    Help with creating a table
    22 Posts 4 Posters 6.9k Views 4 Watching
      Schmaniel
      Hey!
      I started to work on a FACEIT module that shows up a few informations about a player.
      The API thing is done, now I need to create a table to visualize the output nicely.
      At first I created it in html/css. It should look something like this: 88aac78e-3dff-46af-9eff-8196ee11157b-grafik.png
      I started now with this code: https://pastebin.com/jK2jGmjA (only for the thead), but I think it’s too complicated.
      Do you have any ideas, how I can improve it?
      • JalibuJ Offline
        Jalibu Module Developer
        @Schmaniel said in Help with creating a table:
        You could either use the nunjucks template engine, which is baked in the magic mirror core or you could use javascript template strings:
        let markup = `
        <table>
          <tr>
            <td>Matches</td>
            <td>${numMatches}</td>
          </tr>
        </table>
        wrapper.innerHTML = markup
          Schmaniel
          uuh, that worked pretty well, thank you!
          Now I’m stuck with the size of the module…
            sdetweil @Schmaniel
            @Schmaniel welcome to the fun. 900,000 details to consider. size color, font … css
            https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1611671889049
              Schmaniel @sdetweil
              @sdetweil said in Help with creating a table:
              welcome to the fun.
              you misspelt nightmare…
              Thanks for your help!
                sdetweil @Schmaniel
                @Schmaniel it gives u an appreciation for the art of good user experience web pages
                  Schmaniel
                  Everytime my module do an API request to refresh the data, the table is disappearing for a second or two, this shouldn’t be normal, right?
                    sdetweil @Schmaniel
                    @Schmaniel u get new data, then say, this.updateDom(how-fast)
                    then mm calls your getDom() routine to get the new content to display
                    so, what is the number u pass to updateDom()
                    0 means immediately
                    2000 means transition new content in 2 seconds
                      Schmaniel @sdetweil
                      @sdetweil thats the code I got:
                          start: function() {
                              var self = this;
                              setInterval(function() {
                                  self.updateDom(1000);
                              }, 60000);
                      So as I understand now it updates every minute (60000) and it needs 1 second (1000) to update?
                      Should I change the 1000 to 0, so it updates immediately?
                        sdetweil @Schmaniel
                        @Schmaniel yes, 0.
                        doesnt NEED 1 second. should TAKE 1 second
                        so.u slowed it down
