    Config for clock not working
    6 Posts 5 Posters 7.2k Views 4 Watching
    • R
      robsch
      Hello folks,
      I know I am doing something dumb. Everything else is working, though my clock is not taking the config: { section. I am trying to change it to 12 hour format (for WAF) and remove the seconds and add a lowercase am/pm.
      Thanks for any suggestions and help!
      Here is my config file :
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
              port: 8080,
              language: 'en',
              units: 'Imperial',
                              module: 'clock',
                              position: 'top_left',
                                       timeformat: 12,
                                       showPeriod: 'true',
                                       displaySeconds: 'false',
                              module: 'alert',
                              module: 'MMM-wordnik',
                              position: 'lower_third',
                                       api_key: '',
                              module: 'MMM-Traffic',
                              classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                                       api_key: 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
                                       mode: 'driving',
                                       origin: 'xxxxxxxxxxxxxxxxxxxxxxxx',
                                       destination: 'xxxxxxxxxxxxxxxxxxxxxxxxxx',
                                       route_name: 'Home to Work',
                                       changeColor: true,
                                       showGreen: false,
                                       limitYellow: 5, //Greater than 5% of journey time due to traffic
                                       limitRed: 20, //Greater than 20% of journey time due to traffic
                                       traffic_model: 'pessimistic',
                                       interval: 120000 //2 minutes
                              module: 'MMM-Wunderlist',
                              position: 'top_center',  // This can be any of the regions. Best results in left or right regions.
                              header: 'ToDo List', // This is optional
                                         accessToken: 'xxxxxxxxxxxxxxxxxx',
                                         clientID: 'xxxxxxxxxxxxx',
                                         lists: ["inbox"],
                                         interval: 60,
                                         fade: true
                              module: 'airquality',
                              position: 'top_right', // you may choose any location
                              location: 'Philadelphia' // the location to check the index for
                              module: 'calendar',
                              header: 'Family Calendar',
                                                      symbol: 'calendar-check-o ',
                                                      url: 'webcal://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxx/basic.ics'
                              module: 'compliments',
                              module: 'currentweather',
                                      appid: 'xxxxxxxxxxxxxxxxxxxxxx'
                              module: 'weatherforecast',
                              header: 'Weather Forecast',
                              module: 'newsfeed',
                              position: 'bottom_bar',
                                      feeds: [
                                                      title: "ABC US Headlines",
                                                      url: "http://feeds.abcnews.com/abcnews/usheadlines",
                                                      title: "Bristol News",
                                                      url: "http://www.buckslocalnews.com/?rss=bristol_pilot/news",
                                      showSourceTitle: true,
                                      showPublishDate: true
      Note from admin: Please use Markdown on code snippets so it is easier to read!
      • K
        KirAsh4 Moderator
        And the console error is? Or possibly it could also be in 'pm2 logs <YOUR_MM_TASK_NAME>' …
        • R
          robsch
          @KirAsh4 When I hit <CTRL-M> for the console (which is what I assume you mean) I doesn’t give any errors. Everything is working fine. It shows all the data correctly, but the clock is in 24 hour format. It’s almost like it’s just omitting the config section, and moving on. Though it says "No helper found for the module: clock. But I am pretty sure it always has said that.
          Thanks!
          • M
            MrH
            Had the same issue. Try removing the ’ marks before and after “true” or “false”
            like this
                 displaySeconds: false,
            worked for me ;)
            Note from admin: Please use Markdown on code snippets!
            • strawberry 3.141S
              yes true and false are booleans and no strings, so you need to remove the quotes
              • M
                mochman Module Developer
                @strawberry-3-141 Try timeFormat: 12, instead of timeformat: 12,.
                Capitalization has gotten me more times that I can count.
