    What's the best way to block out area of mirror that doesn't have a monitor behind it?
    12 Posts 5 Posters 5.5k Views 5 Watching
    • F
      fribse
      The mirror I have is bigget than the monitor, so I need to block out part of the mirror, so it isnt transparent.
      I was thinking of using some black spraypaint, but anybody that can recommend a good product?
      I can’t use black paper or something like that.
      I’m also going to mount LED-light strips besides the monitor, so that it will light the object in front up from behind the mirror.
      Therefore I was thinking that a good paint for it would be good?
      FoziF T 2 Replies Last reply
      • FoziF
        Fozi Project Sponsor @fribse
        @fribse hmmm…I’m not sure if painting is a good option, because it will be difficult to apply the paint accurately and evenly. I took some black foam matte that in which my mirror was wrapped in. That can be cut very accurately. May I ask why black paper or cardboard is not a viable option?
        F 1 Reply Last reply
        Reply Quote 1
        • F
          fribse @Fozi
          @Fozi Hi there, my hope was that I could make this somewhat frameless, because the mirror by nature is going to be rather fat, it might look less dominating if its frameless. So there is nothing ‘behind’ the mirror to hold the paper.
          • F
            fribse @fribse
            @fribse I’m going to try with foil, you know, the kind for windows. It should be doable, and get a good result without bubbles, I’ve done that for our frontdoor, It’s going to be tricky, but if it succeeds, it should be good.
            • B
              bhepler Module Developer
              I use black construction paper and tape it to the back of the glass. It sounds like the challenge is to get the paper attached without visible adhesive.
              You might be able to use a spray adhesive. There are a couple types that are designed for attaching wood laminate. A light & even coat could work. You would have complete blackout with the paper instead of additional reduction in transmission like you would with the window foil.
              Reply Quote 1
              • H
                Hubschra01
                I use black folie like oracal foil. It’s quit good.
                • you don’t pause your work at the mirror to wait for the paint it´s dry.
                • you can use the space behind the foil for wires, the raspsberry …
                • you can adapt it very quick to another display if your actually is broken or you decide to put a bigger one behind.
                Reply Quote 1
                • T
                  TerryB58 @fribse
                  @fribse I just used some 'blackout’cloth.
                  Reply Quote 1
                  • F
                    fribse
                    Great, thankyou for the suggestions, I definetely have something to go with now.
                    • F
                      fribse @bhepler
                      @bhepler What is ‘construction paper’? But, yes, the adhesive needs to be invisible.
                      I got some black foil for windows, I’m going to try and mount that, and put a flashlight to it, to see how well it does. The oracal foil mentioned by @Hubschra01 is very expensive, but probably also of better quality, I think I’m going to try that next.
                      B 1 Reply Last reply
                      • B
                        bhepler Module Developer @fribse
                        @fribse said in What's the best way to block out area of mirror that doesn't have a monitor behind it?:
                        That may be an Americanism. It’s a thick paper used in craft projects that comes in a variety of bright colors. I was first introduced to it when I was 5 or so, cutting it up with safety scissors to make family portraits. It’s roughly the thickness of business card stock, but it comes in large sheets.
                        If you are familiar with the cartoon South Park, they use construction paper to make the characters and then animate them (or at least they did in the beginning).
                        • F
                          fribse
                          Ahh, ok, then I know exactly what it is :-)
                          I got some oracal651 as suggested by @Hubschra01 , but that was slightly more transparent than the one I already had. So I’m going to stick with the cheap stuff I already had, and return the oracal651.
                          @Goldjunge_Chriz is it correct that I can foil the back of the mirror and then cut through the foil without ruining the ‘mirror foil’ as that is applied to the front of the glass in your variant?
                          • F
                            fribse
                            I sent the oracal back (very expensive stuff) as I could get much cheaper and darker stuff from our local hardware store.
                            So I got the back covered with it, and then cut holes in it for the LED lights and monitor, it seems to work very well.
                            Reply Quote 1
