    Help with creating a table
    22 Posts 4 Posters 9.3k Views 4 Watching
      Schmaniel @sdetweil
      @sdetweil thats the code I got:
          start: function() {
              var self = this;
              setInterval(function() {
                  self.updateDom(1000);
              }, 60000);
      So as I understand now it updates every minute (60000) and it needs 1 second (1000) to update?
      Should I change the 1000 to 0, so it updates immediately?
        sdetweil @Schmaniel
        @Schmaniel yes, 0.
        doesnt NEED 1 second. should TAKE 1 second
        so.u slowed it down
          Schmaniel @sdetweil
          @sdetweil aaaaaaaah, thank you :)
            Schmaniel
            After hours of testing I’m at my end…
            Thats the result so far:
            I want to shrink the cells down, but I can’t find a way to do it…
            I tried it with height, line-height, padding and so on…
            Do you have any ideas?
              sdetweil @Schmaniel
              @Schmaniel
              see https://stackoverflow.com/questions/17342181/how-to-fit-html-table-row-to-its-content
                Schmaniel @sdetweil
                @sdetweil still no success, nothing happens with height: 0px; or
                also because of the main.css the table is getting expanded over the whole screen
                .region table {
                  width: 100%;
                  border-spacing: 0;
                  border-collapse: separate;
                Could it be, that the main.css is interupting something more than just the width? removed this point from the css earlier, didn’t thought about that…
                  sdetweil @Schmaniel
                  @Schmaniel notice its style=“height:0px;”
                  on the ROW tr
                  • BKeyportB Offline
                    BKeyport Module Developer
                    The MMM-Multimonth module I created, and had some help re-writing, does an wonderful job of creating a table on the fly that autosizes, and you can use that to see how things work. Just a thought.
                      Schmaniel @sdetweil
                      @sdetweil yes, I know, but it didn’t worked Out :/
                      @BKeyport thanks I will Look into it later!
                        Schmaniel
                        Thats the view with the developer console
                          Schmaniel
                          The problem was the p tag, but now the break is too big inbetween the lines…a1204375-c435-430d-a355-0b1c9a804bf4-grafik.png
                            sdetweil @Schmaniel
                            @Schmaniel paragraph AND a line break?
                            too much space ?
                            come on man.
                            thats why they creared div and span
                              Schmaniel @sdetweil
                              @sdetweil hahaha, worked with line-height and span style=display now…
                              Im pretty happy with the results now:
                              Just need to calculate the HTLV ratio, but thats another problem I have to solve myself :)
                                sdetweil @Schmaniel
                                @Schmaniel good
                                and if u set a class instead of the individual styles then u can change them in custom.css without changing the code and fiddle w them in the elements view of the dev env to get them like u want 1st…
