    Update to MagicMirror² v2.13.0 failed
    14 Posts 5 Posters 4.8k Views 4 Watching
    • C Offline
      ColinT
      Just run git pull to update from v2.12.0 and it did the update but would not run afterwards. I had to do a clean install of v2.13.0 and copy the config and modules I had installed over to the new install and it now runs fine. Anyone any ideas why it would not run? Might be useful to anyone else with problems.
        sdetweil @ColinT
        @ColinT no idea… but I made a script to handle upgrades a year ago now…
        the ‘best’ part is the log file, so we can see what went on…
        many times u have to do an npm install in the module folders too
        wait,I re-read your post…
        after git pull, you did npm install , right?
        • StoffbeuteluweS Offline
          Stoffbeuteluwe Project Sponsor
          Hallo, I used Sams upgrade script and it works fine …
          Thank you sam for your work and help.
            sdetweil @Stoffbeuteluwe
            @Stoffbeuteluwe my pleasure… one failure was a module problem, the other my be network… unknown
              Stoffbeuteluwe Project Sponsor @sdetweil
              This post is deleted!
                @Stoffbeuteluwe what module is that?
                StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                  @sdetweil default current weather
                    @sdetweil i have it…
                    appendLocationNameToHeader: false,
                    • swvalentiS Offline
                      swvalenti Project Sponsor
                      Sam using your script and this is the output…this all that needs to be done?
                      pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                      No LSB modules are available.
                      doing test run = true, NO updates will be applied!
                      update log will be in /home/pi/MagicMirror/installers/upgrade.log
                      saving custom.css
                      upgrading from version 2.12.0 to 2.13.0
                      fetching latest revisions
                      there are 3 local files that are different than the master repo
                         installers/mm.sh
                         modules/default/compliments/compliments.js
                         package-lock.json
                      any *-lock.json files do not need to be saved
                      do you want to save these files for later   (Y/n)?y
                      processing dependency changes for active modules with package.json files
                      processing for module MMM-EARTH please wait
                      skipped processing for MMM-EARTH, doing test run
                      processing complete for module MMM-EARTH
                      processing for module MMM-FlightRadarTracker please wait
                      skipped processing for MMM-FlightRadarTracker, doing test run
                      processing complete for module MMM-FlightRadarTracker
                      processing for module MMM-DarkSkyForecast please wait
                      skipped processing for MMM-DarkSkyForecast, doing test run
                      processing complete for module MMM-DarkSkyForecast
                      restoring custom.css
                      test run, restoring files stashed
                      pi@raspberrypi:~ $
                        sdetweil @swvalenti
                        @swvalenti said in Update to MagicMirror² v2.13.0 failed:
                        there are TWO passes… one in test mode
                        and one with apply
                        what is wrong with my doc?
                        upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
                        it should handle all the work… and give you a trial run of all that…
                        only applying changes if u request them
                        give it a try this works on Mac as well, cut/paste this line into the terminal window on your device
                        no changes are made to the local repo or the working copy
                        if you WANT to actually apply the changes, cut/paste this line into the terminal window on your device
                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                        there is a log file (upgrade.log) in the MagicMirror/installers folder…
                        i don’t understand how everyone misses this
                          sdetweil
                          I updated the doc again to try to make the processes more visible
                            Thanks Sam
                            • cowboysdudeC Offline
                              cowboysdude Module Developer
                              The more things change… the more they stay the same…LOL
                              • C Offline
                                ColinT
                                Sorry I forgot all about the script been so busy with other stuff since I 1st installed it. Thanks for the reply.
                                Colin
