    can't run "npm run start"
    25 Posts 3 Posters 7.8k Views 3 Watching
      jefftse @sdetweil
      just did that and the error is below
      magicmirror@2.11.0 start /home/jeff/MagicMirror
      electron js/electron.js
      No protocol specified
      (electron:32527): Gtk-WARNING **: 21:53:58.634: cannot open display: :0.0
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.11.0 start: electron js/electron.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.11.0 start script.
      npm ERR! /home/jeff/.npm/_logs/2020-06-24T01_53_58_663Z-debug.log
        sdetweil @jefftse
        @jefftse still trying to open display 0
        what is the vnc display number? do
        env | grep -i display
          jefftse @sdetweil
          XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
          XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
          DISPLAY=:0.0
            sdetweil @jefftse
            @jefftse do u have a real display
              jefftse @sdetweil
              @sdetweil yes, in fact, i had it all working yesterday till I accident broken my sd card. I had to rebuild everything today.
                sdetweil @jefftse
                @jefftse did u use my install script? can’t understand why u are having trouble
                  jefftse @sdetweil
                  @sdetweil sure did. I had to create an user to run your script since it wouldn’t allow me to do in root
                    sdetweil @jefftse
                    @jefftse not supposed to be root
                    are u trying to run as root?
                    can’t do that
                      jefftse @sdetweil
                      @sdetweil correct, and I created an user for the install. the install went fine. I just can’t run it!
                        sdetweil @jefftse
                        @jefftse I don’t understand created a user.
                        raspian installs and starts with user pi
                        • 2 / 3
