    Starter problem
    73 Posts 8 Posters 86.4k Views 5 Watching
    • K Offline
      kurt @strawberry 3.141
      @strawberry-3.141
      Hallo strawberry
      Can you pleas tell me whats wrong with my config.js
      By now nothing is shown. I wanted to impement the W.Linien modul, but also the weatherforcast was not shown.
      Thank you in advance
      Kurt
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
      	language: 'de',
      	timeFormat: 24,
      	units: 'metric',
                            module: "MMM-WienerLinien",
                                 api_key: "NZXDPzyd3QsAtTCT",
                                 stations: ["142", "141"],
      			module: 'alert',
      			module: "updatenotification",
      			position: "top_bar"
      			module: 'clock',
      			position: 'top_left'
      			module: 'compliments',
      			position: 'lower_third'
      			module: 'currentweather',
      			position: 'top_right',
      				locationID: '',  //ID from http://www.openweathermap.org
      				appid: 'xxxxxxxxxxxxxxxxxxx'
      			module: 'weatherforecast',
      			header: 'Das Wetter',
      				locationID: '5128581',  //ID from http://www.openweathermap.org
      			module: 'newsfeed',
      			position: 'bottom_bar',
      				feeds: [
      						title: "Der Standard",
      						url: "http://derstandard.at/?page=rss&ressort=Seite1"
      				showSourceTitle: true,
      				showPublishDate: true
      Note from admin: Please use Markdown on code snippets for easier reading!
      in_a_daysI 2 Replies Last reply Reply Quote 0
      • in_a_daysI Offline
        in_a_days @kurt
        @kurt
        You’re missing a } here
                           api_key: "xxxxxxxxxxx",
        should be
        Could be other issues, but check that out first :)
        What ship would bear me ever back across so wide a Sea?
        K FrühstückF 2 Replies Last reply Reply Quote 2
          in_a_days @kurt
          @kurt
          Also, it’s a good idea to remove your personal API codes when sharing your config file(s).
          • K Offline
            kurt @in_a_days
            Thank you @in_a_days
            I copied your answer into the right place, but the screen stays black.
            in_a_daysI 1 Reply Last reply Reply Quote 0
              in_a_days @kurt
              @kurt
              You’re welcome, did you re-start the mirror program after changing the config file?
              • K Offline
                kurt @in_a_days
                @in_a_days
                Yes with strg R on the raspi
                  in_a_days @kurt
                  @kurt
                  Hmm. I’ll test your config.js on my system and see if I can isolate the problem.
                  • K Offline
                    kurt @in_a_days
                    @in_a_days
                    wow thanks a lot
                    • yawnsY Offline
                      yawns Moderator
                      Did you run npm install in the MMM-WienerLinien folder?
                      • K Offline
                        kurt @yawns
                        @yawns
                        no ! how can I do this?
                          in_a_days @kurt
                          @kurt
                          From a new terminal session:
                          cd MagicMirror/modules/MMM-WienerLinien
                          npm install
                          • K Offline
                            kurt @in_a_days
                            @in_a_days
                            the installation went well, but when I try to reboot the booting logo appears shortly, but thats it.
                            But into the MM folder there are two config folder now, one .config and one config
                            Either I didn’t recogbize that bevor, or one is new.
                              in_a_days @kurt
                              @kurt
                              Just wanted to check in. I tried to copy the config.js you posted and I had some problems as well. I’m a bit busy today, but I have some ideas and if you’re still stuck I’ll try to have a solution for you tomorrow. :)
                              • K Offline
                                kurt
                                Hallo
                                Has somebody an idea to help?
                                The internet connection is fine, cause the rss from the Ney York Times is shown.
                                kurt
                                > magicmirror@2.1.0 start /home/pi/MagicMirror
                                > electron js/electron.js
                                Starting MagicMirror: v2.1.0
                                Loading config ...
                                Loading module helpers ...
                                All module helpers loaded.
                                Starting server op port 8080 ...
                                Server started ...
                                Starting module: newsfeed
                                { Error: listen EADDRINUSE :::8080
                                    at Object.exports._errnoException (util.js:1026:11)
                                    at exports._exceptionWithHostPort (util.js:1049:20)
                                    at Server._listen2 (net.js:1253:14)
                                    at listen (net.js:1289:10)
                                    at net.js:1399:9
                                    at _combinedTickCallback (internal/process/next_tick.js:77:11)
                                    at process._tickCallback (internal/process/next_tick.js:98:9)
                                    at Module.runMain (module.js:592:11)
                                    at run (bootstrap_node.js:402:7)
                                    at startup (bootstrap_node.js:157:9)
                                  code: 'EADDRINUSE',
                                  errno: 'EADDRINUSE',
                                  syscall: 'listen',
                                  address: '::',
                                  port: 8080 }
                                Launching application.
                                • strawberry 3.141S Offline
                                  strawberry 3.141 Project Sponsor Module Developer @kurt
                                  @kurt this means probably that there is already an instance of magicmirror running on your pi because the port is already used
                                  • K Offline
                                    @strawberry-3.141
                                    Thank you strawberry, but how about this now?
                                    pi@raspberrypi:~ $ DISPLAY=:0 npm start
                                    npm ERR! Linux 4.4.38-v7+
                                    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                                    npm ERR! node v6.9.4
                                    npm ERR! npm  v3.10.10
                                    npm ERR! path /home/pi/package.json
                                    npm ERR! code ENOENT
                                    npm ERR! errno -2
                                    npm ERR! syscall open
                                    npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                    npm ERR! enoent This is most likely not a problem with npm itself
                                    npm ERR! enoent and is related to npm not being able to find a file.
                                    npm ERR! enoent
                                    npm ERR!     /home/pi/npm-debug.log
                                      @kurt you are in the wrong directory again :D
                                      cd ~MagicMirror first
                                      • K Offline
                                        @strawberry-3.141
                                        Sorry , but now get the starting logo with the" Please create a config file"
                                        Thank you
                                        pi@raspberrypi:~ $ cd ~/MagicMirror
                                        pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
                                        Loading config ...
                                        WARNING! Could not find config file. Please create one. Starting with default configuration.
                                        No helper found for module: helloworld.
                                        Server started ...
                                          @kurt are you sure you have a config file in /home/pi/MagicMirror/config
                                          K 2 Replies Last reply Reply Quote 0
                                          • K Offline
                                            @strawberry-3.141 I’m allready working on that mistake.
                                            you a right, don’t know who took this fike from that place.
                                            Change the config, file and place over there.
                                            Mystery…
                                            Kurt
                                            • 2 / 4
