    Starter problem
    73 Posts 8 Posters 89.7k Views 5 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @kurt
      @kurt im using filezilla or an usb stick
      • K Offline
        kurt @strawberry 3.141
        @strawberry-3.141
        Anyway, I copied the folder again to the pi.
        calender, changed compliments and newsfeed appear.
        Do you have an idea, why the weather and the forecast dont show?
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: 'de',
        	timeFormat: 24,
        	units: 'metric',
        			module: 'alert',
        			module: "updatenotification",
        			position: "top_bar"
        			module: 'clock',
        			position: 'top_left'
        			module: 'calendar',
        			header: 'US Holidays',
        			position: 'top_left',
        						symbol: 'calendar-check-o ',
        			module: 'compliments',
        			position: 'lower_third'
        			module: 'currentweather',
        			position: 'top_right',
        				locationID: '2761369',  //ID from http://www.openweathermap.org
        				appid: 'xxxxxxxxxxxxxxxxxx'
        			module: 'weatherforecast',
        			header: 'Das Wetter',
        				appid: 'xxxxxxxxxxxxxxxxx'
        			module: 'newsfeed',
        			position: 'bottom_bar',
        				feeds: [
        						title: "Der Standard",
        						url: "http://derStandard.at/?page=rss&ressort=Seite1"
        				showSourceTitle: true,
        				showPublishDate: true
          @kurt do you get any errors in the terminal, maybe your api key is incorrect etc.
          • K Offline
            @strawberry-3.141 Thank you for todays help, can’t find the reason,
            and no, I get no messages.
            Thanks a lot
            • K Offline
              kurt @in_a_days
              @in_a_days
              Thank’s a lot for your help, but strawberry allready repaired my mistakes, so by now i’m fine, just thinking about what is the best way to save such a running system, so I can go back when things go wrong and I found out things go very quick wrong :)
              So have a nice day and Thank you
              • Y Offline
                yawns Moderator @kurt
                @kurt
                I would create an archive of the entire magicmirror folder.
                cd ~
                tar -cvf mirror.tar /MagicMirror
                • K Offline
                  kurt @yawns
                  @yawns
                  this is on the Raspi and on which place will he make the archiv ?
                  And to save it outside the best way is? I#m using Filzilla is this a right tool for this plan?
                  • Y Offline
                    @kurt
                    This command will create a file called mirror.tar in your home directory on your raspberry. You can copy/transfer it to your computer with filezilla, the same way you did to copy new files to your raspberry
                    K 3 Replies Last reply Reply Quote 0
                    • K Offline
                      kurt @yawns
                      @yawns
                      perfekt
                      thank you, I better bring my sheeps to a save place :)
                      • K Offline
                        kurt @yawns
                        @yawns
                        Sorry didn’t happen,
                        he refused “cowardly or yellow” this is the translation I found, to create an empty archiv.
                        pi@raspberrypi:~/MagicMirror $ tar -cvf mirror.tar/MagicMirror
                        tar: Anlegen eines leeren Archivs wird feige verweigert.
                        „tar --help“ oder „tar --usage“ gibt weitere Informationen.
                        • I Offline
                          in_a_days @kurt
                          @kurt
                          Two things -
                          1. You’re in the MagicMirror directory. Type this:
                          cd ~
                          1. You need a space here:
                          should be
                          K 2 Replies Last reply Reply Quote 0
                          • K Offline
                            kurt @in_a_days
                            @in_a_days
                            sorry but if I write just
                            pi@raspberrypi:~ $ cd ~
                            nothing happens
                            • I Offline
                              in_a_days @kurt
                              @kurt
                              That’s okay! You’re in the right folder now :)
                              In the previous post your command prompt looked like this:
                              Which shows you in the MagicMirror directory. But if your command prompt now looks like this:
                              pi@raspberrypi:~ $
                              Then you are back in the correct ‘~’ folder and you can proceed to step 2.
                              • K Offline
                                kurt @in_a_days
                                @in_a_days said in Starter problem:
                                this is what I get:
                                pi@raspberrypi:~ $ tar -cvf mirror.tar /MagicMirror
                                tar: Entferne führende „/“ von Elementnamen
                                tar: /MagicMirror: Funktion stat fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                tar: Beende mit Fehlerstatus aufgrund vorheriger Fehler
                                What do you think?
                                Thank you
                                • I Offline
                                  in_a_days @kurt
                                  @kurt
                                  I apologize, I have not used the tar command before. Remove the ‘/’ before MagicMirror. Try:
                                  tar -cvf mirror.tar MagicMirror
                                  • K Offline
                                    kurt @in_a_days
                                    @in_a_days
                                    Thank you everything went qicker than the eye…
                                    what is the name of the file, it should be outside of the MM file in the pi file?
                                    • I Offline
                                      in_a_days @kurt
                                      @kurt
                                      Great! I’m still very new to this and I’m not using FTP. But there should now be a file named ‘mirror.tar’ in your ‘pi’ directory.
                                      • K Offline
                                        kurt @in_a_days
                                        @in_a_days
                                        seems to be well hidden, wherever it is…hmm
                                        couldn’t find it
                                        • I Offline
                                          in_a_days @kurt
                                          @kurt
                                          From the ~ folder:
                                          pi@raspberrypi:~ $
                                          type
                                          ls
                                          Do you see the mirror.tar file listed there?
                                          • K Offline
                                            kurt @in_a_days
                                            @in_a_days
                                            here we are :)
                                            pi@raspberrypi:~ $ ls
                                            Bilder     Dokumente    mirror.tar  npm-debug.log  python_games  Videos
                                            Desktop    Downloads    Music       oldconffiles   Scratch
                                            Documents  MagicMirror  Musik       Public         Templates
                                            but isn’t shown in Filezilla directory
                                            should be in Bilder Dokumente mirror.tar ? right?
                                            the path is not quite clear for me
                                            not that easy…Thanks a lot for your time in_a_days
                                            I B 2 Replies Last reply Reply Quote 0
                                            • 3 / 4
