    Help with creating a table
    22 Posts 4 Posters 9.4k Views 4 Watching
      Schmaniel
      Everytime my module do an API request to refresh the data, the table is disappearing for a second or two, this shouldn’t be normal, right?
        sdetweil @Schmaniel
        @Schmaniel u get new data, then say, this.updateDom(how-fast)
        then mm calls your getDom() routine to get the new content to display
        so, what is the number u pass to updateDom()
        0 means immediately
        2000 means transition new content in 2 seconds
          Schmaniel @sdetweil
          @sdetweil thats the code I got:
              start: function() {
                  var self = this;
                  setInterval(function() {
                      self.updateDom(1000);
                  }, 60000);
          So as I understand now it updates every minute (60000) and it needs 1 second (1000) to update?
          Should I change the 1000 to 0, so it updates immediately?
            sdetweil @Schmaniel
            @Schmaniel yes, 0.
            doesnt NEED 1 second. should TAKE 1 second
            so.u slowed it down
              Schmaniel @sdetweil
              @sdetweil aaaaaaaah, thank you :)
                Schmaniel
                After hours of testing I’m at my end…
                Thats the result so far:
                I want to shrink the cells down, but I can’t find a way to do it…
                I tried it with height, line-height, padding and so on…
                Do you have any ideas?
                  sdetweil @Schmaniel
                  @Schmaniel
                  see https://stackoverflow.com/questions/17342181/how-to-fit-html-table-row-to-its-content
                    Schmaniel @sdetweil
                    @sdetweil still no success, nothing happens with height: 0px; or
                    also because of the main.css the table is getting expanded over the whole screen
                    .region table {
                      width: 100%;
                      border-spacing: 0;
                      border-collapse: separate;
                    Could it be, that the main.css is interupting something more than just the width? removed this point from the css earlier, didn’t thought about that…
                      sdetweil @Schmaniel
                      @Schmaniel notice its style=“height:0px;”
                      on the ROW tr
                      • BKeyportB Offline
                        BKeyport Module Developer
                        The MMM-Multimonth module I created, and had some help re-writing, does an wonderful job of creating a table on the fly that autosizes, and you can use that to see how things work. Just a thought.
                          Schmaniel @sdetweil
                          @sdetweil yes, I know, but it didn’t worked Out :/
                          @BKeyport thanks I will Look into it later!
                            Schmaniel
                            Thats the view with the developer console
                              Schmaniel
                              The problem was the p tag, but now the break is too big inbetween the lines…a1204375-c435-430d-a355-0b1c9a804bf4-grafik.png
                                sdetweil @Schmaniel
                                @Schmaniel paragraph AND a line break?
                                too much space ?
                                come on man.
                                thats why they creared div and span
                                  Schmaniel @sdetweil
                                  @sdetweil hahaha, worked with line-height and span style=display now…
                                  Im pretty happy with the results now:
                                  Just need to calculate the HTLV ratio, but thats another problem I have to solve myself :)
                                    sdetweil @Schmaniel
                                    @Schmaniel good
                                    and if u set a class instead of the individual styles then u can change them in custom.css without changing the code and fiddle w them in the elements view of the dev env to get them like u want 1st…
