    pm2 Autostart invert issue
    Scheduled Pinned Locked Moved Solved Bug Hunt
    32 Posts 4 Posters 14.8k Views 4 Watching
    • EthyxE
      Ethyx
      Hello,
      This is my first mm project. I used pm2 to autostart my magicmirror and everything is going fine. but the mirror i made can only be put up when the screen is inverted. so i added that to my mm.sh file. Once it boots up, the screen becomes regualr and i have to vnc to it and do ^Q in order to exit the mm. it opens up a short while after and thats when its inverted.
        sdetweil @Ethyx
        @Ethyx are u sure u don’t have two MM’s starting at boot?
        see
        pm2 status
        • EthyxE
          Ethyx
          Yeah I don’t have 2 mm’s starting up at boot.
          • EthyxE
            Ethyx
            here’s my mm.sh file:
            cd./ MagicMirror
            DISPLAY=:0 npm start
            DISPLAY=:0 xrandr --output HDMI-1 --rotate inverted
              sdetweil @Ethyx
              @Ethyx right u start mm before u change rotation, swap the last two lines
              npm start doesn’t return for the next line until mm shuts down
              • EthyxE
                Ethyx
                I did that already but the issue still persists.
                cd./ MagicMirror
                  sdetweil @Ethyx
                  @Ethyx what happens when u execute mm.sh manually. not using pm2?
                  does xrandr return immediately
                  EthyxE 1 Reply Last reply
                  • EthyxE
                    Ethyx @sdetweil
                    @sdetweil yes, it does
                      sdetweil @Ethyx
                      @Ethyx with the screen flipped?
                        @Ethyx I think u can put the screen flip in /boot/config.txt
                        not the xrandr command tho
                        • EthyxE
                          Ethyx
                          how do you do that tho?
                            sdetweil @Ethyx
                            @Ethyx Google is your friend
                            https://www.raspberrypi-spy.co.uk/2017/11/how-to-rotate-the-raspberry-pi-display-output/
                            EthyxE 2 Replies Last reply
                            • EthyxE
                              Ethyx @sdetweil
                              @sdetweil so true
                              • EthyxE
                                Ethyx @sdetweil
                                @sdetweil the issue still persists
                                  sdetweil @Ethyx
                                  @Ethyx u set the rotation in /boot/config.txt and rebooted and rotation was changed, yes?
                                  the remove xrandr from mm.sh
                                  • EthyxE
                                    Ethyx @sdetweil
                                    @sdetweil ok on it
                                    • EthyxE
                                      Ethyx @sdetweil
                                      @sdetweil this time even when I give ^q, the screen is not inverted as opposed to last time.
                                        sdetweil @Ethyx
                                        @Ethyx so the /boot/config.txt didn’t work. read more
                                        • EthyxE
                                          Ethyx @sdetweil
                                          @sdetweil yep
                                          S EthyxE 2 Replies Last reply
                                            sdetweil @Ethyx
                                            @Ethyx you added
                                            display_rotate=2
                                            to config.txt, right, and saved it
