    Starter problem
    73 Posts 8 Posters 92.0k Views 5 Watching
    • K
      kurt @strawberry 3.141
      @strawberry-3.141
      Thank you strawberry, but how about this now?
      pi@raspberrypi:~ $ DISPLAY=:0 npm start
      npm ERR! Linux 4.4.38-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      npm ERR! node v6.9.4
      npm ERR! npm  v3.10.10
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/npm-debug.log
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @kurt
        @kurt you are in the wrong directory again :D
        cd ~MagicMirror first
        K 1 Reply Last reply
        • K
          @strawberry-3.141
          Sorry , but now get the starting logo with the" Please create a config file"
          Thank you
          pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
          > magicmirror@2.1.0 start /home/pi/MagicMirror
          > electron js/electron.js
          Starting MagicMirror: v2.1.0
          Loading config ...
          WARNING! Could not find config file. Please create one. Starting with default configuration.
          Loading module helpers ...
          No helper found for module: helloworld.
          All module helpers loaded.
          Starting server op port 8080 ...
          Server started ...
          Launching application.
          • strawberry 3.141S
            @kurt are you sure you have a config file in /home/pi/MagicMirror/config
            K 2 Replies Last reply
            • K
              @strawberry-3.141 I’m allready working on that mistake.
              you a right, don’t know who took this fike from that place.
              Change the config, file and place over there.
              Mystery…
              Kurt
              • K
                @strawberry-3.141
                I’m working with File Zilla to transfer the files.
                By now I guess he the one who makes the config folder dissapear. Have you ever heard of something like that? or can you recommend an other tool to upload files? I tried Cyberduck, but won’t work.
                • strawberry 3.141S
                  @kurt im using filezilla or an usb stick
                  • K
                    @strawberry-3.141
                    Anyway, I copied the folder again to the pi.
                    calender, changed compliments and newsfeed appear.
                    Do you have an idea, why the weather and the forecast dont show?
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: 'de',
                    	timeFormat: 24,
                    	units: 'metric',
                    			module: 'alert',
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: 'clock',
                    			position: 'top_left'
                    			module: 'calendar',
                    			header: 'US Holidays',
                    			position: 'top_left',
                    						symbol: 'calendar-check-o ',
                    			module: 'compliments',
                    			position: 'lower_third'
                    			module: 'currentweather',
                    			position: 'top_right',
                    				locationID: '2761369',  //ID from http://www.openweathermap.org
                    				appid: 'xxxxxxxxxxxxxxxxxx'
                    			module: 'weatherforecast',
                    			header: 'Das Wetter',
                    				appid: 'xxxxxxxxxxxxxxxxx'
                    			module: 'newsfeed',
                    			position: 'bottom_bar',
                    				feeds: [
                    						title: "Der Standard",
                    						url: "http://derStandard.at/?page=rss&ressort=Seite1"
                    				showSourceTitle: true,
                    				showPublishDate: true
                    • strawberry 3.141S
                      @kurt do you get any errors in the terminal, maybe your api key is incorrect etc.
                      • K
                        @strawberry-3.141 Thank you for todays help, can’t find the reason,
                        and no, I get no messages.
                        Thanks a lot
                        • K
                          kurt @in_a_days
                          @in_a_days
                          Thank’s a lot for your help, but strawberry allready repaired my mistakes, so by now i’m fine, just thinking about what is the best way to save such a running system, so I can go back when things go wrong and I found out things go very quick wrong :)
                          So have a nice day and Thank you
                          Y 1 Reply Last reply
                          • Y
                            yawns Moderator @kurt
                            @kurt
                            I would create an archive of the entire magicmirror folder.
                            cd ~
                            tar -cvf mirror.tar /MagicMirror
                            • K
                              kurt @yawns
                              @yawns
                              this is on the Raspi and on which place will he make the archiv ?
                              And to save it outside the best way is? I#m using Filzilla is this a right tool for this plan?
                              • Y
                                @kurt
                                This command will create a file called mirror.tar in your home directory on your raspberry. You can copy/transfer it to your computer with filezilla, the same way you did to copy new files to your raspberry
                                K 3 Replies Last reply
                                • K
                                  kurt @yawns
                                  @yawns
                                  perfekt
                                  thank you, I better bring my sheeps to a save place :)
                                  • K
                                    kurt @yawns
                                    @yawns
                                    Sorry didn’t happen,
                                    he refused “cowardly or yellow” this is the translation I found, to create an empty archiv.
                                    pi@raspberrypi:~/MagicMirror $ tar -cvf mirror.tar/MagicMirror
                                    tar: Anlegen eines leeren Archivs wird feige verweigert.
                                    „tar --help“ oder „tar --usage“ gibt weitere Informationen.
                                    I 1 Reply Last reply
                                    • I
                                      in_a_days @kurt
                                      @kurt
                                      Two things -
                                      1. You’re in the MagicMirror directory. Type this:
                                      cd ~
                                      1. You need a space here:
                                      should be
                                      • K
                                        kurt @in_a_days
                                        @in_a_days
                                        sorry but if I write just
                                        nothing happens
                                        • I
                                          in_a_days @kurt
                                          @kurt
                                          That’s okay! You’re in the right folder now :)
                                          In the previous post your command prompt looked like this:
                                          Which shows you in the MagicMirror directory. But if your command prompt now looks like this:
                                          pi@raspberrypi:~ $
                                          Then you are back in the correct ‘~’ folder and you can proceed to step 2.
                                          • K
                                            kurt @in_a_days
                                            @in_a_days said in Starter problem:
                                            this is what I get:
                                            pi@raspberrypi:~ $ tar -cvf mirror.tar /MagicMirror
                                            tar: Entferne führende „/“ von Elementnamen
                                            tar: /MagicMirror: Funktion stat fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: Beende mit Fehlerstatus aufgrund vorheriger Fehler
                                            What do you think?
                                            Thank you
                                            • 3 / 4
