    No numbers in analog watch face
    33 Posts 11 Posters 15.0k Views 9 Watching
    • ? Offline
      [[global:former-user]]
      This post is deleted!
      • I Offline
        Ice-cream @Guest
        @hango Thanks Hango.
        1. I have updated the code (still not working presumably because of point 3 below)
        2. I don’t know where to download the old SVG faces - when I installed MM there was/is a folder full of SVG clock faces
        3. Please don’t laugh - I don’t know how to create/use a custom css folder - I plan to learn this soon! X
        • ? Offline
            sdetweil @Guest
            @hango if one uses my installer script, I create the empty custom.css as part of the install.
            • ? Offline
              [[global:former-user]] @sdetweil
              • I Offline
                Ice-cream
                1. Haha thanks guys - that worked!
                Very good point in regard to ‘‘how you update the code if you don’t know to create custom.css?’’- I previouly edited the config.js, clock.js and clock_styles.css > I created a really pretty analog clock with the centre, second hand, minute and hour each with different colours.
                1. For some reason I thought that a custom.css was really technical but I easily created this from my terminal.
                For what it’s worth, I’ve connected to a few APIs and have configued these in the main confg folder and the css’s.
                Going forward I’m going to play with customising the default modules (well the ones which I haven’t hidden in the main config file) in the custom CSS.
                Thanks again Xx
                  sdetweil @Ice-cream
                  @Ice-cream do not edit the default files.
                  config in config.js and css in custom.css
                  • T Offline
                    TomBrown @sdetweil
                    @sdetweil said in No numbers in analog watch face:
                    @lavolp3 interesting, my script tries to minimize space used, so only downloads the master branch
                    to down develop do
                    git fetch origin develop:develop
                    git checkout develop
                    I am probably doing something wrong.
                    I typed in “git fetch origin develop:develop” and then “git checkout develop” and got an error.
                    error: Your local changes to the following files would be overwritten by checkout:
                    	modules/default/clock/clock.js
                    	modules/default/weatherforecast/weatherforecast.js
                    	package-lock.json
                    Please commit your changes or stash them before you switch branches.
                    Aborting
                      sdetweil @TomBrown
                      @TomBrown do u remember why you edited the clock and weatherforecast files?
                      • T Offline
                        TomBrown
                        I edited the clock.js to change the default clock from digital to analog.
                        Not sure about the weatherforcast.js though. I did make a copy of the files before editing anything. Could I just rename the backup file to the regular one and try the update again?
                          sdetweil @TomBrown
                          @TomBrown yes u can copy the originals back.
                          never edit them, use the config.js to change the config.
                          git diff > somefile
                          will show u the changes into somefile
                          u can erase the package-lock.json file
                          • T Offline
                            TomBrown
                            OK. That did it! Ran the update, now at version 2.13.0-develop
                            Changed the clock back to analog with face-010 and it is looking like I want it!
                            Thanks @sdetweil !!
                            • H Offline
                              hayman
                              hello,
                              ive been using Face5 for a while pretty nice ,is there a way to change it to arabic numbers ?
                              thanks
