    MagicMirror v2.1.0 Update error
    31 Posts 12 Posters 29.9k Views 12 Watching
      bhepler Module Developer @Steff
      @Steff Remove the " from around the array names (morning, afternoon, evening).
      compliments:
                   morning : [
                        "Du siehst aber gut aus heute !",
                        "Gut geschlafen ?",
                        "Moin, Moin...."
                    afternoon : [
                       "Ab Fussball spielen !",
                       "Lass uns auf den Abend vorbereiten....",
                        "Musik hören ?"
                    evening : [
                        "Einen Cocktail ?",
                        "Wow, Du bist aber heiss heute...",
                        "Wollen wir heute abend weggehen ?"
        Steff
        @bhepler
        Thanks for your hint.
        I know the doc does not show them. However I understood the documentation that I will need them for an external file. So I wanted to be prepared for the move to an external file. I tested it with them inside the config.js file and it worked. Do you see any specific reason to remove them ?
        B 1 Reply Last reply
          Steff
          I did try to configure an external compliments.json file, however it seems that it is not interpreted, since I do get again the default compliments.
          The file is located within the config directory.
          My configuration:
          { module: 'compliments', position: 'lower_third', config: { remoteFile: 'compliments.json' } },
          Do you have a hint what might be wrong ?
            @Steff Due to my own incompetence when dealing with javascript, the external file needs to have quotes around the array names. If you are expanding the arrays within the config.js file, then you must remove the quotes from around the names.
            So this would work in the config.js file:
            evening : [
                    "Einen Cocktail ?",
            and this should work in the external compliments file:
            "evening" : [
                    "Einen Cocktail ?",
            It’s a bug. But I’m a Java programmer, not a Javascript programmer. I don’t know how to fix it.
            • O
              ostfilinchen
              Hi all,
              After update my MM and want to open the mm via http://ip:8080 i get a blank Black screen. It comes on Win10 and also Android with Chrome.
              The Majorfailure is, the rpi stop working. So i can only disconnect the power and connect again.
              Has anybody else this issue?
              Regals
              Daniel
              L 1 Reply Last reply
              • L
                lolobyte @ostfilinchen
                @ostfilinchen
                No, not such a major issue with the pi.
                Can you access your pi with ssh?
                Take a look at
                https://forum.magicmirror.builders/topic/1326/ipwhitelist-howto/
                • O
                  ostfilinchen
                  At the Moment it works. I have update and dist-upgrade the rpi. Thanks for helping.
                  • T
                    teandryk
                    Hi, after update
                    pi@raspberrypi:~ sudo git pull
                    my MM does not start anymore, so i tried from terminal and getting this error:
                    *pi@raspberrypi:~ $ ./mm.sh
                    >magicmirror@2.1.0 start /home/pi/MagicMirror
                    >electron js/electron.js
                    App threw an error during load
                    Error: Cannot find module ‘express-ipfilter’
                    at Module._resolveFilename (module.js:455:15)
                    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron-prebuilt/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                    at Function.Module._load (module.js:403:25)
                    at Module.require (module.js:483:17)
                    at require (internal/module.js:20:19)
                    at Object. (/home/pi/MagicMirror/js/server.js:13:16)
                    at Module._compile (module.js:556:32)
                    at Object.Module._extensions…js (module.js:565:10)
                    at Module.load (module.js:473:32)
                    at tryModuleLoad (module.js:432:12)
                    A JavaScript error occurred in the main process
                    Uncaught Exception:
                    Y 1 Reply Last reply
                    • Y
                      yawns Moderator @teandryk
                      @teandryk
                      Please run npm install in the main MagicMirror folder
                      T 1 Reply Last reply
                      • O
                        ostfilinchen
                        I think, i Set up a New raspian with New Installation of mm. This update was Not a good idea…
                        • T
                          teandryk @yawns
                          @yawns I did and thats what i got now :)
                          pi@raspberrypi:~/MagicMirror $ npm install
                          \> electron@1.4.13 postinstall /home/pi/MagicMirror/node_modules/electron
                          \> node install.js
                          \> electron-prebuilt@1.4.13 postinstall /home/pi/MagicMirror/node_modules/electron-prebuilt
                          \> node install.js
                          npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/esrecurse requires estraverse@'~4.1.0' but will load
                          npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/estraverse,
                          npm WARN unmet dependency which is version 4.2.0
                          npm ERR! Linux 4.4.21-v7+
                          npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                          npm ERR! node v4.3.2
                          npm ERR! npm  v2.14.12
                          npm ERR! code EPEERINVALID
                          npm ERR! peerinvalid The package grunt@1.0.1 does not satisfy its siblings' peerDependencies requirements!
                          npm ERR! peerinvalid Peer grunt-yamllint@0.2.0 wants grunt@~0.4.0
                          npm ERR! peerinvalid Peer grunt-eslint@19.0.0 wants grunt@>=0.4.0
                          npm ERR!     /home/pi/MagicMirror/npm-debug.log
                          A 1 Reply Last reply
                          • A
                            arosenhave @teandryk
                            @teandryk I too had this problem earlier today. I solved it by navigating to /node_modules/electron
                            and run “sudo node install.js”. Have some patience - it took a loooong time. I ended up leaving it and went to do something else. When I got back half an hour later it was done and the mirror was running.
                            Hope it helps. Good luck :-)
                            T P 2 Replies Last reply
                            • T
                              teandryk @arosenhave
                              @arosenhave
                              It worked and even didnt took a split sec :)
                              thanks !!!
                                poutr @arosenhave
                                @teandryk @arosenhave Hello, I have run into the same issue wanting to install the magic mirror² framework on my windows laptop to develop a module. Running sudo node install.js from my powershell or from a node.js prompt did nothing to solve my problem. As far as I gathered, the issue come from this 2 not-updated packages that MagicMiror is using : https://github.com/geedew/grunt-yamllint/blob/master/package.json and the one called grunt-eslint. Both did not update their package.json (and maybe code) as the grunt developpers asked : http://gruntjs.com/blog/2016-04-04-grunt-1.0.0-released#peer-dependencies . Here is a topic on a forum surrounding that updating issue. However I am uncertain about what to do right now to solve it since the raspeberry pi environment and a laptop are not similar.
                                • T
                                  tosti007 Module Developer @poutr
                                  @poutr if you are running on Windows just type npm install in the main folder and you should be good to go (assuming you have node.js installed on your pc)
                                  If there is anything don’t hesitate to contact me!
                                  ProfileSwitcher, TouchNotifications
                                  P 1 Reply Last reply
                                    poutr @tosti007
                                    @tosti007 Well, it’s the
                                    npm install
                                    that failed. But updating npm solved the issue since I had npm version 2.x.x (I think, not sure since I did not save the command prompt before the update). From the grunt dev page, higher npm version only raises warning for lower version number requirements and does nothing for
                                    "grunt" : ">=version_number"
                                    Which is good.
                                    Forgot to report that the solution there worked when I tested https://forum.magicmirror.builders/topic/971/dependency-problems/6
                                    Thank you for responding promptly to my post !
                                    • T
                                      @poutr alright good to hear that’s the problem is solved!
