    Distance between glass and monitor
    4 Posts 3 Posters 962 Views 3 Watching
    • E Offline
      evgeniy88
      Hi all. Who knows if the monitor should be close to the glass (without a gap)? It’s just that some matrices have a frame (about 2 mm high), so if you attach the matrix to the glass, the fit will not be zero. Will this affect the imaging of the modules on the mirror?
      SergeS 1 Reply Last reply Reply Quote 0
      • SergeS Offline
        Serge @evgeniy88
        @evgeniy88 put the LCD as close to the mirror as possible.
        Even 3mm will decrease the quality of transmitting picture.
        It is better to leave only metal bound for LCD (usually, all LCD has the metal base frame)
        • bheplerB Offline
          bhepler Module Developer
          My first mirror had about a 1cm gap between the monitor and the mirror and it was noticeable.
          It’s not necessary to dismantle the monitor, but it will improve the finished look.
          • E Offline
            evgeniy88
            Thanks for your answers.
