    After update, nothing happens.
    64 Posts 3 Posters 28.4k Views 3 Watching
      Richard238
      @sdetweil said in After update, nothing happens.:
      grep version node_modules/electron/package.json
      pi@pi_mirror:~/MagicMirror__RL1 $ grep version node_modules/electron/package.json
      “type”: “version”,
      “version”: “8.5.3”
        @sdetweil one more diag command
        lsb_release -a
          Richard238
          pi@pi_mirror:~ $ lsb_release -a
          No LSB modules are available.
          Distributor ID: Raspbian
          Description: Raspbian GNU/Linux 8.0 (jessie)
          Release: 8.0
          Codename: jessie
          pi@pi_mirror:~ $
            sdetweil @Richard238
            @Richard238 ok, thx. problem is new electron won’t run on Jessie anymore…
            I don’t know if this will work.
            from. the old mm folder
            rm -rf node_modules/electron
            npm install electron@6.1.12
            then npm start
              Richard238
              Sam, you’re a genius!
              That’s fixed it.
              This will only happen again in the not too distant future I’m sure, so would I be better off installing a newer OS?
              And then how do I recreate my MM on said new OS?
              I’m going to logoff for now, thanks again for your help today.
              More tomorrow I’m sure.
              Kind regards,
              Richard.
                @Richard238
                copy your MagicMirror folder to save it somewhere
                u can zip it to to save space
                install buster on your sd card
                run the installer to get things setup
                restore you MM zip file
                erase the node_modules folder
                npm install (this should put on the newer electron)
                npm start
                  Richard238
                  Old MM FTPd to NAS.
                  Installing new OS now, on a different SD card so I can go back if absolutely necessary.
                  My plan is to build a new MM as the old one had a lot of clutter - old unused modules etc.
                  Taking the opportunity for a fresh start. I’ll let you know how it goes…
                    Richard238 @Richard238
                    @Richard238 said in After update, nothing happens.:
                    Old MM FTPd to NAS.
                    14:24
                    All done.
                    MM back just as it was with custom CSS, but this time using only the modules installed that I actually need.
                    MM accessible from any LAN attached device as I don’t have it setup as a mirror anywhere.
                    The terminal window is showing a constatnt log of what’s happening. Is that correct - I don’t remember it from MM_OLD?
                    And will the update notification module do anything now, or do I need to do anything?
                      @Richard238 edit the config.js, there us a new logLevel setting, make sure debug is not included
                        @Richard238 updatenotification will continue to advise things that have changed…
                        are u at 2.14 w 8.5 electron?
                          Richard238
                          I copied my config.js into the new install, and deleted all the old commented-out module junk I was no longer using.
                          Added the 'loglevel: [… ’ line, doesn’t yet seem to have made any difference. Reboot required perhaps?
                          2.14? Package.Json = “version” : “2.14.0”
                          Electron is 8.5
                          pi@magicmirror:~/MagicMirror $ grep version node_modules/electron/package.json
                            "version": "8.5.5"
                            @Richard238 can u show me some of the messages?
                              @Richard238 notice its logLevel, second l is capital
                                Richard238 @sdetweil
                                rue" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                                [02.01.2021 14:46.31.149] [LOG]   Create new calendar fetcher for url: https://calendar.google.com/calendar/##################################### Interval: 300000
                                [02.01.2021 14:46.31.360] [LOG]   Create new calendar fetcher for url: https://calendar.google.com/calendar/##################################### Interval: 300000
                                [02.01.2021 14:46.31.366] [LOG]   Create new news fetcher for url: http://feeds.reuters.com/reuters/UKTopNews - Interval: 120000
                                [02.01.2021 14:46.31.437] [LOG]   Create new news fetcher for url: http://feeds.skynews.com/feeds/rss/world.xml - Interval: 120000
                                [02.01.2021 14:46.31.447] [INFO]  Checking git for module: MMM-doomsDay
                                [02.01.2021 14:46.31.455] [INFO]  Checking git for module: MMM-MysqlQuery
                                [02.01.2021 14:46.32.473] [INFO]  Newsfeed-Fetcher: Broadcasting 10 items.
                                [02.01.2021 14:46.33.722] [INFO]  Calendar-Fetcher: Broadcasting 4 events.
                                [02.01.2021 14:46.35.400] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                [02.01.2021 14:48.32.644] [INFO]  Newsfeed-Fetcher: Broadcasting 10 items.
                                ipWhitelist: [],
                                	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120",],
                                	language: 'en',
                                	timeFormat: 24,
                                I guess changing it to logLevel: [] ?
                                  @Richard238 all of the messages are normal.
                                  maybe u started w pm2 before
                                    @Richard238 just FYI we were able to reproduce your problem on Jessie. So os upgrade, or downgrade electron were the only options
                                      Rebooted, no change. Not a worry, just curious.
                                      How though do I get MM to auto start at boot?
                                        @Richard238 use pm2, u should have been prompted during my scripted install.
                                        but use the fixuppm2 instructions here, last entry on the page
                                          Does that mean a change to the documentation, or have the install/update script(s) check for OS level before proceeding? (Or both, of course.)
                                          There must be many, many MM installs out there running on old OSs.
                                            @Richard238 i will update my scripts to check and advise.
                                            but my scripts are optional. I doubt the base will check. technically only supports pi3 and 4, but I try to make it to run anywhere
                                            • 3 / 4
