    MM freeze over night
    freezewificlean
    6 Posts 3 Posters 2.5k Views 3 Watching
      MajorC Project Sponsor
      Hello,
      my MM freezes over night. I suspected the SD card or one of the modules. So I bought a new SD card and the original Pi power supply and proceeded step by step:
      1. only Raspberry Pi OS 5.4.51 installed -> runs 48h without problems
      2. MM via the installation script of @sdetweil
      -> MM runs for about 12 hours then the PI obviously loses the wifi connection or something else happend and the whole OS freezes. I still see the MM on the monitor, but:
      • in the terminal I can still execute commands
        or
      • the whole OS is frozen, not even the seconds are running
      My question, what is the best way to proceed? Where can I view which logs?
      FoziF 1 Reply Last reply Reply Quote 0
        I now have a clean OS installation and a clean MM installation. Stopped MM with
        pm2 stop MagicMirror
        and see, what it is doing over night.
        • FoziF Offline
          Fozi Project Sponsor @MajorC
          @MajorC which modules are you running? I had that with conflicting modules and activated one by one to find the culprit. It was a Google maps module in my case.
            MajorC Project Sponsor @Fozi
            @Fozi
            Good morning, with a clean OS and a clean but stopped MagicMirror my Raspberry ran for 48h without any freeze or wifi problem or what so ever. Even after the 48h I could access the OS via SSH.
            Now I rebooted the system, MagicMirror with only the default modules without any changes are running. Let’s see what is in the log’s after 48h.
            I am still looking for help, where I can find the right logs to look into.
            Thank you.
            • T Offline
              Tribun @MajorC
              @MajorC pm2 Logs can be found @
              /home/pi/.pm2/logs
              npm Logs @
              /home/pi/.npm/_logs
              different system logs @
              /var/log
              you can install the following module for better logging:
              https://github.com/shbatm/MMM-Logging
                My MM was running now for 48h without freezing. I don’t know what happened the last couple of times. Thank you to @Tribun ! I checked all the logs and found no problem. I will now start to install the first modules and see what’s going on.
