    Module position
    Scheduled Pinned Locked Moved Forum
    module
    4 Posts 2 Posters 2.0k Views 1 Watching
    • G
      George
      Hello,
      I’m a novice, now I’ve built the first mirror. I want to position a module in a certain area, I tried with:
      module: “MMM-MoonPhase”,
      position: {
      left: calc (100 vh - 50%),
      top: calc (100wv - 40%)
      But it does not work. How should the code be written? Thanks
      SnilleS 1 Reply Last reply
      • SnilleS
        Snille Module Developer @George
        @George Hi, you use the defined “regions”: https://forum.magicmirror.builders/topic/286/regions
        Like this, this is from my config:
        			disabled: false,
        			module: "MMM-MoonPhase",
        			position: "top_right", // This is the region...
        				updateInterval: 43200000,
        				hemisphere: "N",
        				resolution: "detailed",
        				basicColor: "white",
        				title: true,
        				phase: true,
        				x: 150,
        				y: 150,
        				alpha: 0.7
        If you cant find it, make it and share it
        MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
        G 1 Reply Last reply
        • G
          George @Snille
          @Snille , thanks for the reply. I want to partially overlap another module over the “Moon” module. For this I need a positioning with coordinates, otherwise they will not overlap. Do you have any idea how I can do it?
          • SnilleS
            @George Oh, no, not really, but I’m sure it’s possible with CSS, so it would be in your “custom.css” file you should do what’s needed…
            Maybe some one else knows? :)
