    MagicMirror v2.1.0 Update error
    31 Posts 12 Posters 28.2k Views 12 Watching
    • O Offline
      ostfilinchen
      At the Moment it works. I have update and dist-upgrade the rpi. Thanks for helping.
      • T Offline
        teandryk
        Hi, after update
        pi@raspberrypi:~ sudo git pull
        my MM does not start anymore, so i tried from terminal and getting this error:
        *pi@raspberrypi:~ $ ./mm.sh
        >magicmirror@2.1.0 start /home/pi/MagicMirror
        >electron js/electron.js
        App threw an error during load
        Error: Cannot find module ‘express-ipfilter’
        at Module._resolveFilename (module.js:455:15)
        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron-prebuilt/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
        at Function.Module._load (module.js:403:25)
        at Module.require (module.js:483:17)
        at require (internal/module.js:20:19)
        at Object. (/home/pi/MagicMirror/js/server.js:13:16)
        at Module._compile (module.js:556:32)
        at Object.Module._extensions…js (module.js:565:10)
        at Module.load (module.js:473:32)
        at tryModuleLoad (module.js:432:12)
        A JavaScript error occurred in the main process
        Uncaught Exception:
        yawnsY 1 Reply Last reply Reply Quote 0
        • yawnsY Offline
          yawns Moderator @teandryk
          @teandryk
          Please run npm install in the main MagicMirror folder
          • O Offline
            ostfilinchen
            I think, i Set up a New raspian with New Installation of mm. This update was Not a good idea…
            • T Offline
              teandryk @yawns
              @yawns I did and thats what i got now :)
              pi@raspberrypi:~/MagicMirror $ npm install
              \> electron@1.4.13 postinstall /home/pi/MagicMirror/node_modules/electron
              \> node install.js
              \> electron-prebuilt@1.4.13 postinstall /home/pi/MagicMirror/node_modules/electron-prebuilt
              \> node install.js
              npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/esrecurse requires estraverse@'~4.1.0' but will load
              npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/estraverse,
              npm WARN unmet dependency which is version 4.2.0
              npm ERR! Linux 4.4.21-v7+
              npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
              npm ERR! node v4.3.2
              npm ERR! npm  v2.14.12
              npm ERR! code EPEERINVALID
              npm ERR! peerinvalid The package grunt@1.0.1 does not satisfy its siblings' peerDependencies requirements!
              npm ERR! peerinvalid Peer grunt-yamllint@0.2.0 wants grunt@~0.4.0
              npm ERR! peerinvalid Peer grunt-eslint@19.0.0 wants grunt@>=0.4.0
                arosenhave @teandryk
                @teandryk I too had this problem earlier today. I solved it by navigating to /node_modules/electron
                and run “sudo node install.js”. Have some patience - it took a loooong time. I ended up leaving it and went to do something else. When I got back half an hour later it was done and the mirror was running.
                Hope it helps. Good luck :-)
                T P 2 Replies Last reply Reply Quote 1
                • T Offline
                  teandryk @arosenhave
                  @arosenhave
                  It worked and even didnt took a split sec :)
                  thanks !!!
                  • P Offline
                    poutr @arosenhave
                    @teandryk @arosenhave Hello, I have run into the same issue wanting to install the magic mirror² framework on my windows laptop to develop a module. Running sudo node install.js from my powershell or from a node.js prompt did nothing to solve my problem. As far as I gathered, the issue come from this 2 not-updated packages that MagicMiror is using : https://github.com/geedew/grunt-yamllint/blob/master/package.json and the one called grunt-eslint. Both did not update their package.json (and maybe code) as the grunt developpers asked : http://gruntjs.com/blog/2016-04-04-grunt-1.0.0-released#peer-dependencies . Here is a topic on a forum surrounding that updating issue. However I am uncertain about what to do right now to solve it since the raspeberry pi environment and a laptop are not similar.
                    tosti007T 1 Reply Last reply Reply Quote 0
                    • tosti007T Offline
                      tosti007 Module Developer @poutr
                      @poutr if you are running on Windows just type npm install in the main folder and you should be good to go (assuming you have node.js installed on your pc)
                      If there is anything don't hesitate to contact me!
                      ProfileSwitcher, TouchNotifications
                      • P Offline
                        poutr @tosti007
                        @tosti007 Well, it’s the
                        npm install
                        that failed. But updating npm solved the issue since I had npm version 2.x.x (I think, not sure since I did not save the command prompt before the update). From the grunt dev page, higher npm version only raises warning for lower version number requirements and does nothing for
                        "grunt" : ">=version_number"
                        Which is good.
                        Forgot to report that the solution there worked when I tested https://forum.magicmirror.builders/topic/971/dependency-problems/6
                        Thank you for responding promptly to my post !
                        • tosti007T Offline
                          @poutr alright good to hear that’s the problem is solved!
