_getdom' set up to track remote branch 'incorrect_pointer_in_getdom' from 'origin'.
              Switched to a new branch 'incorrect_pointer_in_getdom'
                @sdetweil it says undefined
                • W Offline
                  WouterEekhout @Stoffbeuteluwe
                  @Stoffbeuteluwe I’m assuming self.config.units is undefined on line 26. If that is the case then MagicMirror is having trouble reading in your global units configuration. Are you experiencing the same problem with other modules?
                  For your information, I am from the Netherlands and I also use the metric units. I tried your configurations settings from the following and it works for me.
                  @sdetweil Hello, after module update same problem
                  and your fix don’t work anymore…can you help me again?
                  If you just want to get the module running and forget about problem replace line 26 to the following:
                  this.config.units = 'metric';
                  Be sure you are on the master branch before replacing.
                    @WouterEekhout Hi my other modules work but this is not working and I don’t know why :thinking_face:
                    I will try to change the line 26…thanks for you help
