    trouble with MMM-GoogleTrafficTimes
    traffic
    39 Posts 3 Posters 11.1k Views 3 Watching
    • L Offline
      laschalkh
      I’m new to MagicMirror and I’m trying to get MMM-GoogleTrafficTimes to work. I’ve created a new api key from google and have US addresses entered for the origin and destinations. It’s not showing up on the mirror at all. I’ve tried tweaking it to make sure I didn’t have any typos and rebooted multiple times. Anyone have any suggestions on how to find what’s wrong?
        sdetweil @laschalkh
        @laschalkh open the developers window
        ctrl-shift-i on the mirror keyboard, select the console tab and scroll up to see any errors
        • L Offline
          laschalkh @sdetweil
          Hi Sam, I tried that key sequence from the console. I’m not getting the interface.
          Thanks,
          Kevin
            sdetweil @laschalkh
            @laschalkh all at the same time
            • L Offline
              laschalkh @sdetweil
              Hi Sam,
              yea, I understand this would be pulling up the developer interface from the browser. But it’s not coming up. Is there another way to see those errors?
              Thanks,
              Kevin
                sdetweil @laschalkh
                @laschalkh you can restart MagicMirror by using
                npm start dev
                if you use.pm2, then stop that instance
                pm2 stop all
                • L Offline
                  laschalkh @sdetweil
                  Hi Sam, when I try to run npm start dev I get an error. Which directory does it expect to be run from? I tried in a few locations and nothing worked.
                  Thanks,
                  Kevin
                    sdetweil @laschalkh
                    @laschalkh always in the MagicMirror folder
                    • L Offline
                      laschalkh
                      ok, tried that and got the error:
                      Failed at the magicmirror@2.13.0 start script.
                        sdetweil @laschalkh
                        @laschalkh there has got to be more than 1 line
                        • L Offline
                          laschalkh
                          ok, found that it created a log file for that process
                          1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’, ‘dev’ ]
                          2 info using npm@6.9.0
                          3 info using node@v10.16.0
                          4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                          5 info lifecycle magicmirror@2.13.0~prestart: magicmirror@2.13.0
                          6 info lifecycle magicmirror@2.13.0~start: magicmirror@2.13.0
                          7 verbose lifecycle magicmirror@2.13.0~start: unsafe-perm in lifecycle true
                          8 verbose lifecycle magicmirror@2.13.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/
                          node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bi
                          n:/usr/local/games:/usr/games
                          9 verbose lifecycle magicmirror@2.13.0~start: CWD: /home/pi/MagicMirror
                          10 silly lifecycle magicmirror@2.13.0~start: Args: [ ‘-c’,
                          10 silly lifecycle ‘DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “dev”’ ]
                          11 info lifecycle magicmirror@2.13.0~start: Failed to exec start script
                          12 verbose stack Error: magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/ele ctron.js "dev"
                          12 verbose stack spawn ENOENT
                          12 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/li
                          b/spawn.js:48:18)
                          12 verbose stack at ChildProcess.emit (events.js:198:13)
                          12 verbose stack at maybeClose (internal/child_process.js:982:16)
                          12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                          13 verbose pkgid magicmirror@2.13.0
                          14 verbose cwd /home/pi/MagicMirror
                          15 verbose Linux 4.19.97+
                          16 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start” “dev”
                          17 verbose node v10.16.0
                          18 verbose npm v6.9.0
                          19 error file sh
                          20 error code ELIFECYCLE
                          21 error errno ENOENT
                          22 error syscall spawn
                          23 error magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
                          23 error spawn ENOENT
                          24 error Failed at the magicmirror@2.13.0 start script.
                          24 error This is probably not a problem with npm. There is likely additional logging output above.
                          25 verbose exit [ 1, true ]
                            sdetweil @laschalkh
                            @laschalkh is this a pi 0?
                            • L Offline
                              laschalkh
                              yup, zero w
                                sdetweil @laschalkh
                                @laschalkh ok, lots of setup, or, remove that mm folder and run my install script
                                see the instructions here
                                • L Offline
                                  laschalkh
                                  ok, the entire MagicMirror directory or just the modules?
                                    sdetweil @laschalkh
                                    @laschalkh the entire, rename it
                                    the problem is there is no electron browser for armv6l (pi0/1) devices anymore, so you have to run split mode, server with chromium over the top
                                    the script does all the work, so it looks like normal
                                    • L Offline
                                      laschalkh
                                      Hi Sam,
                                      I went through and rebuilt my pi and then ran your install script. It says it’s installed and when I do a pm status I see the MagicMirror is online. I don’t see the mirror tho. Is there something else I need to do for that to come up on boot?
                                      Thanks,
                                      Kevin
                                        sdetweil @laschalkh
                                        @laschalkh pm2 logs – lines=100
                                        in the status it shows how many times its been restarted
                                        │ id  │ name            │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                                        │ 1   │ MagicMirror     │ default     │ 2.13.0… │ fork    │ N/A      │ 0      │ 1    │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                                        that field next to uptime with the circle and arrow
                                        pm2 stop 0 to stop it while u debug
                                        • L Offline
                                          laschalkh
                                          it looks ok, not complaining. Am I just missing the front end?
                                          /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                                          0|MagicMir |
                                          0|MagicMir | > magicmirror@2.13.0 start /home/pi/MagicMirror
                                          0|MagicMir | > ./run-start.sh $1
                                          0|MagicMir |
                                          0|MagicMir | [2020-10-15 17:13:43.975] [LOG] Starting MagicMirror: v2.13.0
                                          0|MagicMir | [2020-10-15 17:13:44.068] [LOG] Loading config …
                                          0|MagicMir | [2020-10-15 17:13:44.123] [LOG] Loading module helpers …
                                          0|MagicMir | [2020-10-15 17:13:44.147] [LOG] No helper found for module: alert.
                                          0|MagicMir | [2020-10-15 17:13:44.569] [LOG] Initializing new module helper …
                                          0|MagicMir | [2020-10-15 17:13:44.578] [LOG] Module helper loaded: updatenotification
                                          0|MagicMir | [2020-10-15 17:13:44.590] [LOG] No helper found for module: clock.
                                          0|MagicMir | [2020-10-15 17:13:48.255] [LOG] Initializing new module helper …
                                          0|MagicMir | [2020-10-15 17:13:48.263] [LOG] Module helper loaded: calendar
                                          0|MagicMir | [2020-10-15 17:13:48.267] [LOG] No helper found for module: compliments.
                                          0|MagicMir | [2020-10-15 17:13:48.270] [LOG] No helper found for module: currentweather.
                                          0|MagicMir | [2020-10-15 17:13:48.283] [LOG] No helper found for module: weatherforecast.
                                          0|MagicMir | [2020-10-15 17:13:48.482] [LOG] Initializing new module helper …
                                          0|MagicMir | [2020-10-15 17:13:48.490] [LOG] Module helper loaded: newsfeed
                                          0|MagicMir | [2020-10-15 17:13:48.501] [LOG] All module helpers loaded.
                                          0|MagicMir | [2020-10-15 17:13:49.375] [LOG] Starting server on port 8080 …
                                          0|MagicMir | [2020-10-15 17:13:49.542] [LOG] Server started …
                                          0|MagicMir | [2020-10-15 17:13:49.563] [LOG] Connecting socket for: updatenotification
                                          0|MagicMir | [2020-10-15 17:13:49.569] [LOG] Connecting socket for: calendar
                                          0|MagicMir | [2020-10-15 17:13:49.593] [LOG] Starting node helper for: calendar
                                          0|MagicMir | [2020-10-15 17:13:49.601] [LOG] Connecting socket for: newsfeed
                                          0|MagicMir | [2020-10-15 17:13:49.615] [LOG] Starting node helper for: newsfeed
                                          0|MagicMir | [2020-10-15 17:13:49.617] [LOG] Sockets connected & modules started …
                                          0|MagicMir | [2020-10-15 17:13:49.621] [LOG]
                                          0|MagicMir | Ready to go! Please point your browser to: http://localhost:8080
                                          0|MagicMir | [2020-10-15 17:14:28.183] [LOG] [SIGINT] Received. Shutting down server…
                                          0|MagicMir | [2020-10-15 17:14:28.210] [LOG] Stopping module helper: updatenotification
                                          0|MagicMir | [2020-10-15 17:14:28.218] [LOG] Stopping module helper: calendar
                                          0|MagicMir | [2020-10-15 17:14:28.221] [LOG] Stopping module helper: newsfeed
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir | [2020-10-15 17:14:40.950] [LOG] Starting MagicMirror: v2.13.0
                                          0|MagicMir | [2020-10-15 17:14:41.041] [LOG] Loading config …
                                          0|MagicMir | [2020-10-15 17:14:41.092] [LOG] Loading module helpers …
                                          0|MagicMir | [2020-10-15 17:14:41.115] [LOG] No helper found for module: alert.
                                          0|MagicMir | [2020-10-15 17:14:41.477] [LOG] Initializing new module helper …
                                          0|MagicMir | [2020-10-15 17:14:41.485] [LOG] Module helper loaded: updatenotification
                                          0|MagicMir | [2020-10-15 17:14:41.489] [LOG] No helper found for module: clock.
                                          0|MagicMir | [2020-10-15 17:14:45.097] [LOG] Initializing new module helper …
                                          0|MagicMir | [2020-10-15 17:14:45.104] [LOG] Module helper loaded: calendar
                                          0|MagicMir | [2020-10-15 17:14:45.107] [LOG] No helper found for module: compliments.
                                          0|MagicMir | [2020-10-15 17:14:45.110] [LOG] No helper found for module: currentweather.
                                          0|MagicMir | [2020-10-15 17:14:45.123] [LOG] No helper found for module: weatherforecast.
                                          0|MagicMir | [2020-10-15 17:14:45.302] [LOG] Initializing new module helper …
                                          0|MagicMir | [2020-10-15 17:14:45.309] [LOG] Module helper loaded: newsfeed
                                          0|MagicMir | [2020-10-15 17:14:45.311] [LOG] All module helpers loaded.
                                          0|MagicMir | [2020-10-15 17:14:46.068] [LOG] Starting server on port 8080 …
                                          0|MagicMir | [2020-10-15 17:14:46.244] [LOG] Server started …
                                          0|MagicMir | [2020-10-15 17:14:46.273] [LOG] Connecting socket for: updatenotification
                                          0|MagicMir | [2020-10-15 17:14:46.292] [LOG] Connecting socket for: calendar
                                          0|MagicMir | [2020-10-15 17:14:46.295] [LOG] Starting node helper for: calendar
                                          0|MagicMir | [2020-10-15 17:14:46.299] [LOG] Connecting socket for: newsfeed
                                          0|MagicMir | [2020-10-15 17:14:46.323] [LOG] Starting node helper for: newsfeed
                                          0|MagicMir | [2020-10-15 17:14:46.330] [LOG] Sockets connected & modules started …
                                          0|MagicMir | [2020-10-15 17:14:46.343] [LOG]
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir | [2020-10-15 17:17:29.023] [LOG] Starting MagicMirror: v2.13.0
                                          0|MagicMir | [2020-10-15 17:17:29.117] [LOG] Loading config …
                                          0|MagicMir | [2020-10-15 17:17:29.195] [LOG] Loading module helpers …
                                          0|MagicMir | [2020-10-15 17:17:29.218] [LOG] No helper found for module: alert.
                                          0|MagicMir | [2020-10-15 17:17:29.614] [LOG] Initializing new module helper …
                                          0|MagicMir | [2020-10-15 17:17:29.623] [LOG] Module helper loaded: updatenotification
                                          0|MagicMir | [2020-10-15 17:17:29.635] [LOG] No helper found for module: clock.
                                          0|MagicMir | [2020-10-15 17:17:33.776] [LOG] Initializing new module helper …
                                          0|MagicMir | [2020-10-15 17:17:33.784] [LOG] Module helper loaded: calendar
                                          0|MagicMir | [2020-10-15 17:17:33.787] [LOG] No helper found for module: compliments.
                                          0|MagicMir | [2020-10-15 17:17:33.799] [LOG] No helper found for module: currentweather.
                                          0|MagicMir | [2020-10-15 17:17:33.802] [LOG] No helper found for module: weatherforecast.
                                          0|MagicMir | [2020-10-15 17:17:34.029] [LOG] Initializing new module helper …
                                          0|MagicMir | [2020-10-15 17:17:34.037] [LOG] Module helper loaded: newsfeed
                                          0|MagicMir | [2020-10-15 17:17:34.039] [LOG] All module helpers loaded.
                                          0|MagicMir | [2020-10-15 17:17:34.984] [LOG] Starting server on port 8080 …
                                          0|MagicMir | [2020-10-15 17:17:35.147] [LOG] Server started …
                                          0|MagicMir | [2020-10-15 17:17:35.176] [LOG] Connecting socket for: updatenotification
                                          0|MagicMir | [2020-10-15 17:17:35.200] [LOG] Connecting socket for: calendar
                                          0|MagicMir | [2020-10-15 17:17:35.203] [LOG] Starting node helper for: calendar
                                          0|MagicMir | [2020-10-15 17:17:35.207] [LOG] Connecting socket for: newsfeed
                                          0|MagicMir | [2020-10-15 17:17:35.235] [LOG] Starting node helper for: newsfeed
                                          0|MagicMir | [2020-10-15 17:17:35.246] [LOG] Sockets connected & modules started …
                                          0|MagicMir | [2020-10-15 17:17:35.249] [LOG]
                                          0|MagicMir | [2020-10-15 17:26:21.269] [LOG] [SIGINT] Received. Shutting down server…
                                          0|MagicMir | [2020-10-15 17:26:21.297] [LOG] Stopping module helper: updatenotification
                                          0|MagicMir | [2020-10-15 17:26:21.309] [LOG] Stopping module helper: calendar
                                          0|MagicMir | [2020-10-15 17:26:21.311] [LOG] Stopping module helper: newsfeed
                                            sdetweil @laschalkh
                                            @laschalkh ok do
                                            cd ~/MagicMirror
                                            ls -laF run-start.sh
                                            uname -a
                                            pgrep Xorg
                                            which chromium-browser
                                            sorry, for adding late
