    Different calendars result in different layouts!?
    6 Posts 2 Posters 1.1k Views 2 Watching
    • W Offline
      wmx
      Hi there,
      I’m not shure if this is really a css topic, so feel free to move it to a better place if neccessary.
      Just running my first complete build up new MM as my wife wished. :-) (picture will follow)
      Now try some tests with the setup of selected modules. I included the default calendar module in different regions with different calendars. The problem is, their layouts differ and I don’t understand why.
      I build up an example setup to show the problem.
      You see the two upper calendars have different layouts, but I think, their config ist the same, isn’t it?
      Here the config for the scrennshot
      var config = {
      	timeFormat: 24,
       *	TOP_BAR
      			header: "Ferien Hessen",
      			position: "top_bar",
      				tableClass: "medium",
      				colored: true,
      				fetchInterval: 60000,
      				fullDayEventDateFormat: "dd DD. MMM",
      				timeFormat: "absolute",
      				urgency: 0,
      				getRelative: 0,
      				maximumEntries: 2,
      				maxTitleLength: 50,
      				showEnd: true,
      				dateEndFormat: "dd DD. MMM",
      						// Ferien Hessen 2020
      						symbol: "democrat",
      						color: "#ffaaaa",
      						url: "https://www.ferienwiki.de/exports/ferien/2020/de/hessen"
      			header: "Kalender Silke + Dirk",
      				colored: true,
      				coloredSymbolOnly: true,
      				dateFormat: "dd DD. MMM HH:mm",
      				urgency: 0,
      				getRelative: 0,
      				maximumNumberOfDays: 30,
      				maximumEntries: 2,
      				maxTitleLength: 50,
      				excludedEvents: [
      					"Geb.",
      					"Geburtstag ",
      					" Geburtstag"
      //					{filterBy: "Geb."},
      						// Dirk
      						symbol: "calendar",
      						color: "#006600",
       *	TOP_LEFT
      			header: "Geburtstage",
      				colored: true,
      				nextDaysRelative: false,
      				fullDayEventDateFormat: "ddd DD. MMM",
      				urgency: 0,
      				getRelative: 0,
      				maximumEntries: 2,
      						// Geburtstage
      						symbol: "birthday-cake",
      						color: "#5522aa",
      						url: "https://www.ferienwiki.de/exports/ferien/2020/de/hessen",
      			header: "Müllabfuhr2",
      				colored: true,
      				urgency: 0,
      				getRelative: 0,
      				maximumNumberOfDays: 8,
      				maximumEntries: 2,
      				fadePoint: 0.3,
      						// Müllabfuhr
      						symbol: "trash-alt",
      						color: "#FF6A00",
       *	TOP_RIGHT
      			header: "Müllabfuhr",
      				colored: true,
      				urgency: 0,
      				getRelative: 0,
      				maximumEntries: 2,
      				fadePoint: 0.3,
      						// Müllabfuhr
      						color: "#FF6A00",
      			header: "Geburtstage2",
      				colored: true,
      				urgency: 0,
      				getRelative: 0,
      				maximumEntries: 2,
      						// Geburtstage
      						color: "#5522aa",
      Is the config responsible for this layout? Or the calendar connected?
      For all calendars I Wish the icon to be aligned left, followed by the text and the date (the third column) aligned right the same way.
      How do I get this done?
      Every help is welcome.
      Regards
        sdetweil @wmx
        @wmx remember that top bar is all the way across the screen, while left and right are not
          @wmx so you have two stacked, all the way across, title centered, content left/right aligned (in area)
          .region.bar {
            width: 100%;
            text-align: center;
          two stacked, title left text aligned , content left/right aligned (in area)
          top-center is not used
          and two stacked, title right text aligned, content left/right aligned (in area)
          each calendar creates an HTML table
          • W Offline
            wmx @sdetweil
            @sdetweil said in Different calendars result in different layouts!?:
            .region.bar {
            width: 100%;
            text-align: center;
            If I add this css snippet to custom.css nothing changes!?
            Is there a way to format each column in each calendar (table) with css?
            How do I address one single calendar with css?
              sdetweil @wmx
              @wmx I was showing that top bar goes all the way across 100%
              that is the existing css
                sdetweil @wmx
                @wmx I do not know how to target one calendar.
                yes there are ways to target specific elements in specific spot in the dom tree. I have to search for it every time.
