    Update to MagicMirror² v2.13.0 failed
    14 Posts 5 Posters 3.9k Views 4 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @sdetweil
      This post is deleted!
        sdetweil @Stoffbeuteluwe
        @Stoffbeuteluwe what module is that?
        StoffbeuteluweS 2 Replies Last reply Reply Quote 0
          @sdetweil default current weather
            @sdetweil i have it…
            appendLocationNameToHeader: false,
            • swvalentiS Offline
              swvalenti Project Sponsor
              Sam using your script and this is the output…this all that needs to be done?
              pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
              No LSB modules are available.
              doing test run = true, NO updates will be applied!
              update log will be in /home/pi/MagicMirror/installers/upgrade.log
              saving custom.css
              upgrading from version 2.12.0 to 2.13.0
              fetching latest revisions
              there are 3 local files that are different than the master repo
                 installers/mm.sh
                 modules/default/compliments/compliments.js
                 package-lock.json
              any *-lock.json files do not need to be saved
              do you want to save these files for later   (Y/n)?y
              processing dependency changes for active modules with package.json files
              processing for module MMM-EARTH please wait
              skipped processing for MMM-EARTH, doing test run
              processing complete for module MMM-EARTH
              processing for module MMM-FlightRadarTracker please wait
              skipped processing for MMM-FlightRadarTracker, doing test run
              processing complete for module MMM-FlightRadarTracker
              processing for module MMM-DarkSkyForecast please wait
              skipped processing for MMM-DarkSkyForecast, doing test run
              processing complete for module MMM-DarkSkyForecast
              restoring custom.css
              test run, restoring files stashed
              pi@raspberrypi:~ $
                sdetweil @swvalenti
                @swvalenti said in Update to MagicMirror² v2.13.0 failed:
                there are TWO passes… one in test mode
                and one with apply
                what is wrong with my doc?
                upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
                it should handle all the work… and give you a trial run of all that…
                only applying changes if u request them
                give it a try this works on Mac as well, cut/paste this line into the terminal window on your device
                no changes are made to the local repo or the working copy
                if you WANT to actually apply the changes, cut/paste this line into the terminal window on your device
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                there is a log file (upgrade.log) in the MagicMirror/installers folder…
                i don’t understand how everyone misses this
                  sdetweil
                  I updated the doc again to try to make the processes more visible
                    Thanks Sam
                    • cowboysdudeC Offline
                      cowboysdude Module Developer
                      The more things change… the more they stay the same…LOL
                      • C Offline
                        ColinT
                        Sorry I forgot all about the script been so busy with other stuff since I 1st installed it. Thanks for the reply.
                        Colin
