    After update, nothing happens.
    64 Posts 3 Posters 34.1k Views 3 Watching
      Richard238
      Splashscreen: Changed theme to MagicMirror successfully.
      Do you want use pm2 for auto starting of your MagicMirror (y/N)?
        sdetweil @Richard238
        @Richard238 no
          sdetweil
          ~/install.log should say we upgraded node to 10.23 ish and npm to 6.14 ish
            Richard238
            Do you want use pm2 for auto starting of your MagicMirror (y/N)?N
            Do you want to disable the screen saver? (y/N)?
            We’re ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
            pi@pi_mirror:~ $
            As a new user, you can only post once every 120 second(s) until you have earned 3 reputation - please wait before posting again …New User? I’ve been a member for years?
            S A 2 Replies Last reply Reply Quote 0
              @Richard238 no idea…
              so, now
              node --v
              npm --v
              go to the old folder, delete the node_modules folder
              rm -rf node_modules
              npm install --only=prod
              then npm start
                ashishtank Module Developer @Richard238
                @Richard238 you need at least 3 reputation to post more often. It will be visible in your profile.
                  Richard238 @sdetweil
                  @sdetweil said in After update, nothing happens.:
                  [92mNode.js installation Done! version=v10.23.0
                  0mInstalled npm version: V6.14.8
                    so, now
                    node --v
                    npm --v
                    pi@pi_mirror:~ $ node --v
                    node: bad option: --v
                    pi@pi_mirror:~ $ npm --v
                    6.14.8
                    pi@pi_mirror:~ $ node -v
                    v10.23.0
                    pi@pi_mirror:~ $
                      @Richard238 ok, up to level
                        Richard238
                        MagicMirror installation finished successfully!
                        added 330 packages from 282 contributors and audited 1149 packages in 152.782s
                        16 packages are looking for funding
                          run `npm fund` for details
                        found 1 low severity vulnerability
                          run `npm audit fix` to fix them, or `npm audit` for details
                        pi@pi_mirror:~/MagicMirror__RL1 $ npm start
                        > magicmirror@2.14.0-develop start /home/pi/MagicMirror__RL1
                        /home/pi/MagicMirror__RL1/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror__RL1/node_modules/electron/dist/electron)
                          @Richard238 interesting. I have to go pick up grandson, be unable to research for a few hours. 3ish…
                            OK, thank you for your help this far.
                              @Richard238 try this
                              in the old mm folder
                              git pull origin develop
                              npm start
                                Richard238
                                I just powered it off, and this time it’s booted to the default MM with US Holidays.
                                Does that help, what should I try next?
                                  @Richard238 yes the new mm came up.
                                    Should I stop that before doing this
                                    "git pull origin develop / npm install --only=prod / npm start "
                                    in the old MM?
                                      @Richard238 yes pm2 stop all
                                        Richard238
                                        pi@pi_mirror:~ $ pm2 stop all
                                        [PM2] Applying action stopProcessId on app [all](ids: 0)
                                        [PM2] [mm](0) ✓
                                        │ Name │ mode │ status  │ ↺ │ cpu │ memory │
                                        │ mm   │ fork │ stopped │ 0 │ 0%  │ 0 B    │
                                         Use `pm2 show <id|name>` to get more details about an app
                                        pi@pi_mirror:~ $ cd ~/MagicMirror__RL1
                                        pi@pi_mirror:~/MagicMirror__RL1 $ git pull origin develop
                                        remote: Enumerating objects: 8, done.
                                        remote: Counting objects: 100% (8/8), done.
                                        remote: Compressing objects: 100% (8/8), done.
                                        remote: Total 8 (delta 1), reused 0 (delta 0), pack-reused 0
                                        Unpacking objects: 100% (8/8), done.
                                        From https://github.com/MichMich/MagicMirror
                                         * branch            develop    -> FETCH_HEAD
                                           a4ab0cb..da00c16  develop    -> origin/develop
                                        Updating a4ab0cb..da00c16
                                        Fast-forward
                                         CHANGELOG.md | 1 +
                                         js/module.js | 2 +-
                                         2 files changed, 2 insertions(+), 1 deletion(-)
                                        pi@pi_mirror:~/MagicMirror__RL1 $ npm install --only=prod
                                        > magicmirror@2.14.0-develop install /home/pi/MagicMirror__RL1
                                        > echo "Installing vendor files ...
                                        " && cd vendor && npm install --loglevel=error
                                        audited 24 packages in 1.991s
                                        1 package is looking for funding
                                        found 0 vulnerabilities
                                        > magicmirror@2.14.0-develop postinstall /home/pi/MagicMirror__RL1
                                        > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                        > magicmirror@2.14.0-develop install-fonts /home/pi/MagicMirror__RL1
                                        > echo "Installing fonts ...
                                        " && cd fonts && npm install --loglevel=error
                                        audited 1 package in 1.03s
                                        audited 1149 packages in 36.561s
                                          @sdetweil the new install used the master branch, so on electron 6. the old folder is on develop, so electron 8.5
                                            @Richard238 ok. 1st time seeing this…
                                            just to make sure
                                            from the old folder
                                            grep version node_modules/electron/package.json
                                            • 2 / 4
