    Update to MagicMirror² v2.13.0 failed
    14 Posts 5 Posters 3.8k Views 4 Watching
      sdetweil @ColinT
      @ColinT no idea… but I made a script to handle upgrades a year ago now…
      the ‘best’ part is the log file, so we can see what went on…
      many times u have to do an npm install in the module folders too
      wait,I re-read your post…
      after git pull, you did npm install , right?
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor
        Hallo, I used Sams upgrade script and it works fine …
        Thank you sam for your work and help.
          sdetweil @Stoffbeuteluwe
          @Stoffbeuteluwe my pleasure… one failure was a module problem, the other my be network… unknown
            Stoffbeuteluwe Project Sponsor @sdetweil
              @Stoffbeuteluwe what module is that?
              StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                @sdetweil default current weather
                  @sdetweil i have it…
                  appendLocationNameToHeader: false,
                  • swvalentiS Offline
                    swvalenti Project Sponsor
                    Sam using your script and this is the output…this all that needs to be done?
                    pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                    No LSB modules are available.
                    saving custom.css
                    upgrading from version 2.12.0 to 2.13.0
                    fetching latest revisions
                    there are 3 local files that are different than the master repo
                       installers/mm.sh
                       modules/default/compliments/compliments.js
                       package-lock.json
                    any *-lock.json files do not need to be saved
                    do you want to save these files for later   (Y/n)?y
                    processing for module MMM-EARTH please wait
                    skipped processing for MMM-EARTH, doing test run
                    processing complete for module MMM-EARTH
                    processing for module MMM-FlightRadarTracker please wait
                    skipped processing for MMM-FlightRadarTracker, doing test run
                    processing complete for module MMM-FlightRadarTracker
                    processing for module MMM-DarkSkyForecast please wait
                    skipped processing for MMM-DarkSkyForecast, doing test run
                    processing complete for module MMM-DarkSkyForecast
                    restoring custom.css
                    test run, restoring files stashed
                    pi@raspberrypi:~ $
                      sdetweil @swvalenti
                      @swvalenti said in Update to MagicMirror² v2.13.0 failed:
                      there are TWO passes… one in test mode
                      and one with apply
                      what is wrong with my doc?
                      upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
                      it should handle all the work… and give you a trial run of all that…
                      only applying changes if u request them
                      give it a try this works on Mac as well, cut/paste this line into the terminal window on your device
                      no changes are made to the local repo or the working copy
                      if you WANT to actually apply the changes, cut/paste this line into the terminal window on your device
                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                      there is a log file (upgrade.log) in the MagicMirror/installers folder…
                      i don’t understand how everyone misses this
                        I updated the doc again to try to make the processes more visible
