    LocalTransport-Module and calendar
    10 Posts 4 Posters 5.1k Views 4 Watching
    • T
      tidus5
      Hey anybody know if its possible to use the LocalTransport-Module
      now with the calendar ? maybe adapting it to receive the broadcastEvents ?
      • T
        tosti007 Module Developer
        I don’t really understand what kind of result you are looking for, can you explain it a bit better?
        If there is anything don’t hesitate to contact me!
        ProfileSwitcher, TouchNotifications
        strawberry 3.141S 1 Reply Last reply
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @tosti007
          @tosti007 the calender broadcasts the events, he wants that the localtransport module automatically uses the events with locations and show connections for them in the mirror edit like https://github.com/RedNax67/MMM-TrafficCal does
          T 1 Reply Last reply
          • T
            tosti007 Module Developer @strawberry 3.141
            @strawberry-3.141 ah alright, I think that would definitely doable, but wouldn’t it be better for the maker of that module to implement it instead of making a third part module or guide explaining how to change the code?
            Y 1 Reply Last reply
            • Y
              yawns Moderator @tosti007
              @tosti007
              Well, feel free to change the code and submit a pull request to the original developer and it’s repository.
              This way you make it official and everyone can benefit from it. If you just hack the code you would run into trouble if the developer releases an update.
              • T
                tosti007 Module Developer @yawns
                @yawns fair enough, I will have a look at it
                • T
                  So I gave it a look and I think it would be doable, however I don’t know how to work with that api and it also isn’t that easy to aquire a api from them. I think that best would be to open an issue at the module’s github page and ask for it there. He will have more knowlegde about how to use the api and to modify his code to use multiple, non train station id’s, locations aswell, sorry, hope this helps atleast a bit.
                  Reply Quote 1
                  • strawberry 3.141S
                    @tosti007 It’s very easy to get one, just took me ~ 2 minutes. You can give it a try.
                    Reply Quote 1
                    • T
                      I just came across this module. Isn’t this what you are looking for?
                      • T
                        tidus5
                        Hey everybody,
                        (sorry was in holiday) yes its that - i tried to use the calender broadcasts location in the module. but i dont understand how i can do that.
                        Could you help me ?
                        Have a nice day
