    Starter problem
    73 Posts 8 Posters 90.3k Views 5 Watching
    • K Offline
      kurt
      Hallo
      Has somebody an idea to help?
      The internet connection is fine, cause the rss from the Ney York Times is shown.
      Thank you in advance
      kurt
      > magicmirror@2.1.0 start /home/pi/MagicMirror
      > electron js/electron.js
      Starting MagicMirror: v2.1.0
      Loading config ...
      Loading module helpers ...
      All module helpers loaded.
      Starting server op port 8080 ...
      Server started ...
      Starting module: newsfeed
      { Error: listen EADDRINUSE :::8080
          at Object.exports._errnoException (util.js:1026:11)
          at exports._exceptionWithHostPort (util.js:1049:20)
          at Server._listen2 (net.js:1253:14)
          at listen (net.js:1289:10)
          at net.js:1399:9
          at _combinedTickCallback (internal/process/next_tick.js:77:11)
          at process._tickCallback (internal/process/next_tick.js:98:9)
          at Module.runMain (module.js:592:11)
          at run (bootstrap_node.js:402:7)
          at startup (bootstrap_node.js:157:9)
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '::',
        port: 8080 }
      Launching application.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @kurt
        @kurt this means probably that there is already an instance of magicmirror running on your pi because the port is already used
        • K Offline
          kurt @strawberry 3.141
          @strawberry-3.141
          Thank you strawberry, but how about this now?
          pi@raspberrypi:~ $ DISPLAY=:0 npm start
          npm ERR! Linux 4.4.38-v7+
          npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
          npm ERR! node v6.9.4
          npm ERR! npm  v3.10.10
          npm ERR! code ENOENT
          npm ERR! errno -2
          npm ERR! syscall open
          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          npm ERR! enoent This is most likely not a problem with npm itself
          npm ERR! enoent and is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR!     /home/pi/npm-debug.log
            @kurt you are in the wrong directory again :D
            cd ~MagicMirror first
            • K Offline
              @strawberry-3.141
              Sorry , but now get the starting logo with the" Please create a config file"
              Thank you
              pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
              Loading config ...
              WARNING! Could not find config file. Please create one. Starting with default configuration.
              No helper found for module: helloworld.
              Server started ...
                @kurt are you sure you have a config file in /home/pi/MagicMirror/config
                K 2 Replies Last reply Reply Quote 0
                • K Offline
                  @strawberry-3.141 I’m allready working on that mistake.
                  you a right, don’t know who took this fike from that place.
                  Change the config, file and place over there.
                  Mystery…
                  Kurt
                  • K Offline
                    @strawberry-3.141
                    I’m working with File Zilla to transfer the files.
                    By now I guess he the one who makes the config folder dissapear. Have you ever heard of something like that? or can you recommend an other tool to upload files? I tried Cyberduck, but won’t work.
                      @kurt im using filezilla or an usb stick
                      • K Offline
                        @strawberry-3.141
                        Anyway, I copied the folder again to the pi.
                        calender, changed compliments and newsfeed appear.
                        Do you have an idea, why the weather and the forecast dont show?
                        /* Magic Mirror Config Sample
                         * MIT Licensed.
                        var config = {
                        	port: 8080,
                        	language: 'de',
                        	timeFormat: 24,
                        	units: 'metric',
                        			module: 'alert',
                        			module: "updatenotification",
                        			position: "top_bar"
                        			module: 'clock',
                        			position: 'top_left'
                        			module: 'calendar',
                        			header: 'US Holidays',
                        			position: 'top_left',
                        						symbol: 'calendar-check-o ',
                        			module: 'compliments',
                        			position: 'lower_third'
                        			module: 'currentweather',
                        			position: 'top_right',
                        				locationID: '2761369',  //ID from http://www.openweathermap.org
                        				appid: 'xxxxxxxxxxxxxxxxxx'
                        			module: 'weatherforecast',
                        			header: 'Das Wetter',
                        				appid: 'xxxxxxxxxxxxxxxxx'
                        			module: 'newsfeed',
                        			position: 'bottom_bar',
                        				feeds: [
                        						title: "Der Standard",
                        						url: "http://derStandard.at/?page=rss&ressort=Seite1"
                        				showSourceTitle: true,
                        				showPublishDate: true
                          @kurt do you get any errors in the terminal, maybe your api key is incorrect etc.
                          • K Offline
                            @strawberry-3.141 Thank you for todays help, can’t find the reason,
                            and no, I get no messages.
                            Thanks a lot
                            • K Offline
                              kurt @in_a_days
                              @in_a_days
                              Thank’s a lot for your help, but strawberry allready repaired my mistakes, so by now i’m fine, just thinking about what is the best way to save such a running system, so I can go back when things go wrong and I found out things go very quick wrong :)
                              So have a nice day and Thank you
                              • Y Offline
                                yawns Moderator @kurt
                                @kurt
                                I would create an archive of the entire magicmirror folder.
                                cd ~
                                tar -cvf mirror.tar /MagicMirror
                                • K Offline
                                  kurt @yawns
                                  @yawns
                                  this is on the Raspi and on which place will he make the archiv ?
                                  And to save it outside the best way is? I#m using Filzilla is this a right tool for this plan?
                                  • Y Offline
                                    @kurt
                                    This command will create a file called mirror.tar in your home directory on your raspberry. You can copy/transfer it to your computer with filezilla, the same way you did to copy new files to your raspberry
                                    K 3 Replies Last reply Reply Quote 0
                                    • K Offline
                                      kurt @yawns
                                      @yawns
                                      perfekt
                                      thank you, I better bring my sheeps to a save place :)
                                      • K Offline
                                        kurt @yawns
                                        @yawns
                                        Sorry didn’t happen,
                                        he refused “cowardly or yellow” this is the translation I found, to create an empty archiv.
                                        pi@raspberrypi:~/MagicMirror $ tar -cvf mirror.tar/MagicMirror
                                        tar: Anlegen eines leeren Archivs wird feige verweigert.
                                        „tar --help“ oder „tar --usage“ gibt weitere Informationen.
                                        • I Offline
                                          in_a_days @kurt
                                          @kurt
                                          Two things -
                                          1. You’re in the MagicMirror directory. Type this:
                                          cd ~
                                          1. You need a space here:
                                          should be
                                          • K Offline
                                            kurt @in_a_days
                                            @in_a_days
                                            sorry but if I write just
                                            nothing happens
                                            • 3 / 4
