    Starter problem
    73 Posts 8 Posters 89.7k Views 5 Watching
    • I Offline
      in_a_days @kurt
      @kurt
      Two things -
      1. You’re in the MagicMirror directory. Type this:
      cd ~
      1. You need a space here:
      tar -cvf mirror.tar/MagicMirror
      should be
      tar -cvf mirror.tar /MagicMirror
      K 2 Replies Last reply Reply Quote 0
      • K Offline
        kurt @in_a_days
        @in_a_days
        sorry but if I write just
        pi@raspberrypi:~ $ cd ~
        nothing happens
        • I Offline
          in_a_days @kurt
          @kurt
          That’s okay! You’re in the right folder now :)
          In the previous post your command prompt looked like this:
          pi@raspberrypi:~/MagicMirror $
          Which shows you in the MagicMirror directory. But if your command prompt now looks like this:
          pi@raspberrypi:~ $
          Then you are back in the correct ‘~’ folder and you can proceed to step 2.
          • K Offline
            kurt @in_a_days
            @in_a_days said in Starter problem:
            this is what I get:
            pi@raspberrypi:~ $ tar -cvf mirror.tar /MagicMirror
            tar: Entferne führende „/“ von Elementnamen
            tar: /MagicMirror: Funktion stat fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
            tar: Beende mit Fehlerstatus aufgrund vorheriger Fehler
            What do you think?
            Thank you
            • I Offline
              in_a_days @kurt
              @kurt
              I apologize, I have not used the tar command before. Remove the ‘/’ before MagicMirror. Try:
              tar -cvf mirror.tar MagicMirror
              • K Offline
                kurt @in_a_days
                @in_a_days
                Thank you everything went qicker than the eye…
                what is the name of the file, it should be outside of the MM file in the pi file?
                • I Offline
                  in_a_days @kurt
                  @kurt
                  Great! I’m still very new to this and I’m not using FTP. But there should now be a file named ‘mirror.tar’ in your ‘pi’ directory.
                  • K Offline
                    kurt @in_a_days
                    @in_a_days
                    seems to be well hidden, wherever it is…hmm
                    couldn’t find it
                    • I Offline
                      in_a_days @kurt
                      @kurt
                      From the ~ folder:
                      pi@raspberrypi:~ $
                      type
                      ls
                      Do you see the mirror.tar file listed there?
                      • K Offline
                        kurt @in_a_days
                        @in_a_days
                        here we are :)
                        pi@raspberrypi:~ $ ls
                        Bilder     Dokumente    mirror.tar  npm-debug.log  python_games  Videos
                        Desktop    Downloads    Music       oldconffiles   Scratch
                        Documents  MagicMirror  Musik       Public         Templates
                        but isn’t shown in Filezilla directory
                        should be in Bilder Dokumente mirror.tar ? right?
                        the path is not quite clear for me
                        not that easy…Thanks a lot for your time in_a_days
                        I B 2 Replies Last reply Reply Quote 0
                        • I Offline
                          in_a_days @kurt
                          @kurt
                          Happy to help! Unfortunately, this is where my knowledge ends. I’m not sure what folders you can see over Filezilla. But again make sure you are in the ~ directory and try this:
                          cp mirror.tar Dokumente
                          If you can access that Dokumente folder in Filezilla, you should now see the mirror.tar file.
                            broberg Project Sponsor @kurt
                            @kurt
                            no, Bilder and Dokumente is two different folders,
                            either it’s the first directory you get to when connecting with ftp
                            OR
                            it is in /home/pi/
                            • K Offline
                              kurt @in_a_days
                              @in_a_days and @broberg
                              Thank you, not that easy to find the lost sheeps
                              the file was in:
                              /home/pi/Dokumente
                              but Filezilla didn’t show the file from the start, also I refreshed…
                              So Thanks a lot for your quick help!
                              Kurt
                              • K Offline
                                kurt @yawns
                                @yawns
                                Hi yawns
                                I hope you can help me, couse I managed to crash my whole MM system so I’m back on the start again. But this time I can’t even put my MM to my Raspberry. Shame on me but that’s how it is.
                                I’m working by ssh and Filezilla, have on my pi a Folder in /tmp/magic
                                but when I try to do
                                scp -r /kurt/Admin/Downloads/MagicMirror-master
                                pi@rasbpi:/tmp/magic
                                I get this
                                pi@raspi:~ $ scp -r /kurt/Admin/Downloads/MagicMirror-master
                                usage: scp [-12346BCpqrv] [-c cipher] [-F ssh_config] [-i identity_file]
                                           [-l limit] [-o ssh_option] [-P port] [-S program]
                                           [[user@]host1:]file1 ... [[user@]host2:]file2
                                pi@raspi:~ $ pi@raspi:/tmp/magic
                                -bash: pi@raspi:/tmp/magic: Datei oder Verzeichnis nicht gefunden
                                pi@raspi:~ $
                                Thanks a lot in advance
                                kurt
                                  bhepler Module Developer @kurt
                                  @kurt Your scp command didn’t go through. At a guess, you attempted to scp the entire directory and not the individual file(s). Try this instead: scp -r /kurt/Admin/Downloads/MagicMirror-master/mirror.tar
                                  • K Offline
                                    kurt @bhepler
                                    @bhepler
                                    Thank you
                                    pi@raspi:~ $ scp -r /kurt/Admin/Downloads/MagicMirror-master/mirror.tar
                                    pi@raspi:~ $
                                      @kurt Well, something’s not right with that scp command. All right, let’s do it the brute force way:
                                      cd /tmp/magic
                                      scp -rv /kurt/Admin/Downloads/MagicMirror-master/
                                      • K Offline
                                        kurt @bhepler
                                        @bhepler
                                        all right, but:
                                        pi@raspi:~ $ cd /tmp/magic
                                        pi@raspi:/tmp/magic $ scp -rv /kurt/Admin/Downloads/MagicMirror-master/
                                          @kurt Wait a second… the mirror folder… that’s on the same machine as your /tmp/magic, right?
                                          Try cp and not scp.
                                          • K Offline
                                            kurt @bhepler
                                            @bhepler
                                            The Magic Mirror-master Folder is in downloads on my mac
                                            tmp/magic is on my Raspi
                                            pi@raspi:/tmp/magic $ cp -rv /kurt/Admin/Downloads/MagicMirror-master/
                                            cp: Fehlender Zieldatei‐Operand hinter „/kurt/Admin/Downloads/MagicMirror-master/“
                                            „cp --help“ liefert weitere Informationen.
                                            Thanks for your patience
                                            • 4 / 4
