    how to make just 1 module bigger?
    6 Posts 3 Posters 1.5k Views 3 Watching
      aarish
      hey, I was using the default weather module and I changed it to only pull up 6 things from my calendar. I was able to successfully fo that but now I want the calendar module to be a lot bigger but keep the size of everything else the same. how would I be able to do that?
      • lavolp3L Offline
        lavolp3 Module Developer @aarish
        @aarish you can reference every module as a css element using its name as class.
        in this case it is .calendar
        in custom.css
        .calendar {
          width: 500px;
          height: xxxpx;
        But note that all other modules are automatically set with width: 100% so will adept their width…
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          aarish @lavolp3
          @lavolp3 Thank you so much, this helps a lot!
            aarish
            Hello, I am using Bugsonet’s MMM-Weather module and wanted to make the data bigger. I wrote the same thing as above in custom.css besides changing .calendar to .MMM-Weather. I noticed that when I changed the width it made the module move left and right. I also noticed that changing the Height value did not effect anything. Any idea how to make it bigger?
            • P Offline
              pakal41
              hello, I made it like this
              • MMM-Weather custom
              .MMM-Weather .wrapper.tiled .forecast-container .forecast-item .time,
              .MMM-Weather .wrapper.tiled .forecast-container .forecast-item .day-name {
              font-size: 22px !important;
              .MMM-Weather .wrapper.tiled .forecast-container .forecast-item .temperature,
              .MMM-Weather .wrapper.tiled .forecast-container .forecast-item .temperature-container {
              font-size: 26px !important;
              .MMM-Weather .wrapper.tiled .forecast-container .forecast-item .precipitation-container,
              .MMM-Weather .wrapper.tiled .forecast-container .forecast-item .wind-container {
              .MMM-Weather .wrapper.table .forecast-container {
              .MMM-Weather .wrapper.table .forecast-container .forecast-item > span,
              .MMM-Weather .wrapper.table .forecast-container .header-row > span {
              font-size: 17px !important;
              .MMM-Weather .wrapper.table .forecast-container .header-row .temperature-header {
              .MMM-Weather .current-conditions-wrapper .icon {
              width: 180px;
              height: 180px;
              .MMM-Weather .inline-icon,
              .MMM-Weather .wrapper.tiled .forecast-container .forecast-item .inline-icon {
              width:45px;
              height: 45px;
              .MMM-Weather .extra-current-conditions-wrapper .feels-sun-container .inline-icon {
              width: 26px;
              height: 26px;
              .MMM-Weather .wrapper.tiled .forecast-container .forecast-item .forecast-icon {
              width: 80px;
              height: 80px;
              .MMM-Weather .wrapper.table .forecast-container .forecast-item .forecast-icon {
              width: 50px;
              height: 50px;
                aarish
                This is amazing, thank you so much!
