    Starter problem
    73 Posts 8 Posters 82.3k Views 5 Watching
    • K Offline
      kurt @yawns
      @yawns
      Sorry didn’t happen,
      he refused “cowardly or yellow” this is the translation I found, to create an empty archiv.
      pi@raspberrypi:~/MagicMirror $ tar -cvf mirror.tar/MagicMirror
      tar: Anlegen eines leeren Archivs wird feige verweigert.
      „tar --help“ oder „tar --usage“ gibt weitere Informationen.
      in_a_daysI 1 Reply Last reply Reply Quote 0
      • in_a_daysI Offline
        in_a_days @kurt
        @kurt
        Two things -
        1. You’re in the MagicMirror directory. Type this:
        cd ~
        1. You need a space here:
        should be
        tar -cvf mirror.tar /MagicMirror
        What ship would bear me ever back across so wide a Sea?
        K 2 Replies Last reply Reply Quote 0
        • K Offline
          kurt @in_a_days
          @in_a_days
          sorry but if I write just
          pi@raspberrypi:~ $ cd ~
          nothing happens
            in_a_days @kurt
            @kurt
            That’s okay! You’re in the right folder now :)
            In the previous post your command prompt looked like this:
            Which shows you in the MagicMirror directory. But if your command prompt now looks like this:
            pi@raspberrypi:~ $
            Then you are back in the correct ‘~’ folder and you can proceed to step 2.
            • K Offline
              kurt @in_a_days
              @in_a_days said in Starter problem:
              this is what I get:
              pi@raspberrypi:~ $ tar -cvf mirror.tar /MagicMirror
              tar: Entferne führende „/“ von Elementnamen
              tar: /MagicMirror: Funktion stat fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
              tar: Beende mit Fehlerstatus aufgrund vorheriger Fehler
              What do you think?
              Thank you
                in_a_days @kurt
                @kurt
                I apologize, I have not used the tar command before. Remove the ‘/’ before MagicMirror. Try:
                tar -cvf mirror.tar MagicMirror
                • K Offline
                  kurt @in_a_days
                  @in_a_days
                  Thank you everything went qicker than the eye…
                  what is the name of the file, it should be outside of the MM file in the pi file?
                    in_a_days @kurt
                    @kurt
                    Great! I’m still very new to this and I’m not using FTP. But there should now be a file named ‘mirror.tar’ in your ‘pi’ directory.
                    • K Offline
                      kurt @in_a_days
                      @in_a_days
                      seems to be well hidden, wherever it is…hmm
                      couldn’t find it
                        in_a_days @kurt
                        @kurt
                        From the ~ folder:
                        pi@raspberrypi:~ $
                        type
                        ls
                        Do you see the mirror.tar file listed there?
                        • 6
                        • 7
                        • 8
                        • 6 / 8
