    Need help - New programmer
    23 Posts 5 Posters 6.1k Views 5 Watching
      smart_user
      Hello, I am a 16 year old new programmer and I am in the process of making a smart mirror. My mirror should remind the person to drink water every 1 hour. I am unable to code it to do that. Can somebody help? I will really appreciate it!
      • A
        ashishtank Module Developer
        @smart_user Where you are stuck ? check the default modules code, you will need to configure a timer to repeat the task every 1 hour (should be configurable). and in that task you should display message on screen.
        Check window.timeout and window.setInterval function of javascript.
          sdetweil @smart_user
          @smart_user you could use my sample module which puts up a configured message every few minutes. Change the message and the time…
          https://github.com/sdetweil/SampleModule
            smart_user @ashishtank
            @ashishtank Yes I will look into it. Thank you so much for the instant reply. Appreciate it a lot
              smart_user @sdetweil
              @sdetweil Thank you so much! I will use this module and let you know how it goes!
                @smart_user ok. Timer is in the node_helper.
                It is a one time timer, setTimer, vs repeating, setInterval.
                Doesn’t need to be in the node_helper, but did that to show the structure and communication between the parts
                  smart_user
                  @sdetweil It still isn’t working. I had configured for the alert to show up in 10 seconds but it didn’t
                    @smart_user you changed the 15000 in node_helper to 10000, right?
                    And u had a position: set in config.js, right?
                      smart_user
                      @sdetweil Yes
                        smart_user
                        @sdetweil Is it possible for you to send me a picture of the .js file so I can double check?
                          @smart_user u can look on the github site
                          View code. Then click on file.
                          If you used git clone, then u can do
                          git diff node_helper.js
                          to see the differences
                            smart_user
                            @sdetweil Hello. I did and still am not receiving any alert on the screen
                              @smart_user show me the config block. Minimum is this. MUST have a position
                                   module:"SampleModule",
                                   position:"middle",
                                A Former User
                                euh … position needed ONLY if you have to show something on the mirror (getDom).
                                If you have nothing to show THEN position is not needed
                                Note: verified in my lasted module (position is not needed because no visual)
                                  sdetweil @Guest
                                  @Bugsounet yes, my sample module DOES want to display something
                                    smart_user
                                    @sdetweil Yes! I missed adding the position to the config file. Just have another clarification. Can these messages show up for a few seconds then disappear and then appear again after 30 minutes? If so, how do I do that?
                                      @smart_user sure. When u want the message to go away, set the string to empty, or not create any content in getDom()…
                                      U would start a timer after u display the text, and the call updateDom() in the timer routine.
                                      Wait, display. Wait. Remove output
                                      Repeat
                                      • I
                                        innovation
                                        @sdetweil Hello, I am facing the same problem - and I want the same feature @smart_user mentioned. But I am sorry, I didn’t get the timer part. Which string are you talking about? and where will I add the updateDom()? Please help
                                          sdetweil @innovation
                                          @innovation i have my grandson for a few hours will get back to you
                                          • I
                                            innovation
                                            sure @sdetweil, no problem!
