    Starter problem
    73 Posts 8 Posters 89.7k Views 5 Watching
    • K Offline
      kurt @in_a_days
      @in_a_days
      sorry but if I write just
      pi@raspberrypi:~ $ cd ~
      nothing happens
      • I Offline
        in_a_days @kurt
        @kurt
        That’s okay! You’re in the right folder now :)
        In the previous post your command prompt looked like this:
        pi@raspberrypi:~/MagicMirror $
        Which shows you in the MagicMirror directory. But if your command prompt now looks like this:
        pi@raspberrypi:~ $
        Then you are back in the correct ‘~’ folder and you can proceed to step 2.
        • K Offline
          kurt @in_a_days
          @in_a_days said in Starter problem:
          tar -cvf mirror.tar /MagicMirror
          this is what I get:
          pi@raspberrypi:~ $ tar -cvf mirror.tar /MagicMirror
          tar: Entferne führende „/“ von Elementnamen
          tar: /MagicMirror: Funktion stat fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
          tar: Beende mit Fehlerstatus aufgrund vorheriger Fehler
          What do you think?
          Thank you
          • I Offline
            in_a_days @kurt
            @kurt
            I apologize, I have not used the tar command before. Remove the ‘/’ before MagicMirror. Try:
            tar -cvf mirror.tar MagicMirror
            • K Offline
              kurt @in_a_days
              @in_a_days
              Thank you everything went qicker than the eye…
              what is the name of the file, it should be outside of the MM file in the pi file?
              • I Offline
                in_a_days @kurt
                @kurt
                Great! I’m still very new to this and I’m not using FTP. But there should now be a file named ‘mirror.tar’ in your ‘pi’ directory.
                • K Offline
                  kurt @in_a_days
                  @in_a_days
                  seems to be well hidden, wherever it is…hmm
                  couldn’t find it
                  • I Offline
                    in_a_days @kurt
                    @kurt
                    From the ~ folder:
                    pi@raspberrypi:~ $
                    type
                    ls
                    Do you see the mirror.tar file listed there?
                    • K Offline
                      kurt @in_a_days
                      @in_a_days
                      here we are :)
                      pi@raspberrypi:~ $ ls
                      Bilder     Dokumente    mirror.tar  npm-debug.log  python_games  Videos
                      Desktop    Downloads    Music       oldconffiles   Scratch
                      Documents  MagicMirror  Musik       Public         Templates
                      but isn’t shown in Filezilla directory
                      should be in Bilder Dokumente mirror.tar ? right?
                      the path is not quite clear for me
                      not that easy…Thanks a lot for your time in_a_days
                      I B 2 Replies Last reply Reply Quote 0
                      • I Offline
                        in_a_days @kurt
                        @kurt
                        Happy to help! Unfortunately, this is where my knowledge ends. I’m not sure what folders you can see over Filezilla. But again make sure you are in the ~ directory and try this:
                        cp mirror.tar Dokumente
                        If you can access that Dokumente folder in Filezilla, you should now see the mirror.tar file.
                          broberg Project Sponsor @kurt
                          @kurt
                          no, Bilder and Dokumente is two different folders,
                          either it’s the first directory you get to when connecting with ftp
                          OR
                          it is in /home/pi/
                          • K Offline
                            kurt @in_a_days
                            @in_a_days and @broberg
                            Thank you, not that easy to find the lost sheeps
                            the file was in:
                            /home/pi/Dokumente
                            but Filezilla didn’t show the file from the start, also I refreshed…
                            So Thanks a lot for your quick help!
                            Kurt
                            • K Offline
                              kurt @yawns
                              @yawns
                              Hi yawns
                              I hope you can help me, couse I managed to crash my whole MM system so I’m back on the start again. But this time I can’t even put my MM to my Raspberry. Shame on me but that’s how it is.
                              I’m working by ssh and Filezilla, have on my pi a Folder in /tmp/magic
                              but when I try to do
                              scp -r /kurt/Admin/Downloads/MagicMirror-master
                              pi@rasbpi:/tmp/magic
                              I get this
                              pi@raspi:~ $ scp -r /kurt/Admin/Downloads/MagicMirror-master
                              usage: scp [-12346BCpqrv] [-c cipher] [-F ssh_config] [-i identity_file]
                                         [-l limit] [-o ssh_option] [-P port] [-S program]
                                         [[user@]host1:]file1 ... [[user@]host2:]file2
                              pi@raspi:~ $ pi@raspi:/tmp/magic
                              -bash: pi@raspi:/tmp/magic: Datei oder Verzeichnis nicht gefunden
                              pi@raspi:~ $
                              Thanks a lot in advance
                              kurt
                                bhepler Module Developer @kurt
                                @kurt Your scp command didn’t go through. At a guess, you attempted to scp the entire directory and not the individual file(s). Try this instead: scp -r /kurt/Admin/Downloads/MagicMirror-master/mirror.tar
                                • K Offline
                                  kurt @bhepler
                                  @bhepler
                                  Thank you
                                  pi@raspi:~ $ scp -r /kurt/Admin/Downloads/MagicMirror-master/mirror.tar
                                  pi@raspi:~ $
                                    @kurt Well, something’s not right with that scp command. All right, let’s do it the brute force way:
                                    cd /tmp/magic
                                    scp -rv /kurt/Admin/Downloads/MagicMirror-master/
                                    • K Offline
                                      kurt @bhepler
                                      @bhepler
                                      all right, but:
                                      pi@raspi:~ $ cd /tmp/magic
                                      pi@raspi:/tmp/magic $ scp -rv /kurt/Admin/Downloads/MagicMirror-master/
                                        @kurt Wait a second… the mirror folder… that’s on the same machine as your /tmp/magic, right?
                                        Try cp and not scp.
                                        • K Offline
                                          kurt @bhepler
                                          @bhepler
                                          The Magic Mirror-master Folder is in downloads on my mac
                                          tmp/magic is on my Raspi
                                          pi@raspi:/tmp/magic $ cp -rv /kurt/Admin/Downloads/MagicMirror-master/
                                          cp: Fehlender Zieldatei‐Operand hinter „/kurt/Admin/Downloads/MagicMirror-master/“
                                          „cp --help“ liefert weitere Informationen.
                                          Thanks for your patience
                                          • K Offline
                                            kurt @kurt
                                            Hallo
                                            I managed at least to get the MM on my Raspberry, but here are again some mistakes, which I hope somebody can help me with.
                                            So I didn’t touch the default modules, just changed the location in the weather moduls.
                                            Thank you
                                            Kurt
                                            pi@raspi:~ $ cd ~/MagicMirror
                                            pi@raspi:~/MagicMirror $ DISPLAY=:O npm start
                                            > magicmirror@2.1.0 start /home/pi/MagicMirror
                                            > electron js/electron.js
                                            npm ERR! Linux 4.4.38-v7+
                                            npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                                            npm ERR! node v6.9.4
                                            npm ERR! npm  v3.10.10
                                            npm ERR! code ELIFECYCLE
                                            npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
                                            npm ERR! Exit status 1
                                            npm ERR!
                                            npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
                                            npm ERR! If you do, this is most likely a problem with the magicmirror package,
                                            npm ERR! not with npm itself.
                                            npm ERR!     electron js/electron.js
                                            npm ERR!     npm bugs magicmirror
                                            npm ERR! Or if that isn't available, you can get their info via:
                                            npm ERR!     npm owner ls magicmirror
                                            npm ERR!     /home/pi/MagicMirror/npm-debug.log
                                            • 4 / 4
