    Starter problem
    73 Posts 8 Posters 88.9k Views 5 Watching
    • K Offline
      kurt @yawns
      @yawns
      perfekt
      thank you, I better bring my sheeps to a save place :)
      • K Offline
        kurt @yawns
        @yawns
        Sorry didn’t happen,
        he refused “cowardly or yellow” this is the translation I found, to create an empty archiv.
        pi@raspberrypi:~/MagicMirror $ tar -cvf mirror.tar/MagicMirror
        tar: Anlegen eines leeren Archivs wird feige verweigert.
        „tar --help“ oder „tar --usage“ gibt weitere Informationen.
        • I Offline
          in_a_days @kurt
          @kurt
          Two things -
          1. You’re in the MagicMirror directory. Type this:
          cd ~
          1. You need a space here:
          should be
          tar -cvf mirror.tar /MagicMirror
          K 2 Replies Last reply Reply Quote 0
          • K Offline
            kurt @in_a_days
            @in_a_days
            sorry but if I write just
            pi@raspberrypi:~ $ cd ~
            nothing happens
            • I Offline
              in_a_days @kurt
              @kurt
              That’s okay! You’re in the right folder now :)
              In the previous post your command prompt looked like this:
              Which shows you in the MagicMirror directory. But if your command prompt now looks like this:
              pi@raspberrypi:~ $
              Then you are back in the correct ‘~’ folder and you can proceed to step 2.
              • K Offline
                kurt @in_a_days
                @in_a_days said in Starter problem:
                this is what I get:
                pi@raspberrypi:~ $ tar -cvf mirror.tar /MagicMirror
                tar: Entferne führende „/“ von Elementnamen
                tar: /MagicMirror: Funktion stat fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                tar: Beende mit Fehlerstatus aufgrund vorheriger Fehler
                What do you think?
                Thank you
                • I Offline
                  in_a_days @kurt
                  @kurt
                  I apologize, I have not used the tar command before. Remove the ‘/’ before MagicMirror. Try:
                  tar -cvf mirror.tar MagicMirror
                  • K Offline
                    kurt @in_a_days
                    @in_a_days
                    Thank you everything went qicker than the eye…
                    what is the name of the file, it should be outside of the MM file in the pi file?
                    • I Offline
                      in_a_days @kurt
                      @kurt
                      Great! I’m still very new to this and I’m not using FTP. But there should now be a file named ‘mirror.tar’ in your ‘pi’ directory.
                      • K Offline
                        kurt @in_a_days
                        @in_a_days
                        seems to be well hidden, wherever it is…hmm
                        couldn’t find it
                        • I Offline
                          in_a_days @kurt
                          @kurt
                          From the ~ folder:
                          pi@raspberrypi:~ $
                          type
                          ls
                          Do you see the mirror.tar file listed there?
                          • K Offline
                            kurt @in_a_days
                            @in_a_days
                            here we are :)
                            pi@raspberrypi:~ $ ls
                            Bilder     Dokumente    mirror.tar  npm-debug.log  python_games  Videos
                            Desktop    Downloads    Music       oldconffiles   Scratch
                            Documents  MagicMirror  Musik       Public         Templates
                            but isn’t shown in Filezilla directory
                            should be in Bilder Dokumente mirror.tar ? right?
                            the path is not quite clear for me
                            not that easy…Thanks a lot for your time in_a_days
                            I B 2 Replies Last reply Reply Quote 0
                            • I Offline
                              in_a_days @kurt
                              @kurt
                              Happy to help! Unfortunately, this is where my knowledge ends. I’m not sure what folders you can see over Filezilla. But again make sure you are in the ~ directory and try this:
                              cp mirror.tar Dokumente
                              If you can access that Dokumente folder in Filezilla, you should now see the mirror.tar file.
                                broberg Project Sponsor @kurt
                                @kurt
                                no, Bilder and Dokumente is two different folders,
                                either it’s the first directory you get to when connecting with ftp
                                OR
                                it is in /home/pi/
                                • K Offline
                                  kurt @in_a_days
                                  @in_a_days and @broberg
                                  Thank you, not that easy to find the lost sheeps
                                  the file was in:
                                  /home/pi/Dokumente
                                  but Filezilla didn’t show the file from the start, also I refreshed…
                                  So Thanks a lot for your quick help!
                                  Kurt
                                  • K Offline
                                    kurt @yawns
                                    @yawns
                                    Hi yawns
                                    I hope you can help me, couse I managed to crash my whole MM system so I’m back on the start again. But this time I can’t even put my MM to my Raspberry. Shame on me but that’s how it is.
                                    I’m working by ssh and Filezilla, have on my pi a Folder in /tmp/magic
                                    but when I try to do
                                    scp -r /kurt/Admin/Downloads/MagicMirror-master
                                    pi@rasbpi:/tmp/magic
                                    I get this
                                    pi@raspi:~ $ scp -r /kurt/Admin/Downloads/MagicMirror-master
                                    usage: scp [-12346BCpqrv] [-c cipher] [-F ssh_config] [-i identity_file]
                                               [-l limit] [-o ssh_option] [-P port] [-S program]
                                               [[user@]host1:]file1 ... [[user@]host2:]file2
                                    pi@raspi:~ $ pi@raspi:/tmp/magic
                                    -bash: pi@raspi:/tmp/magic: Datei oder Verzeichnis nicht gefunden
                                    pi@raspi:~ $
                                    Thanks a lot in advance
                                    kurt
                                      bhepler Module Developer @kurt
                                      @kurt Your scp command didn’t go through. At a guess, you attempted to scp the entire directory and not the individual file(s). Try this instead: scp -r /kurt/Admin/Downloads/MagicMirror-master/mirror.tar
                                      • K Offline
                                        kurt @bhepler
                                        @bhepler
                                        Thank you
                                        pi@raspi:~ $ scp -r /kurt/Admin/Downloads/MagicMirror-master/mirror.tar
                                        pi@raspi:~ $
                                          @kurt Well, something’s not right with that scp command. All right, let’s do it the brute force way:
                                          cd /tmp/magic
                                          scp -rv /kurt/Admin/Downloads/MagicMirror-master/
                                          • K Offline
                                            kurt @bhepler
                                            @bhepler
                                            all right, but:
                                            pi@raspi:~ $ cd /tmp/magic
                                            pi@raspi:/tmp/magic $ scp -rv /kurt/Admin/Downloads/MagicMirror-master/
                                            • 3 / 4
