    Help with creating a table
    22 Posts 4 Posters 9.8k Views 4 Watching
      Schmaniel
      Hey!
      I started to work on a FACEIT module that shows up a few informations about a player.
      The API thing is done, now I need to create a table to visualize the output nicely.
      At first I created it in html/css. It should look something like this: 88aac78e-3dff-46af-9eff-8196ee11157b-grafik.png
      I started now with this code: https://pastebin.com/jK2jGmjA (only for the thead), but I think it’s too complicated.
      Do you have any ideas, how I can improve it?
      • JalibuJ
        Jalibu Module Developer
        @Schmaniel said in Help with creating a table:
        You could either use the nunjucks template engine, which is baked in the magic mirror core or you could use javascript template strings:
        let markup = `
        <table>
          <tr>
            <td>Matches</td>
            <td>${numMatches}</td>
          </tr>
        </table>
        wrapper.innerHTML = markup
          Schmaniel
          uuh, that worked pretty well, thank you!
          Now I’m stuck with the size of the module…
            sdetweil @Schmaniel
            @Schmaniel welcome to the fun. 900,000 details to consider. size color, font … css
            https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1611671889049
            S 1 Reply Last reply Reply Quote 2
              Schmaniel @sdetweil
              @sdetweil said in Help with creating a table:
              welcome to the fun.
              you misspelt nightmare…
              Thanks for your help!
                sdetweil @Schmaniel
                @Schmaniel it gives u an appreciation for the art of good user experience web pages
                  Schmaniel
                  Everytime my module do an API request to refresh the data, the table is disappearing for a second or two, this shouldn’t be normal, right?
                    sdetweil @Schmaniel
                    @Schmaniel u get new data, then say, this.updateDom(how-fast)
                    then mm calls your getDom() routine to get the new content to display
                    so, what is the number u pass to updateDom()
                    0 means immediately
                    2000 means transition new content in 2 seconds
                      Schmaniel @sdetweil
                      @sdetweil thats the code I got:
                          start: function() {
                              var self = this;
                              setInterval(function() {
                                  self.updateDom(1000);
                              }, 60000);
                      So as I understand now it updates every minute (60000) and it needs 1 second (1000) to update?
                      Should I change the 1000 to 0, so it updates immediately?
                        sdetweil @Schmaniel
                        @Schmaniel yes, 0.
                        doesnt NEED 1 second. should TAKE 1 second
                        so.u slowed it down
                          Schmaniel @sdetweil
                          @sdetweil aaaaaaaah, thank you :)
                            Schmaniel
                            After hours of testing I’m at my end…
                            Thats the result so far:
                            I want to shrink the cells down, but I can’t find a way to do it…
                            I tried it with height, line-height, padding and so on…
                            Do you have any ideas?
                              sdetweil @Schmaniel
                              @Schmaniel
                              see https://stackoverflow.com/questions/17342181/how-to-fit-html-table-row-to-its-content
                                Schmaniel @sdetweil
                                @sdetweil still no success, nothing happens with height: 0px; or
                                also because of the main.css the table is getting expanded over the whole screen
                                .region table {
                                  width: 100%;
                                  border-spacing: 0;
                                  border-collapse: separate;
                                Could it be, that the main.css is interupting something more than just the width? removed this point from the css earlier, didn’t thought about that…
                                  sdetweil @Schmaniel
                                  @Schmaniel notice its style=“height:0px;”
                                  on the ROW tr
                                  • BKeyportB
                                    BKeyport Module Developer
                                    The MMM-Multimonth module I created, and had some help re-writing, does an wonderful job of creating a table on the fly that autosizes, and you can use that to see how things work. Just a thought.
                                      Schmaniel @sdetweil
                                      @sdetweil yes, I know, but it didn’t worked Out :/
                                      @BKeyport thanks I will Look into it later!
                                        Schmaniel
                                        Thats the view with the developer console
                                          Schmaniel
                                          The problem was the p tag, but now the break is too big inbetween the lines…a1204375-c435-430d-a355-0b1c9a804bf4-grafik.png
                                            sdetweil @Schmaniel
                                            @Schmaniel paragraph AND a line break?
                                            too much space ?
                                            come on man.
                                            thats why they creared div and span
