    new tutorial pls
    20 Posts 5 Posters 6.8k Views 5 Watching
      raf
      can someone make a new tutorial to make for the google assistant credentials / api because the steps are very different than described in the wiki
      https://github.com/bugsounet/MMM-GoogleAssistant/wiki/Google-Assistant-Setup
      thx
      S E 2 Replies Last reply Reply Quote 0
        sdetweil @raf
        @raf well, we are all busy…
        • E Offline
          ember1205 @raf
          @raf Are you volunteering? :)
          Seriously - You won’t be anywhere near as well-versed as if you can figure it out on your own. And documenting your learnings to help others is how all of this stuff grows and improves. I’ve pestered @sdetweil plenty about a lot - much of his input has been to help me understand where to look, but he has also done some coding and such on his side. I’ve offered back some things I learned along the way that he has then incorporated and I’m now going to look into helping to extend and enhance some work he has done by doing the coding myself. It take a village, as they say…
          R cowboysdudeC 2 Replies Last reply Reply Quote 1
            raf @ember1205
            @ember1205 if the wiki were correct then there was no problem I’ve already made almost 30 tries
            E S 2 Replies Last reply Reply Quote 0
            • E Offline
              ember1205 @raf
              @raf So, figure out what’s incorrect and help get it updated. The doc you’re trying to work from was built in that same way at one point…
              • cowboysdudeC Offline
                cowboysdude Module Developer @ember1205
                @ember1205 problem is that’s not how it works LOL in the new ‘buy me’, ‘give me’, ‘take me’ culture we live in.
                I don’t answer much because people don’t ask for help…they just want someone else to do all the work. Personally I don’t want either Alexa or Google on a mirror. If you want that you may as well just go buy an Alexa or Google…
                E C 2 Replies Last reply Reply Quote 0
                • E Offline
                  ember1205 @cowboysdude
                  @cowboysdude I agree that most are quick to say “do this for me” and seldom say “how can I help you get this changed?” When you’re dealing with commercial products, that approach is expected because the source is closed. But, this is open-source and community-developed. We all have the ability to contribute -something-…
                    cyberphox @cowboysdude
                    @cowboysdude Smartest thing I ever did when I wanted Alexa on my Mirror? Bought a cheap echo dot and called it a day!
                      sdetweil @raf
                      @raf here u go, https://www.dropbox.com/s/3rug57k78murz30/gaconfig.zip?dl=0
                      unzip and open the GA-config.md with then atom editor, and press ctrl-shift-m twice
                        raf
                        @sdetweil thx
                        i installed atom on my windows 10 and opened the manual but it stops halfway (the manual stops at this sentence and photo) (we also need the project ID for the plugin configuration above select the project name in the dropdown top left, and this panel will pop up copy/paste the project ID from the right hand column of this project)
                        but I’m glad you wanted to help me
                          sdetweil @raf
                          @raf well u have the info needed for the rest of the tutorial which would be the same
                            @raf this takes you thru step 5 of the current wiki, so u can continue from there
                              raf @sdetweil
                              @sdetweil after installing the google assistant I get this message and magic mirror does not start anymore:
                              [2020-10-10 19:54:42.380] [LOG] Starting MagicMirror: v2.12.0
                              [2020-10-10 19:54:42.394] [LOG] Loading config …
                              [2020-10-10 19:54:42.405] [LOG] Loading module helpers …
                              [2020-10-10 19:54:44.378] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot
                              find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node’
                              Require stack:
                              • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js
                              • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js
                              • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
                              [2020-10-10 19:54:44.380] [LOG] Loading module helpers …
                              [2020-10-10 19:54:44.391] [ERROR] App threw an error during load
                              [2020-10-10 19:54:44.392] [ERROR] Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node’
                              Require stack:
                              do I also have to install snowboy?
                              i just get black screen with no error message on the screen
                                raf
                                this is the same error as with me but I have google instead of alexa:
                                https://forum.magicmirror.builders/topic/12798/mmm-awesome-alexa-warning-electron-v6-1-linux-arm-snowboy-node
                                  sdetweil @raf
                                  @raf i understand… I do not know the answer… his installer was one of the best, so I do not know what is the problem…
                                  he has been moving to a new location so has been/will be busy…
                                    raf @sdetweil
                                    @sdetweil now finally managed to do with the credentials and now i have another problem again but thanks again for the manual you made
                                      raf
                                      why is this crossed out:
                                      MMM-GoogleAssistant bugsounet Google Assistant integration. Actually not working with Original MagicMirror
                                      does it no longer work?
                                        sdetweil @raf
                                        @raf at one point he had removed all his modules. I do not know the status of individual modules
                                          raf
                                            raf
                                            after days of searching and a completely new installation I finally managed to get everything working, I finally did a rebuild of electron and then it works (and then in Dutch although I thought that this language was not supported )
