    MM does not start full screen (pi Zero)
    20 Posts 3 Posters 6.1k Views 3 Watching
    • J
      jthewarrior7
      Hi all,
      With some help of a friend I was able to get the MM running on a pie zero. The only problem that I am now running into is that the MM window does not start full screen. (see image)
      Can anyone help me with this? My programming experience does not reach further than installing and configuring some modules.
      Thanks in advance!
      • A
        ashishtank Module Developer @jthewarrior7
        @jthewarrior7 Is it starting electron window or chromium browser ? I recently made my magic mirror with pi zero w and had some issues with electron but as it is optional npm start is starting chromium browser in full screen and it is working fine, Also I am using Rapbian OS Desktop version.
          sdetweil @ashishtank
          @ashishtank yes, if you used my installer script, it would have setup for chromium…
          • A
            ashishtank Module Developer @sdetweil
            @sdetweil Yes, I did used it Sam. I also mentioned it in your scripts topic as well. Thanks for the script :)
              @ashishtank I know. i was talking to @jthewarrior7
              • J
                jthewarrior7
                Yes it is indeed chromium
                  sdetweil @jthewarrior7
                  @jthewarrior7 ok, if u close mm, pm2 stop 0.
                  then start chromium manually. (probably from terminal window), does it open to fill the screen?
                  • J
                    jthewarrior7
                    I have started the chromium-browser , which opens in the same size as the magic mirror.
                    • A
                      @jthewarrior7 May be it is remembering the last opened size of browser ? can you maximize it then close and reopen it ? Is it open maximized ? Then try with Mirror script.
                        @ashishtank but the script (run-start.sh), requests maximize…
                        • J
                          jthewarrior7
                          Chromium indeed remembers the size when I reopen it after increasing the window size, and also the kiosk mode of chromium opens in this size. Unfurtunately the MM still opens in its original size.
                          Is it maybe possible to start up the MM in the non-kiosk mode, then adjust the size/position and turn it back into kiosk?
                            @jthewarrior7 sure, edit the run-start.sh and remove ‘-kiosk’ from the parameters
                             chromium-browser -noerrdialogs -kiosk -start_maximized  --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
                            hm… looking thru the flags supported, it says all need double dash in front… so, add a dash to -maximized
                            and -kiosk
                            https://peter.sh/experiments/chromium-command-line-switches/
                              @jthewarrior7 u can also try adding the window-size parm.
                              --window-size ⊗	Sets the initial window size. Provided as string in the format "800,600".
                              • J
                                jthewarrior7
                                Thanks for these tips, I will try if that works and let you know :)
                                  @jthewarrior7 ok, I am trying to change my pi0 orientation to test
                                    @jthewarrior7 mine came up full screen without any script changes
                                    • J
                                      jthewarrior7
                                      The --start-maximized but also the --window-size does not seem to have any effect. I tried them both when opening a new chromium window via the console (chromium-browser --start-maximized, but the chromium still launches at its previously closed size and position.
                                        @jthewarrior7 try --start-fullscreen
                                        this seems to work on my pi0, where --start-maximized does not
                                        • J
                                          jthewarrior7
                                          start fullscreen removes the top bar etc. but strangely enough the size of the chromium window does not go to fullscreen.
                                            @jthewarrior7 weird… kiosk is what removes the titlebar
