    new tutorial pls
    20 Posts 5 Posters 5.3k Views 5 Watching
    • E Offline
      ember1205 @raf
      @raf So, figure out what’s incorrect and help get it updated. The doc you’re trying to work from was built in that same way at one point…
      • cowboysdudeC Offline
        cowboysdude Module Developer @ember1205
        @ember1205 problem is that’s not how it works LOL in the new ‘buy me’, ‘give me’, ‘take me’ culture we live in.
        I don’t answer much because people don’t ask for help…they just want someone else to do all the work. Personally I don’t want either Alexa or Google on a mirror. If you want that you may as well just go buy an Alexa or Google…
        E C 2 Replies Last reply Reply Quote 0
        • E Offline
          ember1205 @cowboysdude
          @cowboysdude I agree that most are quick to say “do this for me” and seldom say “how can I help you get this changed?” When you’re dealing with commercial products, that approach is expected because the source is closed. But, this is open-source and community-developed. We all have the ability to contribute -something-…
          • C Offline
            cyberphox @cowboysdude
            @cowboysdude Smartest thing I ever did when I wanted Alexa on my Mirror? Bought a cheap echo dot and called it a day!
              sdetweil @raf
              @raf here u go, https://www.dropbox.com/s/3rug57k78murz30/gaconfig.zip?dl=0
              unzip and open the GA-config.md with then atom editor, and press ctrl-shift-m twice
                raf
                @sdetweil thx
                i installed atom on my windows 10 and opened the manual but it stops halfway (the manual stops at this sentence and photo) (we also need the project ID for the plugin configuration above select the project name in the dropdown top left, and this panel will pop up copy/paste the project ID from the right hand column of this project)
                but I’m glad you wanted to help me
                  sdetweil @raf
                  @raf well u have the info needed for the rest of the tutorial which would be the same
                    @raf this takes you thru step 5 of the current wiki, so u can continue from there
                      raf @sdetweil
                      @sdetweil after installing the google assistant I get this message and magic mirror does not start anymore:
                      [2020-10-10 19:54:42.380] [LOG] Starting MagicMirror: v2.12.0
                      [2020-10-10 19:54:42.394] [LOG] Loading config …
                      [2020-10-10 19:54:42.405] [LOG] Loading module helpers …
                      [2020-10-10 19:54:44.378] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot
                      find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node’
                      Require stack:
                      • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js
                      • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js
                      • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
                      • /home/pi/MagicMirror/js/app.js
                      • /home/pi/MagicMirror/js/electron.js
                      • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                      [2020-10-10 19:54:44.380] [LOG] Loading module helpers …
                      [2020-10-10 19:54:44.391] [ERROR] App threw an error during load
                      [2020-10-10 19:54:44.392] [ERROR] Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node’
                      Require stack:
                      do I also have to install snowboy?
                      i just get black screen with no error message on the screen
                        raf
                        this is the same error as with me but I have google instead of alexa:
                        https://forum.magicmirror.builders/topic/12798/mmm-awesome-alexa-warning-electron-v6-1-linux-arm-snowboy-node
