    Help with creating a table
    22 Posts 4 Posters 9.4k Views 4 Watching
      Schmaniel @sdetweil
      @sdetweil said in Help with creating a table:
      welcome to the fun.
      you misspelt nightmare…
      Thanks for your help!
        sdetweil @Schmaniel
        @Schmaniel it gives u an appreciation for the art of good user experience web pages
          Schmaniel
          Everytime my module do an API request to refresh the data, the table is disappearing for a second or two, this shouldn’t be normal, right?
            sdetweil @Schmaniel
            @Schmaniel u get new data, then say, this.updateDom(how-fast)
            then mm calls your getDom() routine to get the new content to display
            so, what is the number u pass to updateDom()
            0 means immediately
            2000 means transition new content in 2 seconds
              Schmaniel @sdetweil
              @sdetweil thats the code I got:
                  start: function() {
                      var self = this;
                      setInterval(function() {
                          self.updateDom(1000);
                      }, 60000);
              So as I understand now it updates every minute (60000) and it needs 1 second (1000) to update?
              Should I change the 1000 to 0, so it updates immediately?
                sdetweil @Schmaniel
                @Schmaniel yes, 0.
                doesnt NEED 1 second. should TAKE 1 second
                so.u slowed it down
                  Schmaniel @sdetweil
                  @sdetweil aaaaaaaah, thank you :)
                    Schmaniel
                    After hours of testing I’m at my end…
                    Thats the result so far:
                    I want to shrink the cells down, but I can’t find a way to do it…
                    I tried it with height, line-height, padding and so on…
                    Do you have any ideas?
                      sdetweil @Schmaniel
                      @Schmaniel
                      see https://stackoverflow.com/questions/17342181/how-to-fit-html-table-row-to-its-content
                        Schmaniel @sdetweil
                        @sdetweil still no success, nothing happens with height: 0px; or
                        also because of the main.css the table is getting expanded over the whole screen
                        .region table {
                          width: 100%;
                          border-spacing: 0;
                          border-collapse: separate;
                        Could it be, that the main.css is interupting something more than just the width? removed this point from the css earlier, didn’t thought about that…
                          sdetweil @Schmaniel
                          @Schmaniel notice its style=“height:0px;”
                          on the ROW tr
                          • BKeyportB Online
                            BKeyport Module Developer
                            The MMM-Multimonth module I created, and had some help re-writing, does an wonderful job of creating a table on the fly that autosizes, and you can use that to see how things work. Just a thought.
                              Schmaniel @sdetweil
                              @sdetweil yes, I know, but it didn’t worked Out :/
                              @BKeyport thanks I will Look into it later!
                                Schmaniel
                                Thats the view with the developer console
                                  Schmaniel
                                  The problem was the p tag, but now the break is too big inbetween the lines…a1204375-c435-430d-a355-0b1c9a804bf4-grafik.png
                                    sdetweil @Schmaniel
                                    @Schmaniel paragraph AND a line break?
                                    too much space ?
                                    come on man.
                                    thats why they creared div and span
                                      Schmaniel @sdetweil
                                      @sdetweil hahaha, worked with line-height and span style=display now…
                                      Im pretty happy with the results now:
                                      Just need to calculate the HTLV ratio, but thats another problem I have to solve myself :)
                                        sdetweil @Schmaniel
                                        @Schmaniel good
                                        and if u set a class instead of the individual styles then u can change them in custom.css without changing the code and fiddle w them in the elements view of the dev env to get them like u want 1st…
